Old 03-15-2013, 05:55 PM
occountin occountin is offline
Mein Auto: 7 series hopeful
Groaning sound from Front when turning
WHen I make a slow like U turn, I can sometimes here a groaning sound which seems like its coming from the front left or right suspension. Is that something to do with the self leveling suspension and maybe something leaking or worn out?
Is there a diagnostic to do to help diagnose the problem?
Thank you for the advise
Old 03-15-2013, 05:57 PM
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
Did you check your power steering fluid? It's the one with the green top to the right of the motor I believe. Also I believe self leveling suspension is only in the rear.
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
Old 03-15-2013, 06:05 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
+1 to this
If its full then change it if its low try and find a leak if that don't work then it could be other components but trying the fluid first wont hurt as it should be changed every few years at a bare minimum
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 03-15-2013, 06:50 PM
First_745Li's Avatar
Mein Auto: 2007 Audi A8
Maybe a flush would work, might have water in the lines.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 03-17-2013, 10:49 AM
Good thoughts. I should have mentioned that I did check the power steering fluid and it is at the top. The groaning sound is not so consistent that I can repeat it each and every time. I try some things in a open parking lot to see If I can consistently make it happen as Until I can demonstrate it to the technician I don't think Ill get anywhere with the a diagnosis from them. I think it happens with sharp turns under acceleration or with some speed.
Old 04-28-2013, 03:51 PM
Groaning Sound Fixed
The shop replaced the power steering fluid. He said the fluid seemed a dark color vs the bright green it should be. That did not seem to improve the groaning sound.
A few weeks later he did a flush, and used the diagnostics to control the hydraulic suspension which when running the diagnostic causes the car to alternately move up and down on each corner which has the result checking the auto leveling and also burping or bleeding any air out of the system.
After several days, I have not heard the groaning sound and I tried hard to make it happen. I think its fixed!.
Old 05-15-2013, 09:13 AM
Monaco&Barbera Monaco&Barbera is offline
Mein Auto: 2008 BMW 750Li
Mine does the same thing, only on low speed sharp turns such as u turns, parking etc. Do you have the sport package on yours? Idk how to get this solved as the BMW technician said they wouldn't do it under my CPO for some reason.
Range Rover Supercharged - Current
BMW 750i Monaco Blue w/ oyster interior.
BMW 750LI Sport Package Barbera Red w/Nat. Brown Interior-SOLD
Old 06-02-2013, 12:40 PM
Sound like exactly the same problem. Mine happened on low speed turns just as you described. Yes I have the sports package. Some CPO arent very good and might not cover but its not too expensive to have done. I would take care of it on your own. They can do it while you wait. I think the secret is to run the diagnostic where they move the suspension upa nd down to burp the system. I just have my fluid changed and that did not fix it. But after he ran the suspension software that made the corners move it has worked find for a couple months now. No groan!
Old 06-02-2013, 12:51 PM
Thanks for the advice as I would love to get this fixed. It doesnt happen all the time but is annoying when it does. My car goes in in 4400 miles so I will have them preform the software test then. Glad you posted and found a solution! Great contribution to the board.
