Old 05-07-2013, 08:38 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Low Key Fob Battery Question...
How does placing the key fob near the steering wheel column help 'charge' it?
It does so wirelessly!?
Old 05-07-2013, 08:57 PM
Snorlax Snorlax is offline
Mein Auto: _
Never heard this. From what I know it is how the car pairs itself with the key by placing it next to the steering column. The key gets power from a small button type battery. Maybe someone knows something I don't about this.
Old 05-07-2013, 09:14 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
The E65\66 cars with comfort access uses a replaceable CR2032 battery. I would assume the F01/02 battery would be the same since the design of the key fob is similar.
Old 05-07-2013, 10:57 PM
Not sure, but my remote completely stopped working the other day; I believe the battery needs to be replaced (2.5 years old). Called BMW Assist (forgot I had BMW Remote on my iPhone) to unlock my doors. Car wouldn't start with the key in the car and I was told to place the remote near the steering column. Didn't work first couple of attempts, but after keeping the remote there for a little while (2 minutes?), and reattempting, the car started. Key has worked since, but I'm bringing in the car for service tomorrow and will ask them to replace the battery. Anyone know if the battery is covered under warranty?
Old 05-07-2013, 11:47 PM
KingTrack KingTrack is offline
Mein Auto: 750LI
Interesting, I had an issue where the car wouldnt start and the system told me to place the key next to the steering column and it started. I replaced the battery myself though, 3 batteries for 12 bucks at radioshack. Works fine now.
Old 05-08-2013, 12:13 AM
RGSM's Avatar
RGSM RGSM is offline
Mein Auto: 2016 750i
You should get a warning on the i-drive screen when the battery in the remote is low.
Pick up a few batteries at Radio Shack. It takes all of 30 seconds to change.
Old 05-08-2013, 07:18 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
On old E60s and E90s fobs used to be charged inductively on the ignition when you put the key in to start the engine. However this no longer happens as we all have at least basic keyless go without comfort access.
Old 05-08-2013, 08:35 AM
Hmm; okay; thanks for your replies, gentlemen. So the older remotes charged inductively; very neat! I'm just wondering what's occurring when the remote doesn’t work, but placing next to the steering wheel brings it back to life; maybe these charge up as well - but only for a short amount of use thereafter?
Old 05-08-2013, 08:47 AM
Basic immobilizer system is passive. i.e. no energy is needed on transponders part to be read. So basically when you put it next to the sw you let the reader read the immobilizer chip on the fob passively.
Old 05-08-2013, 09:17 AM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
Dang! That's a good price, I just bought 1 battery from Target (my fob battery died after 3 months!!!) and it was $6...
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 05-08-2013, 09:20 AM
Popoemt's Avatar
I just read a thread about this and it said the battery is covered... If you live a distance from the nearest center then try changing it out yourself, it literally took me about 30 seconds to pop the fob open and install a new battery, easy peasy... I'd check around on battery prices though...
2015 750i
2007 G35 (trade-in)
Old 05-08-2013, 01:23 PM
I just asked my dealer on the latest oil change and they did it for free. Changed the batteries on both fobs just to be safe even though only one fob gave me errors.
This is the latest status of my fobs
Old 05-08-2013, 02:34 PM
Just dropped my car off at the dealer; service advisor said that it's covered, but I'm wondering what placing the remote near the steering wheel does to bring it back to life...
Old 05-08-2013, 09:01 PM
For anyone wondering same:
What an answer found in Post #7(!):
http://f10.5post.com/forums/showthread.php?t=837796
Old 05-08-2013, 09:59 PM
Mein Auto: _
Wow! Got some bling on those FOB's. Now just bedazzle them and you will be all set.
Old 05-09-2013, 03:13 AM
Never thought of bedazzling them. But I need to bedazzle my seats as well to match the key fob
Old 07-07-2013, 05:18 PM
xkye77 xkye77 is offline
Mein Auto: 2003 BMW 735i
Hi there,
Is your BMW non comfort access? What is the battery model?
Panasonic VL2020? Vertical or horizontal?
Do you need programming after replacing the battery?
Thank you.
Old 07-09-2013, 07:00 PM
abbjax abbjax is offline
Mein Auto: 750i M Sport
I just went by the dealer for this tonight. Battery replaced and works fine w/comfort access. No reprogramming required. If the battery dies pull the metal key part out and use that to unlock the door manually. Hold the fob near the Start button and the car will turn on. It doesn't charge the battery in the fob- there's a chip or something that the car senses.
