Old 05-03-2013, 06:38 PM
handstand handstand is offline
Mein Auto: 2013 535i x-drive
Hi. I haven't been able to find a working link to download E-Sys. Could someone point me in the right direction? Also, is there a way to tell what version of pszdata my car is currently running?
Many thanks in advance.
Old 05-03-2013, 06:49 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
You need read the car's current I-Level with E-Sys to know what it has on it:
http://www.f30post.com/forums/showpo...postcount=1403
Once you know the current I-Level, you can cross reference it to the ISTA/P version.
PM sent.
Old 05-03-2013, 07:18 PM
Thanks so much for the quick reply, Shawn.
Old 05-04-2013, 02:45 AM
modicbmw modicbmw is offline
Mein Auto: bmw 520
I very interested in the BMW programming, although I have to use isss and isid-diagnosis programming.
But I still prefer the E-sys and winkfp of
Is currently learning.
Old 05-04-2013, 02:52 AM
Yes, i think E-Sys is better too in that you can flash individual ECU's rather than a running a full measures plan on the car.
Old 05-05-2013, 12:21 PM
firebull firebull is offline
Mein Auto: F31 330xd
i just installed esys 3.22.5 with patch and token, but iīm new in F-series coding so i still have some problems/questions.
I want to code auto start/stop and speedlock for the beginning, but i donīt know where it is in new F31 (build 04/2013).
And if i want to read coding data i get two errors, the other ECUs work reading them.
http://imageshack.us/f/547/87363286.png
http://imageshack.us/f/705/43411419.png
Can someone help me please?!
Thanks a lot
Old 05-05-2013, 01:46 PM
Thanks a lot
You selected F20 Target, the one without _DIRECT after it correct?
Which PSdZData version are you using?
What is your current I-Step?
Old 05-05-2013, 05:12 PM
littlezen littlezen is offline
Mein Auto: 2011 750i
Help needed
Hello fellow coders,
Thanks to Shawn I've been able to code the following - disclaimer removal, window/mirrow close with key fob, and truck close with key fob. With that said I have run into a few road blocks and looking for your assistance.
I'm currently running Esys 3.18.4 with psdzdata 48.3 on windows 7 laptop coding a 2011 750i (F01).
1. Disabling Auto start/stop - I'm not able to locate CAS>300 TC> TC_MSA_DEFAULT_OFF; Is this located some where else on an F01? (Actually my first question is what does disabling Auto Start/Stop do?)
2. HUD Turnsignal - I'm not able to locate KOMBI>3000 Anzeige_Konfiguration>BLINKER_HUD_ENABLE; Again if this located elsewhere for F01 please let me know. I did find HU_CIC>3000 HMI>HUD Turnsignal and changed it to active but it did not work for me.
3. Tire pressure Info - Is this the correct module for tire pressure: HUCIC>3001 EBOX>RDC_Safety? If not, please direct me to the correct module(s).
4.DVD in motion: Are these the 3 i need to change: SPEEDLOCK_X_KMH_MAX, SPEEDLOCK_X_KMH_MIN, and VIDEO_NUR_MIT_HANDBREMSE? If not these, please direct me to the correct module(s).
5. Cameras in motion: Are these the 4 I need to change: D_SCHWELLE_1, D_SCHWELLE_2, V_SCHWELLE_1, V_SCHWELLE_2? If not these, please direct me to the correct module(s).
Again, appreciate any help you guys can provide.
Thanks,
Josh
Old 05-05-2013, 05:55 PM
Thanks,
Josh
I have not seen an F01 Cheat Sheet, but the codes for F10 and F01 are the same, or similar enough to understand what to code. So, I can't tell you exactly what to look for in your F01, and will answer based on F10.
1) Your car should not have ASS (Auto Start Stop). You would have a switch as part of the Start / Stop button right below it if you did, A 750i should not have it as it is not on V8 engines.
2) What is the name of your Kombi CAFD file? When you enabled HUD_TURNSIGNAL, did you go under iDrive Options and enable the "Turn indicator" Checkbox in Settings=>Heads-Up Display?
3) Yes.
4) Yes. For the SPEEDLOCK settings, you will be changing the Werte Value
5) Yes. For the SCHWELLE settings, you will be changing the Werte Value
If you do not know how to change Werte Values, read this:
http://www.bimmerfest.com/forums/att...5&d=1338725691
When you change a Werte Value, you change only that, and do not change the associated Dropdown value at the same time, and vice versa. It will always be one or the other, but not both.
Also, when you look for codes, all the matters is the Module (ECU) itself, and not the subsection of it (e.g. 3000, 3001, etc.). In your chassis the codes you are looking for could easily be in a different section.
Old 05-06-2013, 03:12 AM
Hello Shawn,
i use PSdZData 49.1 with update to 49.2 and 49.3.
And i select F20 Target without _Direct, yes.
Now i could code DVD In Motion (a first success :-) ) The problem here was: In the F30 CheatSheet the ECU was not the same than in my car.
For the i-Step i will have to look this evening and then post it here.
Thanks a lot for your help!!!
Old 05-06-2013, 09:31 AM
Hello Shawn,
my I-Step is: F020-13-03-503
When i want to code Auto Start/Stop to default: "off" i get this error:
https://www.dropbox.com/s/3ra46y61t7...2018.26.29.jpg
Old 05-06-2013, 10:07 AM
Hello Shawn,
Hello Shawn,
Your problem is that you have 49.3 on the car (cafd_00000794.caf.004_228_010), and it requires the full 49.3 PSdZData. Unlike 49.2, it cannot run inside the 49.1 PSdZData container. You must update.
PM sent.
Old 05-06-2013, 12:24 PM
I don't currently have my laptop so don't know what the CAFD file name is. I did go into iDrive but did not see the "Turn Indicator" option in the HUD section. I'll continue to play with this further. Thanks again for all your help!
Josh
Old 05-06-2013, 01:55 PM
Josh
Well, when you find out what the name of the CAFD is, let me know and I will look at it.
Old 05-06-2013, 05:44 PM
val3ntin3s's Avatar
val3ntin3s val3ntin3s is offline
Mein Auto: 2012 535i
Shawn, can you PM the link with the latest PZ data please? Thank you
2015 F32 435i | Estoril Blue |M Sport
2012 F10 535i | Alpine White | ZPP | ZSP | Tech | Lip Spoiler - retired
2007 E92 335i | Spark. Graph. | ZSP | 6 speed MT | Lip Spoiler - retired
Old 05-06-2013, 08:23 PM
PM sent.
Old 05-07-2013, 12:20 PM
Still one question:
Does anyone know if the DAB function can be activatet with esys or are there additional modules needed?
I found it in esys, but i dont have in in my car configuration....
Old 05-07-2013, 02:08 PM
XQOS XQOS is offline
Mein Auto: 750i F01
Software links
Hello,, Im just starting to code my 09 750, can someone send me links to the software? I ordered the cable from Ebay today.
BMW ENET ESYS E-SYS ICOM ISTA ETHERNET OBD CODING INTERFACE RJ45 CABLE F-SERIES
Thanks ...
Old 05-07-2013, 03:09 PM
Still one question:
Do you have CIC / NBT? I thought the DAB Tuner was built into those in Europe, whereas we get a Sat Radio Tuner instead.
Old 05-07-2013, 03:12 PM
Thanks ...
PM sent.
Old 05-08-2013, 10:01 PM
Richy1877 Richy1877 is offline
Mein Auto: F30
Hi,
Since i got my F30 back from service, all my code was gone, then i have to re-code my car and the 3.814 no longer work, then i switch to 3.225 and 49.1, the IHKA module could be modified, but the FEM body got error said that file for cafd_0000794-004_228_010 not found, any idea of this issue? Thx in advance!!
Old 05-09-2013, 03:38 AM
I Have a new problem:
when i connect the first time to the 530d (F10, Built 05/2012) i can read all,
after clicking edit and exit the editet file i loose my connection.
I use latest psdzdata 49.3.
Can anyone tell me whats the problem here?
See screenshot here:
https://www.dropbox.com/s/b6mhs1jfj8r5bml/error.PNG
Thanks in advance
Old 05-09-2013, 07:19 AM
I have NBT (there i can find DAB (in US sat radio)
i just have all those ECUs:
https://www.dropbox.com/s/nei7rp7gy1u0opk/ECU.PNG
Old 05-09-2013, 07:23 AM
Yes, you will need 49.3 (i have this file in 49.3).
PM Sent
Originally Posted by Richy1877 View Post
Hi,
Old 05-09-2013, 09:07 AM
Thanks in advance
Are you using E-Sys 3.18.4?
