Old 12-25-2012, 12:12 AM
richterbmw richterbmw is offline
Mein Auto: 02 BMW 325xi
BMW Diagnostic Tool for Scanning ABS, Brake, DSC Lights
Hello Everyone,
Well this questions has been asked a hundred times and I know I should visit a dealer to have my car scanned so I can figure out how to resolve this problem. The problem I have is I live in the middle of North Dakota and there isn't a BMW dealership for at least 500 miles (Minneapolis).
My brake, ABS, and DSC lights are all on, on my 2002 325xi. I've checked all of my speed sensors and cleaned them but the problem persists. I don't really want to drive 500 miles in the winter to Minneapolis to visit a dealership. Do most car repair shops have the necessary tools to diagnose BMW's? I'm thinking of ordering a scanner off eBay so I can scan the car myself but I'm not sure if the scanners on there will be able to diagnose this problem.
Does anyone else have any experience in using a code scanner from eBay or elsewhere that is specifically made for BMW's? I hope it's just a speed sensor but the problem is you can't tell if they are bad without a scanner and I live 500 miles from the nearest BMW specific scanner. I was thinking of ordering the following scanner but I'm not sure if it will return what I need.
http://www.ebay.com/itm/Brand-New-BM...c96a2c&vxp=mtr
Any help would be appreciated.
Thank You!
Old 12-25-2012, 12:16 AM
chansta chansta is offline
Learning Daily
Mein Auto: 89 CIVIC
wheel speed sensor? you can test these with a dmm if you know how it works.
iATN
Old 12-25-2012, 12:23 AM
What is DMM
I think it is the wheel speed sensor but I don't want to replace all of them. Can you shed some more light on what "dmm" is? Thank you for the quick reply.
Old 12-25-2012, 12:24 AM
Never mind
Oops never mind. Thanks for the reply. I'll test the speed sensors with a "DMM".
Old 12-25-2012, 01:08 PM
Most of us avoid the dealer like the plague ... so that should be of no concern to you (other then for the odd fifty-cent hose or bolt).
It's called the trifecta. It has happened to virtually every single E38, E39, and E46 on the planet. See this canonical reference:
- How to diagnose & resolve the BMW ABS BRAKE DSC/ASC trifecta DIY
How did you check them? (We've outlined the six or seven tests in that post above).
The only tools you need are a DMM and some celery wire for testing the sensors; for testing the ABS control module, you need an exacto knife and a toothpick (and a magnifying glass if you don't have good eyes).
All the details are in that thread I just pointed you to (almost 300,000 people have visited that thread, so, all the garbage has been weeded out - and - all the odd-ball experiences have been added & resolved). Nobody has failed to solve their trifecta.
Necessary tools? It's just a car. It's simply an engine. It's a plain Jane Bosch ABS (same one used in plenty of other vehicles). There's nothing special about it (other than BMW cut costs by locating the ABS control module too close to engine heat and vibration & Bosch screwed up on their attachment of the 7th aluminum wire to its gold bondpad).
If you really want the fancy schmancy diagnostic tools, you guys have an E46 thread on where to get them yourself. The E39 thread for that is here:
- Making sense of the most often recommended BMW diagnostic tools & cable interfaces (1)
Loooooong story. The fancy schmancy tools, in the case of the trifecta, have been proven (time and time and time again) to be nearly useless. See why here:
- Why the fancy diagnostic tools very often (extremely often, like almost all the time) fail to properly diagnose the trifecta or bifecta (1) (2) (3) (4) (5) (6)
Ummm... yeah. Plenty of people here (see the aforementioned diagnostic thread). But, for the trifecta, just get out a good DMM (my Fluke 75 worked perfectly for the trifecta diagnostic step) and some really thin celery wire.
Let me put it bluntly. The scanner is (almost) useless for the trifecta - the reasons why are in the aforementioned threads.
There's that dealer again!
Only a fool replaces more than one wheel speed sensor.
You, my friend, have a simple problem, with a simple solution. Just read:
- How to diagnose the BMW amber ABS BRAKE DSC/ASC trifecta or bifecta (1) & what are all known options when your ABS control module is bad (1) & Quick99Si's explanation of why the 10-minute wheel speed sensor diode-action quick test doesn't always work, especially on brand new non-OEM wheel speed sensors (1) (2) & explanations by 540iman as to why the fancy diagnostic tools very often (extremely often, like almost all the time) fail to properly diagnose the trifecta or bifecta (1) (2) (3) (4) (5) (6) & where to get the fancy schmancy diagnostic tools for free once you're aware of these limitations (1) & an ABS BRAKE DSC trifecta brake pressure sensor diagnostic DIY (1) & how to test and replace the steering angle sensor (1)
Old 12-25-2012, 08:22 PM
Thank You bluebee
Hello bluebee...
Thank you very much for the detailed break down of my question. I've purchased a DMM and will post the results once I know more.
Thanks for the help everyone
Old 12-26-2012, 12:27 AM
Right Rear Sensor
Well I checked using a DMM and all sensors returned 2.9v except the right rear sensor which I couldn't get a reading from. I know that sensor can cause problems with my cruise control but that strangely still works. Ordered a new sensor... Fingers crossed
Old 01-04-2013, 11:52 PM
Speed sensor didn't resolve the problem
I just replaced the right rear speed sensor and that didn't solve the problem. I have a 325xi and I don't think the pin-out instruction in the DIY ABS, DSC, Brake light fix are correct for a E46 as the instruction cover a E39. Ordered a BMW Super Scanner from eBay:
http://www.ebay.com/itm/140767720234...S:3160&vxp=mtr
I hope that will help me shed more light on what the problem could be. I don't think its the ABS module overheating as the problem started on a cold day in North Dakota. I don't think anything could overheat when it's 20 degrees outside If anyone else has anymore suggestions I'd appreciate them.
Old 01-05-2013, 10:48 AM
That makes no sense (to me).
You replaced the sensor, right?
You had it in your hands, right?
If so, why not just test the readings off the two pins on the end of the sensor connector?
You wanted a scanner so badly, I suspected you were going to get one.
The problem with a scanner, especially on the ABS issues you're facing, is that it has to be connected in the right place (bypassing the ABS control module in most cases).
Nobody ever does that. So everybody gets the wrong answer when it's the (broken) ABS control module that is giving the answers.
What if the 7th aluminum wire lifted off it's gold bondpad (which is the most common ABS control module fault)?
Are you saying that just can't happen in 20 weather?
Old 01-05-2013, 02:55 PM
Sensor pinout
I actually didn't remove the sensor until I ordered the new one. When I said the pin out wasn't correct I was talking about the harness under the hood where all of the points come together and plug into the ABS module. I tested from there when I originally diagnosed the problem using the a DMM.
Pins 30 and 31 are specified in the DIY diagnosis which weren't the correct pins for my rear right sensor. The other pins are correct. So after testing the other points and getting a reading from the DMM I assumed the right rear was the culprit because I wasn't getting a reading from it... Which wasn't the the problem. The DIY has a list of several error codes that can be returned and when browsing other posts regarding the same issue most people say take it to the dealer and get the codes read because it can be different problems.
I don't understand what you mean by connecting in the wrong place? From my understanding the code reader connects to the OBDII output by the drivers feet.
What if the 7th aluminum wire lifted off it's gold bondpad (which is the most common ABS control module fault)? Are you saying that just can't happen in 20 weather?
That I'm not sure of. Some posts I've read say this happened on a hot day due to heat problems causing problems with the solder points and my problem starting happening when I was driving on a really cold day. But I guess this could be the problem too.
Does anyone know where to find more information on this problem related to E46 and not an E39?
Old 01-06-2013, 12:13 PM
EDIT: I'm very sorry the DIY caused you to buy a sensor you didn't need. I understand. You trusted the DIY, and it failed you. I feel badly about that. I wish there was a good description of the pinout for the E46. I implore the E46 owners to list the pinout.
Here is mine for the Bosch 5.7 DSC III module.
Once you have the E46 pinouts (they may vary by module), the rest of the DIY should be the same.
The trifecta is sooooooo prvevalent that it behooves you guys to figure out the pinout, once, so that everyone can benefit.
It would be nice if one of you posts an update to the aforementioned thread (which has had 250K views so a LOT of people are going there for solutions).
Once the proper pinout is outlined for the E46, the rest of the procedure should be the same.
Would you kindly post the right pinout to that thread so the NEXT E46 owner has the answer (or open an E46-specific thread, or put it here, and I'll reference it).
That's the wrong place.
Fundamentally, ALL scanners try to read the (often broken) ABS computer for the answer ... and they all come up with the wrong answer almost all the time if not all the time. I didn't conclude this - others did - but the record time and time and time and time again has borne this one out.
Sad to say, but the scanner won't help when it comes to the trifecta. A toothpick and an exacto knife is all you really need to positively diagnose an ABS control module.
It's covered in gory detail here:
- Repeated explanations by 540iman as to why the fancy diagnostic tools fail (1) (2) (3) (4) (5) (6)
There are many idiots out there. And morons. And styupid people. And smart people. The whole gamut is out there - so - guess what? Since the bifecta or trifecta happens to almost all of us (if not all of us), there are that many opinions on what happened.
Fact is you have it. It's like a disease. It really doesn't matter, at this point, how you got it (in reality, BMW put the ABS control module too close to the engine in order to save money - which is covered with proof from Bosch - but it really doesn't matter at this stage).
If there is a canonical E46 link, please let me know so that I can refer to it in the aforementioned canonical ABS control module diagnostic DIY.
If there are folks who own an E46 who know the answer, please chime in.
In addition, it's not really the vehicle model that matters so much as the ABS system model. Here's just one page, a chart, out of the BMW training manual that we posted on that thread which covers the E46 in gory detail, as well as the E39.
Old 01-07-2013, 05:36 PM
It's Ok
Hey bluebee no worries. I appreciate the DIY you've put together and it's been helpful diagnosing ABS problems on my 325xi. Once I get the scanner in I'll report back. I appreciate all of the effort put forth into creating the DIY and once I get back into the heated shop (Live in North Dakota) I'll provide more information on the ABS harness pin-out for E46 owners.
Old 01-07-2013, 08:51 PM
That would be great.
Here is the thread for it:
- E46 ABS control module harness wheel sensor pinout for the ABS/BRAKE/DSC bi trifecta
Old 05-04-2013, 08:17 PM
TK9211 TK9211 is offline
Mein Auto: 2006 325i
Guys, sorry I am too confused trying to follow how to fix this trifecta on a 02 e46? Can either of you list me exact link/steps (one more time) please? I don't have any tools, have tried nothing and don't even know what dmm is, so please don't joke but help this layman...thanks much !!
Old 12-07-2014, 10:29 PM
NutsAndBolts NutsAndBolts is offline
NutsAndBolts
Mein Auto: 2000 X5 4.4L
I am looking for the pinout for the 2000 E53 DSC module. Like richterbmw, pin 30 is not correct for my vehicle. I removed the wiring harness cover and can see that pin 30 is not used. I never saw the conclusion to richterbmw's E46 pinout. Does anyone no where I can find more DSC pinout information? Would you expect the pinout for the 2002 E39 and the 2000 E53 to be the same since the table indicates that they are both DSC III Bosch 5.7? Would you expect the pinout information to be in the Bentley E53 Service Manual?
Old 01-04-2015, 05:20 PM
NutsAndBolts
Following up on my last post. Couldn't find any pinout information on-line so I finally got around to ohm'ing out the right rear wheel speed sensor to the DSC module on my E53. The signal wire maps out to Pin 14 on the DSC wiring harness. All other speed sensor signals and grounds matched bluebee's E39 pinout. Tried the resistance and diode tests from a different post from Bluebee. Diode test failed on all 4 sensors. Ohm test so open circuit for 5 of the 8 tests. Only the Right Rear showed resistance in both forward and reverse bias (removed all 4 wheels and tested at the blue connectors).
Sensor Left Rear (FB) Left Rear (RB) Right Rear (FB) Right Rear (RB) Left Front (FB) Left Front (RB) Right Front (FB) Right Front (RB)
DMM (+) Lead Pin 13 Pin 29 Pin 14 Pin 31 Pin 28 Pin 12 Pin 15 Pin 16
DMM (-) Lead Pin 29 Pin 13 Pin 31 Pin 14 Pin 12 Pin 28 Pin 16 Pin 15
Diode Test 0L 0L 0L 0L 0L 0L 0L 0L
Resistance 0L 38.2M 5.0M 5.0M 0L 0L 0L 0L
Next step is to remove sensors, clean and test. Started with Left Rear and have a mess. Very similiar to
http://www.bimmerfest.com/forums/sho...43#post8495943
Guess it is time to get out the drill???
Old 06-16-2016, 08:22 AM
FinnL FinnL is offline
Mein Auto: 2004 325i
2004 325i Ate DSC
This is for 2004 325i Ate DSC (not Bosch).
The DSC (also called ABS charge pump) unit is located under the master brake cylinder (not easy to get to).
Controller module: 6 765 454 (10.960-0820.3)
Pump: 6 765 452 (10.0206-0026.4)
Note: the two screws that holds the pump to the valve unit also holds the controller module to the valve unit.
Pins:
1: 8 volts
32: 12 volts
12+32: ground
Brake cylinder pressure sensor:
18 (black/purple))
19 (white/blue)
20 (blue/black)
21 (white/blue+yellow dot) (ground)
22 (blue/black+yellow dot)
23 (white/blue)
Wheel sensors (these are all 2-wire magnetic hall sensors):
Front right:
33 (brown) (ground)
34 (yellow)
Rear left:
37 (brown) (ground)
36 (blue)
Rear right:
43 (brown/yellow) (ground)
42 (yellow/black)
Front left:
46 (brown) (ground)
45 (brown/red)
If you test the wheel speed sensors with a multimeter, use the diode test setting. About 700 in one direction and infinite in the other.
With all wheels off the ground, one at a time I put an oscilloscope on each of the pins (34, 36, 42, 45), turned on the engine and turned each wheel. The square 0.75 V p-p waves were not easy to see in all the noise, but visible.
I started out with only the yellow DSC and BRAKE lights on. Now I also have the yellow ABS light on. Probably because I started the car with the master cylinder pressure sensors disconnected. Now I need to figure out how to reset them (NCS Expert?).
Because I had a hissing sound when applying brakes, I finally replaced the brake booster (yes, that was the source of the hissing sound), and to make space to do that I removed the master cylinder, which then gave me access to remove and inspect the DSC unit.
I cut the lid off the module with a hack saw in the existing groove.
Unfortunately I did not see any bad solder joints. This unit is very well made.
I did ohm the pump and found it odd that it's only 0.5 ohms or so. I have a used unit on order and will see what it is there.
Meanwhile I had to put everything back together (hot glued the lid onto the controller) so I can drive the car.
Bleeding the brakes with a vacuum pump was not as difficult as I had read. Used less than 32 oz.
ID:	567417   Click image for larger version
ID:	567418   Click image for larger version
ID:	567419   Click image for larger version
Old 06-21-2016, 11:49 AM
stroogie stroogie is offline
Mein Auto: 325ci
help!
Has anyone gotten this. My brake light (in yellow) and the triangle light came on. It came on before but would shut off after turning off the car. Now its on all the time. Thanks so much!
diagnostic tools, dsc abs brake lights
