odd problem with battery connection. - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 05-02-2013, 11:46 PM
filnguyen filnguyen is offline
Mein Auto: 525i
i don't know exactly how to word it. car works and runs fine. but i notice when my car is at idle. the cluster, headlight and all the lighting inside of the car pulsates. was wondering if anyone has had this problem or know what it could possibly be? guessing i don't have a solid connection from my battery?
thanks
Old 05-03-2013, 01:54 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
sounds like battery, is it easy to start the car?
E30 above Sold
Last updated 2nd January 2014
Old 05-03-2013, 06:05 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Even though this is one of my weakest points, it could also be the alternator or the voltage regulator within the alternator. Do your headlights pulse? Do they get brighter when the engine is revved and dimmer when at idle?
I would recommend that you go by a local Auto Zone, Advance Auto, etc. and have them check the charging system. They can place a load on it and can give a better diagnosis than just a volt meter.
Good luck.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-03-2013, 06:25 AM
allenbee allenbee is offline
Banned
Mein Auto: 525
thanks
Alternator !
Step on the gas when you are at neutral. If the lights stabilise and get brighter, then its the alternator for sure.
You should get it tested anyway.
Old 05-03-2013, 09:03 AM
Mein Auto: 525i
Thanks guys for the tips I'll be sure to check on that when I get Into my car later. Right now don't feel like getting into a completely black car while the weather is rising to the 90's
Old 05-03-2013, 10:02 AM
The Ornery Old Man
Mein Auto: GTI
It could also just be the ICV not keeping the idle speed at the correct rpm when running so many acessories.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 05-13-2013, 12:55 AM
Mein Auto: 1989 525i M20B25
If the electronics are all really pulsating, then it is probably the voltage regulator in the alternator.
Figure out if your is replaceable or not.
Old 05-13-2013, 10:28 AM
Mein Auto: 525i
Thanks again for the tip. I notice even when I'm on the free driving all of the electronics is still pulsating. This fix is going to have to wait a big cause I'm about to get my car towed to the shop to fix the clutch master / slave cylinder.
Old 05-13-2013, 10:59 AM
PlasmaE34 PlasmaE34 is offline
Banned
Mein Auto: E34
Would be a very good idea to rebuild or replace your alternator at the same time. A bad alternator will eventually fail, flatten your battery, and leave you with a no start situation unexpectedly.
At least get the alternator tested.
Old 05-13-2013, 08:38 PM
Mein Auto: 525i
Hahaha funny how you said that cause when my slave cylinder gave out the pulley belt fell off due to a bad alternator even though my mechanic said it seemed like its been replaced recently before I bought the car. Just replaced the fly wheel and clutch last month which costed me $900 now replacing the alternator, pulley, belt, ac belt and slave cylinder. Oh well at least I got a killer deal on a new Bosch alternator and my car will be running smoothly
Hope all of this will fix my pulsating lights as well. Haha slowly I'm learning about my car. Haha
Old 05-27-2013, 05:33 PM
Mein Auto: 525i
just wanted to update this post incase anyone else is having problems. after replacing a new alternator and pulley bet it fixed my pulsating light problem.
