Old 05-09-2013, 08:48 PM
bad540i bad540i is offline
Mein Auto: 1998 BMW 540i
540i stalling problem!
Some times when i start my 540i it stalls after a couple of seconds. today it stalled while i was driving . i have just cleaned my MAF sensor and nothing has changed! how do i remove the idol control valve and clean it? And is it hard to do? or harder than cleaning the MAF sensor.
Old 05-09-2013, 11:19 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Actually, it's the "idle control valve."
Not difficult. The valve is under the engine cover, at the front of the intake manifold. It's an aluminum can about the size of a small juice can.
Unhook the plastic retainer, and carefully disconnect the hoses. Hose out the valve with brake cleaner. Properly cleaned, the valve shoud rattle when shaken. Examine the hoses to make sure they are not split.
Old 05-10-2013, 09:25 AM
borahatch borahatch is offline
Do you have a scanner? It could also be your cam position sensor starting to fail. I had a pending code for my CPS for months. One day, I started my car and it stalled within seconds. Ordered a new CPS (OEM only) and all is well.
1998 540i
Old 05-10-2013, 07:42 PM
Hey guys i did what people told me and cleaned the icv it was quite seized up and didnt clink. After cleaned it was moving freely. I placed the part back in and car is still stalling . Should i get my codes read and move to cam position sensor? how much are these oem?
Old 05-10-2013, 07:54 PM
Yes, get your car scanned. Takes out all the guess work. I picked up my CPS for $130 from an Indy BMW repair shop. You might be able to get it cheaper online. Just make sure you're getting a BMW part and not some knock-off.
1998 540i
Old 05-10-2013, 07:58 PM
Thank you ^^^
Old 05-10-2013, 08:32 PM
No problem. Let us know how things work out.
1998 540i
Old 05-15-2013, 12:06 AM
Hey guys i just bought a scanner although it isnt giving me a code it saying cam position sensor
What do io do ? does my car only have one cam position sensor? also it had a few more before i cleared them . One was hot film mass airflow sensor and another was cc continuous power supply! what do i do
Old 05-15-2013, 11:00 AM
it isnt giving me a code it saying cam position sensor If there's no code, how do you know?
There's only one CPS, and it's mounted to the front of the right side cylinder head.
Old 05-15-2013, 12:29 PM
To make things easy on you, here's a picture of the box my CPS came in. That's the part number you'll need. We have the same car.
[IMG][/IMG]
1998 540i
Old 05-15-2013, 01:58 PM
i mean its not giving me a p code haha its just saying 70 cam position sensor
