Old 05-12-2013, 10:41 AM
gassy gassy is offline
BMW 7 Series Obsessed
Mein Auto: 2016 M4 Champagne Quartz
Is this a defective tire?
I replaced my stock runflats with Conti ExtremeContact DW tires 11,000 miles ago. Below, you can see that the left front tire (first image) is shot while the right front (second image) is fine. Inflation has been normal- in fact, when I started seeing increased wear on the outer edge, I bumped up my inflation by a few psi in hopes of arresting this advanced wear. My alignment is acceptable with a very slight pull to the left, but not distractingly so. Is this a defective tire?
ID:	376065   Click image for larger version
Old 05-12-2013, 10:43 AM
dagoo98's Avatar
dagoo98 dagoo98 is offline
Mein Auto: 2014 BMW 650xi Gran Coupe
Looks to me like an alignment issue or a faulty front end part. I would have the front end of the vehicle properly checked. If no faults are found I would find another alignment shop.
Old 05-12-2013, 02:00 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
you def. need an alignment judging by your comment that the car slightly pulls to the left. That could be indicative of the tire not sitting flat or staying proper. Or something is wrong with the control arms/suspension on the front left side and you should have it checked out! I highly suggest getting a new tire and then getting an alignment. Make sure whomever does the alignment gives you a printout of the before and after specs. Also while you are there you can have them reduce the camber in the rear of the car to increase mileage with a minimal impact in driving dynamics!
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 05-12-2013, 02:22 PM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
This is not intended to sound silly, if you have a staggered set-up, when you replaced, did they put the right sizes on the right ends?
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 05-12-2013, 04:23 PM
Snorlax Snorlax is offline
Mein Auto: _
Originally Posted by dagoo98 View Post
looks to me like an alignment issue or a faulty front end part. I would have the front end of the vehicle properly checked. If no faults are found i would find another alignment shop.
+1
Old 05-12-2013, 05:01 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
Also seems like you have some slight cupping... could be not only alignment, but as others have mentioned, a suspension problem (have them look for worn or bent pieces). Otherwise, the alignment shop needs to go and you should find someone else.
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 05-12-2013, 06:14 PM
Doktorek's Avatar
Doktorek Doktorek is offline
Mein Auto: 750 Li
if you didnt purchase road hazard - no warranty. Road hazard is worth every penny on any high end car.
2008 BMW 750 LI
2010 Panamera Turbo
Old 05-12-2013, 07:16 PM
aom aom is offline
Moderator
I always purchase certs from tirerack when buying new tires... Unfortunately, they will specifically exclude damage caused by bad alignment or suspension parts. Which this seem to be Unless he can get another kind of hazard warranty that would--- having it in this case wouldn't have made a difference for the OP. As this is very likely not a specific tire issue.
now, if happens to find a nail in the sidewall.. then that's a different story.
Old 05-13-2013, 10:41 AM
Yes, and it's not a silly question. Smaller ones in front.
