Emissions related check engine light ? - Bimmerfest - BMW Forums
Old 09-19-2012, 07:04 PM
Mr.BMW745li Mr.BMW745li is offline
Mr. 745li
Mein Auto: bmw
Exclamation Emissions related check engine light ?
Hello fellow BMW enthusiasts,
I Just got a SERVICE ENGINE SOON light. i checked my idrive and it said its a EMISSION RELATED FAULT. What does that mean?.....
Old 09-19-2012, 07:35 PM
Khabar Khabar is offline
Mein Auto: 745i 2005
need some repair more likely spark plugs or coil,but in cause you would feel the engine work differently, may be O2 sensor. hook it up to computer and read error codes u can do it at autozone for free if do not have your own
Old 09-19-2012, 07:47 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
Yup, Autozone can read the code and tell you what the problem is, or at least get close. It could be as simple as a loose gas cap.
Old 05-12-2013, 08:07 AM
minhvotx minhvotx is offline
Mein Auto: 2006 bmw 750li
Hi Mr.BMW745li,
Were you able to find out what the problem was and how to fix? My 2006 750li just has this same check engine message, looking for help. Don't really want to bring to the dealer.
Thanks.
Old 05-12-2013, 09:47 AM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Have autozone pull the code.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 05-12-2013, 07:40 PM
Will try that. Thanks.
Old 05-13-2013, 08:53 PM
Hi pmpn8ez,
Got my 2006 750LI to AutoZone today for scan, the code is P1434, and have the printed out message:
Troubleshooting P1434
OEM Band: Volkswagen
Definition: Secondary air injection relay circuit short to positive
Explanation: Open or short circuit condition
Probable cause: failed air pump relay
First, is this possible that this code is not accurate, the scanner was for Volkswagen only, did not work for BMW?
Second: I see a few post on this forum for this code P1434, and a few members saying that the problem was bad gas cap, but the code did not say anything about gas cap. Anyone esolved this problem code by replaced the gas cap?
Thanks,
Old 05-15-2013, 07:58 AM
Busarider Busarider is offline
Mein Auto: 745LI
Does'nt hurt to replace the gas cap first, it's the least expensive part. sometimes the rubber gasket around the cap tends to wear off and show sign of cracks which allows the fumes to escape. Check for these cracks.
Old 05-17-2013, 06:27 PM
Mr. 745li
Mein Auto: bmw
Hello....not yet...will take it to get read this weekend.
Old 05-17-2013, 07:48 PM
dommm dommm is offline
Mein Auto: 2011 550ix
[QUOTE=minhvotx;7582912]Hi pmpn8ez,
My engine light turned on awhile back & all I did was remove & then put back on the gas cap & made sure it was on tight (mine clicks) & the engine light went off after a half day of normal driving. gl
Old 05-25-2013, 06:42 AM
[QUOTE=dommm;7592415]
Originally Posted by minhvotx View Post
Hi pmpn8ez,
I checked my gas cap, looks good, and closed tight. Put it back carefully and waited a few days, but the code was not cleared. I will look for a new cap.
I also bought a OBDII bluetooth interface ELM327 from Amazon for $23 and use free Torque app for my Andoid phone to read the code. I do see code P1434 as what AutoZone got, but tried to reset, it did not clear. I was able to clear O2 sensor check engine on my Honda Odyssey, may be it just does not work on BMW.
Old 05-28-2013, 09:04 AM
May check engine light disappeared now, so it looks like the new gas cap works. just take too long to clear the code?
Old 05-28-2013, 09:26 AM
PRBMW7ser05's Avatar
PRBMW7ser05 PRBMW7ser05 is offline
745i Blk-Blk
Mein Auto: 2005 745i s
Just had the same fault pop up yesterday. My car is running great, so I'll take it by my indy to see whats up.
Old 05-31-2013, 09:36 AM
745i Blk-Blk
Mine ended up being thermostat fault. I replaced mine about 10k miles ago, so we just reset computer and I'll give a few days to see if it sticks again. I lucked out so far...
