Excessive movement in drive-line - Bimmerfest - BMW Forums
Old 05-10-2013, 03:15 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
I think I know what cause my shudder during high speed braking. I just happened to notice the stick shift moved forward kind of excessive during hard braking, definitely not normal when compares to my other Bimmers.
The engine and tranny mounts have just been replaced last year. What do you guys think which components would cause such excessive movement in the drive-line?
Old 05-10-2013, 05:59 PM
Mason_E39 Mason_E39 is offline
Anti JDM
Mein Auto: 2001 BMW E39
Could be warped brake rotors or your balancing weights came off your wheels. Similar thing happened to me. I replaced rotors and balanced wheels, now its like driving on glass.
2001 BMW 530I
1968 Chevrolet Camaro
Old 05-10-2013, 06:07 PM
16valex's Avatar
Did you notice your stick shift kind move forward excessively when hard braking before you have resolved with rotors and balance?
Old 05-10-2013, 06:14 PM
Anti JDM
I have an auto so I wouldnt know. But one of those fixes cured my shutter in the car drastically. Because it use to feel like I was driving a civic but now Im driving my original Bimmer again haha.
2001 BMW 530I
Old 05-10-2013, 07:18 PM
16valex's Avatar
Maybe in your case it is but mine I can go 100 MPH and it's still smooth but as soon as I hit the brake while above 75 MPH it will start to shudder.
If your rotors and tires aren't balance you will get vibration even without hitting the brake at high speed.
Old 05-10-2013, 07:22 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
trust arm bushing ?
Old 05-10-2013, 07:33 PM
16valex's Avatar
Originally Posted by champaign777 View Post
trust arm bushing ?
In a normal case of shudder that is a good guess but in this case what do thrust arms have any thing to do with the drive-line move forward when brake is hit under high speed.
Old 05-10-2013, 07:39 PM
Elvis530i's Avatar
Elvis530i Elvis530i is offline
Stimulus Package
Mein Auto: 2002 530i
Who did your engine and tranny mounts? What did you replace them with? My first guess is something might have come loose. Brake judder alone shouldn't cause your driveline to shake.
2002 530i | Black/sand | Rondell Style 81s: 18x8.5 Front 18x10 Rear | Koni FSD | Eibach Pro-Kit | Zimmerman X-Drilled Rotors | Axxis Deluxe+ Brake Pads | StopTech SS Brake Lines | 50w 6000k Xenon Lows/LED Fogs/Phillips Luxeon LED DRLs | Angel i Brights v3.0 | Solaris Invisibulbs | Shadowline Trim | ///M5 Trunk Lip Spoiler | 35% Madico Tint | Dynavin D99+ ///M3Evolution | Backup camera | Intake Muffler, Front Plate, Badge & Cup/Coinholder Delete | Klasse AIO+SG
Old 05-10-2013, 08:05 PM
16valex's Avatar
I did them with OEM manufacture. And thanks for confirming that brake judder should effect my drive-line to move forward.
I plan to replace the CV and Center bearing, I think one of these is the culprit.
Old 05-11-2013, 06:24 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
FTW Trump 2020!
Mein Auto: 2001 540i/6
I bet the springs in the dual mass flywheel are shot. I swear mine are.
When your in stop and go traffic and your on the gas off the gass on the gas off the gas does it feel like the clutch is releasing jerking when you push the pedal?
I did motor motor and trans mounts, diff mounts, subframe to body mounts, , new d/s and c/v and still have this problem but there is nothing left to replace. I think the dualmass flywheel is slopping back and forth in my car. No idea if its original but a good excuse to go lwfw
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 05-11-2013, 06:45 AM
16valex's Avatar
Topaz, at 143K miles my clutch is still nice and smooth no complain whatsoever, it slips when I'm on it with S/C but there's no evidence of any kind of clunk.
Old 05-11-2013, 07:08 AM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
Where do you feel the shudder?
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 05-11-2013, 08:13 AM
16valex's Avatar
The whole car, only at high speed above 75 MPH though.
