Updated DIY for pre 2002 AUX IN
So I have searched everywhere for a way to add AUX IN on pre 2002 CD53 radios. Everything I read said it was impossible to do without a 80 dollar adapter. I don't like spending money on things I know I can do my self and I really don't like the word "impossible". So here it goes how to add an AUX in to a pre 2002 business radios
Tools you will need
1)Wide flat head screw driver for trim removal or putty knife
2)Phillips head for removing head unit
3)Set of jewelers screw driver
3) soldering iron
4)Solder
5) Most importantly very steady hands
6) 10MM socket and wrench or driver
7)hot glue gun
8)electrical tape
9) Male or female 3.5mm jack ( this was a Beta run for me so I used what I had a male 3.5)
10) Sand paper
11)Hot glue gun
1) Remove head unit from car there are several guides for this. It takes 5 minutes.
2) After removing the head unit find a clean flat work area.
3) Start by removing the three bronze screws on top use your jewelers screw driver
4) Pop off top cover
5) Remove the 2 screws holding on the face plate
6) Remove the 4 screws holding in the cd tray
7) Remove cd tray gently it should just pop out
8) Pop off face plate be very careful there are clips on the bottom also
9) Remove the 4 long screws in the heat sink on the side it should pop right off
10) Remove the screw on the support bracket pull it out
11) Remove the 10mm bolt on back of radio
12) Remove the screws that mount the board in and all remaining screws on the bottom
13) Carefully wiggle board out
14) Now that you have the board out flip ,it over and look at the pins where your cd player plugs into the breadboard it should be a black or grey connector .
15) You need to find the pins for L in R in And a G mine were the first 3 on the right.
16) I had blue protection adhesive over my connection lightly sand the pins you will be using
17) Prep you lead wire for your 3.5 jack by stripping 1/8 inch of insulation off the end of the red and green
18) Take you electrical tape and insulate your ground wire all but 1/8th inch on the tip
19) Tin your wires
20) Very carefully and I mean very carefully solder your green wire to the L channel pin then the red wire to the R channel pin and the Ground G DO NOT let solder flow to the other pins you will render your stereo useless.
21) Now that you're done with the hard part lat a piece of electrical tape over pins in front of where you soldered to help prevent shorts
22) Run your lead wire out through the closest vent hole and reassemble stereo
23) Now decide you much wire you will need and solder on your 3.5mm jack
24) Reinstall your stereo and put your aux in where ever you desire
25) Pop a cd in and put the stereo in cd mode now plug in your device and it will over ride the cd an there you have it AUX IN the hard way
Just remember to be extremely careful while doing this you could destroy your head unit. But with great risk comes great reward. Sorry i didn't take pics of taking apart the head unit apart.
