White smoke after idle - Bimmerfest - BMW Forums
Old 04-27-2013, 10:41 AM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
For some reason the past 2 weeks I've been getting white smoke from my exhaust pipes when I let the car idle standing still for about 4 minutes or more in park or drive. It happens when I push the gas the first time after the idle session. When it drives it's fine I see nothing.
Only happens after a few minutes of idling I have cycled the fuel put in additives but still smoke. I have a little bit of surging and a tad of rough idle at times.
I am thinking it might be my CAM sensors but not really sure if they would produce smoke.
I have no service engine soon lights or codes. Seems as if when idling something accumulates somewhere then gets burned off after a few throttle pumps.
Any ideas????
Thanks team!!!
Sent Via iPhone using BimmerApp
Old 04-27-2013, 01:14 PM
HerbP HerbP is offline
If your CCV valves have not been changed, it might be time to change them. If they have been changed, it sounds like your valve seals might be starting to fail. There are lots of threads on the 7 series forum, discussing valve seal failures.
Old 04-27-2013, 01:45 PM
Nitrogen's Avatar
Hi Herb I have changed the CCV's a few months ago. As for the valve seals when they start going out you usually will see a white bluish smoke at first start of the day. Mine doesn't do that it never smokes only after the short stand still ..
Old 04-27-2013, 01:59 PM
The only other thing could be would be antifreeze entering the combustion chamber from a possible bad head gasket. Are you losing any coolant from the system?
Old 05-03-2013, 09:17 PM
Nitrogen's Avatar
im not losing any antifreeze. Still can't find the cause.
Old 05-11-2013, 01:15 PM
Nitrogen's Avatar
Hi Herb I am not losing any coolant from my system. It's very weird only does it when it stands at idle for a maybe 5 minutes or more then after the first puff blows away its fine again no more smoke till it sits again. Stopping at traffic lights it's fine never smokes, I even just had it smog/emission tested and they passed it fine. Only level that was a little high in the report was HydroCarbons. Still hunting, I don't think it's the valve seals as they would smoke much more and more often.
Old 05-11-2013, 06:08 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
Oh oh! That sounds like bad valve stem seals to me. Seen it on a 735i & that was the cause, also have a read of RusheyIRL's thread about his issue with white smoke at idle.
What does the smoke smell like after a while idling? Is it a choking smell like burning oil?
Old 05-11-2013, 06:40 PM
Nitrogen's Avatar
I know the smell your talking about but it's not the burning oil smell! Also oil will burn blueish not white the smell is hard to describe.
Old 05-12-2013, 12:35 AM
With the valve seals gone the oil will burn white, have a look at this video:
or this one:
or this:
finally this:
Old 05-12-2013, 11:23 AM
Nitrogen's Avatar
or this one:
or this:
finally this:
Hi Rebel thanks for the info, man that doesn't look good. I might have the same problem after watching that. I wonder if I should sell the car my valve covers are leaking too. Pain in the butt don't know if I should keep it and fix stuff or just get rid of it and start over. It has 131K miles on it and I think things will just get worst from here as far as repairs are concerned. Although I do all my own repairs on the car.
Old 05-12-2013, 11:51 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
In this situation the oil is coming out white because its being sucked in the exhaust valve.Oil is not being burnt in the combustion but rather by the cats and exhaust manifold.Suck in exhaust stroke pushed out with exhaust.Thats why its white,not burning hot enough to turn blue.
Old 05-13-2013, 01:14 PM
snapdapro snapdapro is offline
650I Rolln
Mein Auto: 650i convertible
this is something that happens with 650i. I JUST had 8k work done to mine and luckily I purchased the warranty and it was cover. your valve covers are bad and its leaking oil. i can forward you the invoice if you want to see all bmw el cajon fixed. took about 2 weeks, but depends on there workload.
me and my girlfriend...SUGA
Old 05-13-2013, 01:18 PM
Nitrogen's Avatar
If I had to pay 8k I would buy another car to drive around with and do the work on my 6er myself and take my time .
I have no warranty my car has 131k miles no company will give me a warranty!!!
Old 05-13-2013, 03:38 PM
If you are willing to do the work, I would go ahead & pull the motor. The valve seals can be replaced with the engine in the car, but it is probably a long 20 to 30 hours of pure aggravation. If you pull the heads, I think that you will need a special timing jig for reassembly? There is a thread on the 7 Series forum by Keif, that explains the repair.
A used motor might be found for 4 to 5k, but at that price I would build my own! The only damage that you can do by driving it as is, is possible damage to the cats. If you can make a trade without taking a beating, now would be the time to do it. Monitor the engine to see when it smoke the least, & take it to trade when it smokes the least.
Good Luck!
Old 05-13-2013, 09:24 PM
ferny ferny is offline
Mein Auto: 06' BMW 650i
The Warranty Group and CARCHEX will cover your car with those miles I believe. Call them and ask.
// 06 650i, aFe Intake, M310 Avant Garde Wheels
// M Driving School
Old 05-14-2013, 05:38 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Sorry to hear about your problems Nitrogen. It seems you love your ride and would like to keep it. I would suggest you try and repair it because a trade would kill you on the value with that problem. I figured you would lose just as much on the lost value, maybe even more, on a trade that you could use to fix the car. The cost of the seals are not that bad it's the labor cost that is going to be the problem. If you have a garage and handy with tools, you can pull it off yourself. Like others have said, it will take time but you can do it if you have the time to spare. And another good thing is you can replace all that you think needs replacing while you have it apart. Then you don't have to worry about certain issues for another 100K miles!
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 07-01-2014, 11:37 AM
GoGo98102 GoGo98102 is offline
Mein Auto: 06' 650i
I know this is an old thread but I bet people are still searching for info...
I had the exact same problem. Only smoke after a long idle but not first thing in the morning (typical symptoms of a leaking vale stem seals). BMW didn't know for sure what's wrong and quoted me an $8000 fix anyway. After googling and doing a lot of research, I found out that if you changed your oil to higher (5w 30 to 10w 40), it would stop oil from leaking into the engine. Because my car (06' 650i) can take up to 10w 60, I went to my BMW dealer and bought a case of them. Now 200 miles later, I have yet to see any smoke.
Obviously this is just a patch, not an $8000 fix but I can live with it.
06' 650i Coupe/Sports/Cold Weather/Premium Sound/Head Up
03' 325i
98' 540i
92' 318i Convertible
Old 07-01-2014, 04:32 PM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
Like GoGo said you might try a heavier oil as a temp fix. It might last a while but when that fails it will grenade quickly.
If all this is actually $8k to fix you might look into a new rebuilt engine (I have no idea what one would cost) or if your mechanically inclined pull the engine and rebuild the top half yourself and then you would be good to go for sometime.
+ Various Mods & Upgrades
Old 07-02-2014, 02:37 PM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
Or you can get the valve stem seal job done for $2500 (for those closer to the northeast).... Check out my threads
Old 07-07-2014, 04:44 PM
Bk650's Avatar
Bk650 Bk650 is offline
Nerdy G
Send a message via AIM to Bk650
Mein Auto: CLS 550
I can vouch for BMWOEM1 he did mine and saved me tons of money..
Greg A
650i on 22's Asanti, mtec v3 angel eyes, Custom exhaust...(retired)
2000 GS300 heavily modded(retired) gone but never forgotten
1998 LS400 Daily driver (retired)
2005 Range Rover HSE (family car) Lost in Divorce
Old 07-30-2014, 10:48 PM
Nitrogen's Avatar
Wow I changed my oil to 5-40 and no more smoke as well. Thanks for the easy fix. We will see how long it lasts but I think it will be good for a long time. If it doesn't just keep going with thicker oil.
Old 07-31-2014, 06:45 PM
It's hard to believe that going from 0w40 to 5w40, would make that big a difference? Good to know, we might all need it one day!
Old 08-04-2014, 03:22 PM
Nitrogen's Avatar
Ok so to recap, I did further testing and it still smokes. But it takes a really long time.
Before I would go through a car wash and at the end it would smoke like crazy. Also on long waits at traffic lights.
So Herb you are correct! But it is much better now it takes about 25minutes on idle to do anything. Which to me is no big deal if it gets worst again I will go thicker and thicker till it blows up LOL...
Old 10-14-2014, 12:03 PM
martininkent martininkent is offline
Mein Auto: 645ci
please explaine bmwoem1 if you would thanks
hi I am a engineer first then a technician, and top tech / master tech for Volvo and others for a long time, iam not questioning your diagnostics of the valve stem seals I totally understand that and I have bought the parts to do mine next week,, but just one thing I don't understand or can get my head around is why does it not do it on tickover ??, , the vacuum in the engine is there to balance the air induction on idle and move oil around, but why not when its idling, thanks
Old 10-14-2014, 04:53 PM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
I will absolutely be bringing mine to you if it ever happens to my car......
