rough idle, power steering pump? - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 05-12-2013, 06:23 PM
5seriesman 5seriesman is offline
Mein Auto: 1991 bmw 525i 5 speed
I have a 95 BMW 540i, Anyhow went to start it up today and it was idling terribly, and when you turn the steering wheel the car wants to bog down and squeel extremely loud to were the neighbors are wandering what's going on lol it drives rough like it has no power I littlery had to stop at the end of my road it was si bad! Does it sound like my belts are going bad or my power steering pump? The car sounds like its missing, when you turn the wheel in both directions it will try to bog down and make a real bad squeeling sound! I mean the car sounds like complete sh$&26$!!! As you turn the wheel it feels like something is about to break! I need some help!
Old 05-12-2013, 08:02 PM
Bimmerfan84's Avatar
Bimmerfan84 Bimmerfan84 is offline
Mein Auto: 1998 528i
Any time you turn the wheel hard the power steering is pumping harder and therefore putting a load on the engine. So try this, instead of turning the wheel put the car in drive and keep your foot firmly on the brake. Hit the accelerator slowly while keeping your foot on the brake (this is putting a load on the engine as well) and see if it runs worse that way. If it does, you can suspect a coil and start inspecting them for cracks and testing to make sure they are firing. If not it may be something else. If you suspect a pulley may be frozen, with the car COLD remove the belts and start the car to see if it runs better (don't leave it running long without the belts on though because it will eventually overheat the engine and drain your battery)
Old 05-12-2013, 08:09 PM
I will try that thank you it just started doing it! I thought my power steering pump went out or my belts are worn out but the rough idle has got me confused I just don't understand I was running fine the last time I drove it.
Old 05-12-2013, 08:36 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
It was running fine the last time drove it.. hahahaha story of my life..
i got my 540 with a bad pump.. o man it sucked.. wheel was heavy ya but it like sticks in places and you gotta be ready muscle it when it does..
i did not have surges at idle but i have a MT and would be giving throttle/clutch while turning at low speed and not notice maybe..
Good luck
fck jdm / fck honda
Old 05-12-2013, 09:20 PM
Good luck
It honestly was lol then I was going on a Sunday stroll and I ran into this problem! One thing after another.
Old 05-12-2013, 10:44 PM
I have a feeling I gonna have fun changing this power steering pump lol
Old 05-12-2013, 10:55 PM
Resident e34 Racer
Actually no, its a pain in the ass.. Or maybe thats your idea of fun..? hahahah jk
im guessing a 525 is much easier than a 540i/530i so maybe its not so bad.. i can tell you if you have a 540i check or just do that motor mount while you are there.. maybe this apply's to you also?
its a pain to get too for us
fck jdm / fck honda
Old 05-12-2013, 11:32 PM
Ohh lord lol the last time I checked a new power steering pump was around 300 bucks lord lord lol I haven't looked into it hard enough to really say what's wring with it could be a 20 dollar fix to a 500 dollar fix I just hope for the best!
Old 05-12-2013, 11:35 PM
Your grill and power steering pump would look soooo good on my car and I don't like Honda's either so you artta just let me get that too lol
Old 05-12-2013, 11:46 PM
Resident e34 Racer
LKQ got me a used pump for 130$ fyi
Old 05-13-2013, 12:16 AM
Hell thatvaint to bad but still a chunk of change ill see what I can do actually I gotta do something lol
Old 05-13-2013, 12:23 AM
Yea Ill crawl under the beast in the morning and attempt to see what's wrong with it or act like I know what I'm doing and try to fix it so my ole lady will leave me alone knowing me ill get under their and fall asleep lol
Old 05-13-2013, 02:20 PM
I found out today that my power steering pump is still good! I probably pinched a line were my grille came off and went under the car cause it happened rite after that. My friend said the lines were made of metal and I probably pinched one! Were are they located and could this be what happens?
Old 05-14-2013, 02:13 PM
Re: rough idle, power steering pump?
Well I found out it wasn't my power steering pump its some kind of sensor the exaust has a very harsh gas smell the engine shakes the car at idle idk what sensor it is does anyone have a clue
Sent from my SAMSUNG-SGH-I997 using BimmerApp mobile app
Old 05-14-2013, 02:39 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Do the stomp test. Look in the stickies if you don't know what that is.
Most problems are usually something simple !
Originally Posted by noego View Post
It's Deja Poo - as in, I've heard this **** before.
Steve
Calypso Red 1992 525i with 225K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-14-2013, 02:53 PM
I did try that for some reason the check engine light isn't on idk if I has a blown bulb or what but is the stomp test were you turn the car on and stomp 5 times?
Old 05-14-2013, 03:00 PM
Turn the key on not the car!
Old 05-14-2013, 03:22 PM
BMR_LVR's Avatar
Humble E34 lover
Yeah. Did you check the sticky at the top? It has a link to the stomp test procedure and it also has a video of a person doing it.
You should be able to turn your key to position 2 (dash lights on, but not cranking car) and the CEL should be on. If it is not, then the bulb is likely burned out. If that is the case, then you need to get the car to someone who has an OBD I code scanner to pull any error codes.
Until you either do the stomp test or have the codes read, you are kind of pissing in the wind in trying to diagnose the problem. Certainly not trying to be a jerk about it, but people here can speculate to the nth degree and still not know what the problem is. You need to get a diagnosis before you can treat the disease.
BTW, I don't think that your rough running engine is related to the belt squealing. I suppose it's possible, but unlikely. Once you get the engine running correctly, you can address the belt issue.
Good luck.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-14-2013, 03:54 PM
BMWFatherFigure's Avatar
Old School
O2 sensor?
Current:
E38 Parts Car
Previous:
Old 05-14-2013, 04:01 PM
BMR_LVR's Avatar
Humble E34 lover
Originally Posted by BMWFatherFigure View Post
O2 sensor?
Yeah. He posted another thread correlating this to when his nose peice of his grill came off and he ran over it. O2 sensor was my though as well once he tied the two together.
BTW, good to hear from you again BMW FF. Where ya' been?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-14-2013, 05:03 PM
The o2 is the first thing I thought about or the mass air flow sensor, I think that's what it is that screws into the intake
Old 05-14-2013, 05:54 PM
Resident e34 Racer
Bad maf?
unplug it and drive, if the car like's it. its bad.. sometimes indicates a vacuum leak too tho
fck jdm / fck honda
