All BMWs After Coding Tailgate Doesn't Open or Close - Bimmerfest - BMW Forums
Old 05-06-2013, 12:20 PM
erkbiz erkbiz is offline
Mein Auto: 2013 X3
Hello,
I recently coded my 2013 X3 to auto close my tailgate using the button in the cockpit or from the fob.
The coding worked after waiting the suggested 1 hour but 24 hours later it quit working.
Not only does the TG not close automatically it doesn't open either, it unlocks but doesn't lift.
Has anyone else experienced similar problems? Do you have a solution?
Thanks,
ERK
Here is the coding I used:
Close Trunk/ Tailgate through button on FOB
HKFM | 3010 | SCH_FBD | aktiv / Werte=01
HKFM | 3010 | TASTER_FBD | aktiv / Werte=01
Close Trunk/ Tailgate through button on driver side
HKFM | 3010 | SCH_TOEHKI | aktiv / Werte=01
Old 05-06-2013, 06:05 PM
jaza45 jaza45 is offline
I'm in Miami B.
Send a message via AIM to jaza45 Send a message via Yahoo to jaza45
Mein Auto: E92 M3
Try to code the module back to default and then recode it again, it happen to me once with a friends 550GT.
Old 05-06-2013, 09:14 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by erkbiz View Post
Hello,
Thanks,
ERK
Please do not cross post:
http://www.bimmerfest.com/forums/sho...&postcount=320
Old 05-08-2013, 10:53 AM
Mein Auto: 2013 X3
Please disregard
Please disregard
Too bad we cannot remove posts from this forum
ERK
Old 05-08-2013, 01:03 PM
Stealth.Pilot's Avatar
The Driver
Mein Auto: 2014 M5
Did you check if you a accidentally nudged the valet trunk lock switch? This is a toggle switch in your glovebox or arm rest compartment which locks the trunk. Once that switch is set to lock, nothing will open or close the trunk. Sometimes it gets accidentally activated when you are fumbling in the armrest compartment.
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 05-08-2013, 02:44 PM
Mein Auto: 2013 X3
Stealth.Pilot
My vehicle is a small SUV it doesn't have the switch you site. Also, the tailgate unlocks it just doesn't automatically lift. What I did discover, however, is that if I repeatedly press the button on the fob the tailgate does go up in steps. Furthermore when I press the button on the tailgate to lower it instead of closing it jerks in an upward motion like it's trying to open further and this is with the restored default values having done a VO coding which removed the coding that I did.
Thanks for your suggestion.
ERK
Old 05-14-2013, 03:37 AM
TurboBusa TurboBusa is offline
Mein Auto: 2012 X5 5.0i
Sorry I cant be of more help, but I don't know about this coding stuff. I am thinking about getting my vehicle done this weekend, but this scares me. Did you ever get this work correctly? What happened? Please update!! Hopefully the pros will assist you with this.
Old 05-14-2013, 04:32 AM
Mein Auto: 2013 X3
TurboBusa,
Nope, I still have the problem, it is intermittent, (maybe it's healing itself?), and I am still working on it. My progress is slow because of my schedule. Prior to coding the TG I successfully coded the digital MPH readout. I am thinking that my situation is not typical.
If I am unable to resolve this I will end up at the dealer and tell them that the TG is operating intermittently and will have them recode the vehicle. Will I do any further coding? Right now I am not sure.
ERK
Old 05-14-2013, 04:39 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
Wow, u have to wait 1hr and a half for the TG to kick in? Damn
When I get my car coded, my TG worked right after in my X3.
If you go to the dealer and they find out about you messing with the coding of the car, don't be surprised if they would void the whole thing regarding to coding.
I would suggest to load up the original files that you backed up that wasn't coded.
Old 05-14-2013, 04:49 AM
Mein Auto: 2013 X3
Kamigawa120,
It wasn't that I had to wait the 90 minutes the cheat sheet stated that it took 1 to 2 hours to work so I didn't test it out immediately I chose to wait the suggested time. I did reset values back to their original state and the problem persisted, go figure.
I am thinking the dealer won't know that I was mucking with the vehicle their job is to just fix it. If they look at the current coding on the module they will see the default values cause I changed everything back. I don't see how they can tell that I did any coding. Besides I will play dumb, "Coding, I don't know what that even means"
ERK
Old 05-14-2013, 07:36 PM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: F80 M3
Did you try what I recommended?
Old 05-15-2013, 04:29 AM
Mein Auto: 2013 X3
I will be doing a VO coding on the module today. I hope it works.
As stated this is an intermittent problem. Yesterday evening when got home I used the button in the vehicle to open the TG and it went into a loop. It would unlock, raise about a foot, stop, close, lock then repeat. This continued unabated until I pressed the button again.
Old 05-15-2013, 03:22 PM
Mein Auto: 2013 X3
Just finished VO coding the module. Here is a copy of the log generated during the coding process:
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
TAL execution started. [C205]
ExecutionID=2013/05/15-17:24:36.650
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[HKFM_LS - 6B] prepareECUforCoding started
[HKFM_LS - 6B] prepareECUforCoding finished
[HKFM_LS - 6B] authenticateECUforCoding started
[HKFM_LS - 6B] authenticateECUforCoding finished
[HKFM_LS - 6B - cafd_000007c8-006_004_000] Transaction type: cdDeploy; Message: TA started
[HKFM_LS - 6B - cafd_000007c8-006_004_000] Transaction type: cdDeploy; Message: TA finished
[HKFM_LS - 6B] finalizeECUCoding started
[HKFM_LS - 6B] finalizeECUCoding finished
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "Finished". [C207]
TAL execution finished. Duration: "13s". [C206]
MSM update: Read current SVT. [C194]
MSM update started. [C215]
MSM update finished. [C216]
VCM Update: Write FA to VCM. [C188]
VCM Update: Write FP to VCM. [C190]
VCM Update: Read current SVT. [C191]
VCM Update: Check current SVT with TAL. [C192]
VCM Update: Write target SVT. [C193]
VCM Update: Write FA to backup. [C189]
VCM Update: finished. [C195]
Abarbeitung beendet
Old 05-15-2013, 04:11 PM
sfiermon sfiermon is offline
Mein Auto: 2014 x3 35i
what is a VO coding?
Old 05-15-2013, 05:40 PM
Caf's suchen
Tal wird generiert
Abarbeitung beendet
This all looks good. Was the TAL Log green (successful) or Red (unsuccessful)?
Old 05-15-2013, 05:45 PM
When you VO Code an ECU (right-click on ecu itself and select code), E-Sys will code all Function Data Lines (100% of the module) based on the Production Date and the SA Option Codes defined in FA (VO), as opposed to FDL Coding where you change individual Function Data Lines without any regard to FA (VO).
Old 05-15-2013, 06:15 PM
Mein Auto: 2013 X3
That is a good question. I don't know what the TAL log is or where to look for it. I did not see anything red which normally stands out. If you can tell me where to look for it I will try to recall if I saw something red or green.....thanks.
Old 05-15-2013, 06:52 PM
I was thinking it was log you posted, which should have been in a pop-up window.
Old 05-15-2013, 07:15 PM
Is there a benefit to VO coding?
Old 05-15-2013, 07:18 PM
Yes. One, assuming you have the necessary hardware, if you know the SA Option Code for a feature, but do not know all the individual FDL Codes required to enable it, you can simply add the Option to the VO and VO Code the module, and let the VO do all the FDL Coding work for you. Two, it is a quick easy way to reset an entire module to its as delivered factory condition.
Old 05-16-2013, 03:45 AM
Mein Auto: 2013 X3
Shawn, Yes, you are correct, the log is the TA Log. I don't recall any coloring so I don't believe there was anything colored red. I guess the bottom line is, did this VO work. I'm on my way out the door in a few and will try it several times throughout the day. Wish me luck.
Old 05-16-2013, 08:54 AM
Erkbiz, quick question. What is the year map version of your Navigation system?
Old 05-16-2013, 12:22 PM
Mein Auto: 2013 X3
kamigawa120,
I can do this for you but I don't know how to extract the year map version info from my vehicle.
erkbiz
Old 05-16-2013, 12:28 PM
Mein Auto: 2013 X3
Shawn, Triple_O,
TG Update.
When I first tried to open the TG it just unlocked it did not lift. Awhile later tried again and everything functioned as it should. Tried some time after that and it was still working. Not calling this problem fixed as of yet cause it was always intermittent. I figure if I go a week of normal operation and it continues to work I will claim success.
I thank you for all the advice you have given. Oh, and of course, if the problem is solved I will once again try to code it for auto close....Perhaps I am a "glutton for punishment".
Thanks again,
ERK
Old 05-16-2013, 12:29 PM
kamigawa120,
erkbiz
Check under iDrive Nav Options. It will dispaly the map version.
