48.3 vs. 49.0 PSdZData CAFD Changes - E-Sys 3.18.4 End of Life - & 49.1 Changes - Page 14 - Bimmerfest - BMW Forums
Old 05-06-2013, 07:41 PM
djsaad1 djsaad1 is offline
Mein Auto: range rover
shawn when you get a chance can you send me the password for 49.3? Thanks!
Old 05-06-2013, 09:24 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
PM sent.
Old 05-07-2013, 10:14 AM
erkbiz erkbiz is offline
Mein Auto: 2013 X3
Shawn,
I posted twice cause I thought this thread was the wrong place to post and didn't see a place to delete it from here. Won't do it again.
A question: If I do a complete reset on the ECU, as you suggested, is it possible I may wipe something out, other than my changes, that could cause me more headaches? Is it possible that when the vehicle left the factory or at the dealer something was coded that changed the default settings?
Thanks,
ERK
Old 05-07-2013, 10:55 AM
Originally Posted by erkbiz View Post
Shawn,
Thanks,
ERK
Actually, you are correct. The new thread you opened was the appropriate thing, and this is the cross post. Unfortunately, you can not delete posts on Bimmerfest, although I wish you could.
To answer your question, no, it is not possible to wipe something out other than your changes. When you VO code an ECU, it undergoes the same identical process that your dealer does when they program your car with ISTA/P, which is to code 100% of the ECU to predefined settings required to support all your vehicle options defined in your Vehicle Order (VO) based on your vehicle's Production Date. What you end up with is an ECU matching its original as delivered state.
Old 05-07-2013, 04:17 PM
webb webb is offline
Mein Auto: korea
Hi my friend.
Old 05-07-2013, 04:19 PM
PM sent.
Old 05-08-2013, 06:50 AM
Mein Auto: 2013 X3
Shawn,
Going to reprogram the HKFM today. I first tried to set the CADF values back to their original state, (kinda nervous about reprogramming the entire ECU), but this didn't work. I also don't understand why after programming it takes up to 2 hours for the programming to take effect. If you have the time can you explain please? And, does this mean waiting 2 hours with the ignition on and engine running?
When I reprogram the ECU do you know if it will take effect immediately or do I need to wait some time period?
The psdzdata file I am using is 49.1 with a 49.2 patch on E-Sys 3.22.5, (obtained about 2 weeks ago). Would it be to my advantage to upgrade my psdzdata file to 49.3? My X3 was built end of Jan/beginning of Feb 2013. If I do update the psdzdata file to 49.3 is it just a matter of replacing my current file with this new one?
Just curious, does the data to reprogram the ECU to the VO come from the psdzdata file based on my vehicle's VIN?
Again, I appreciate the assistance. Thanks,
ERK
Old 05-08-2013, 08:41 AM
Shawn,
ERK
You should not worry about VO Coding any ECU. As I already explained, this is harmless, and it is what your dealer does. And you are not programming the ECU, rather you are encoding it. Programming would involve flashing new firmware on the ECU.
The only FDL Code that for some reason is not instant, is the Trunk Close from Fob and Dash Button. No one knows why that is. It is not really 2 hours, more like 20 minutes or so. The car needs to go into sleep mode (completely off for around 20 minutes) it seems in order for the FDL Code to begin working.
There is no reason nor advantage in your case to updating to 49.3. If you were to though, you would just REPLACE in its entirety your existing 49.1 psdzdata folder with the 49.3 psdzdata folder.
Old 05-09-2013, 04:00 AM
seksona seksona is offline
Mein Auto: 520d F11
Dear Shawn,
I just donwloaded psdzdata 48.3. Could you please PM me the paspassword for opening .rar file
Many thanks for your help.
Sekson
Mein Auto: 520d F11
Dear Shawn,
Sekson
Old 05-09-2013, 10:30 AM
Originally Posted by seksona View Post
Dear Shawn,
Sekson
PM sent.
Old 05-09-2013, 10:47 AM
ngo2 ngo2 is offline
Mein Auto: 530XD
Hi Shawn,
My I-STEP Version is F010-13-03-503
Please PM me the link for the propper E-SYS and Psdzdata files (incl. rar passwords)
I'm useing 3.18 and 48.3 right now
Thank's a lot!
Old 05-09-2013, 10:58 AM
Originally Posted by ngo2 View Post
Hi Shawn,
Thank's a lot!
PM sent.
Old 05-11-2013, 06:32 PM
LowFlying LowFlying is offline
LowFlying
Mein Auto: 2017 340xi
Shawm et alia,
My I-Step = F020-13-03-502
Currently using E-Sys 3.22.5 & PsdZData 48.3
The Transaction Report shows an error on a few CAFD downloads.
does this mean i need a newer version of PsdZData?
Regards Chris
Old 05-11-2013, 06:33 PM
LowFlying
Shawm et alia,
Regards Chris
Old 05-11-2013, 06:41 PM
LowFlying
apologies for the double-up
Old 05-11-2013, 07:32 PM
Originally Posted by LowFlying View Post
Shawm et alia,
Regards Chris
F020-13-03-502 = ISTA/P 2.49.1. You need to update your PSdZData.
PM sent.
Old 05-11-2013, 09:39 PM
findromy findromy is offline
Mein Auto: clouds
Need download link
Hi Shawn,
Can I please get the download link too. Thanks
I have few other questions about F02/750li BMW, can I PM you?
thanks
rs
Old 05-11-2013, 09:57 PM
Originally Posted by findromy View Post
Hi Shawn,
thanks
rs
PM sent.
Yes, you can send PM.
Old 05-11-2013, 10:21 PM
Mein Auto: clouds
WOW --- LIGHTING FAST
Thanks Downloading now.
Old 05-12-2013, 07:28 AM
Mein Auto: 2013 X3
Shawn,
Can you please send me the link for psdzdata version 49.3?
ERK
Old 05-12-2013, 08:06 AM
Shawn,
ERK
PM sent.
Old 05-12-2013, 01:23 PM
afafonin afafonin is offline
Mein Auto: F30
Originally Posted by shawnsheridan View Post
PM sent.
Shawn,
What's the difference between 49.2 and 49.3 ? May I have 49.3 CAFD updates?
Thanks.
Old 05-12-2013, 01:30 PM
Originally Posted by afafonin View Post
Shawn,
Thanks.
The difference is 49.3 Added these:
cafd_0000000f.caf.005_024_228
cafd_000000f9.caf.007_006_059
cafd_00000c18.caf.013_064_006
cafd_0000012f.caf.012_006_023
cafd_00000794.caf.004_228_010
cafd_00000819.caf.001_011_001
These though can not just be added to 49.1 PSdZData Library and used, so if needed, the the full 49.3 PSdZData must be used.
Old 05-12-2013, 01:34 PM
Mein Auto: F30
Great!
I have been update up to 49.2 by adding one CAFD file to 49.1. What items I have for download? Do you have a full 49.3 pack for 3.22.5 ? Thanks
