Old 03-12-2012, 04:42 PM
bkdave2atl bkdave2atl is offline
Send a message via AIM to bkdave2atl
Mein Auto: 745i
HELP!! Code P1434
My bimmer brothaz my engine light came on, not sure what to do. Just came back from autozone who gave me the error code. Definition "secondary air injection pump relay circuit short to positive"
Explanation "open or short circuit condition probable cause"
Failed air pump relay. Is this something I need to worry about, is it a big job? My car is running fine, but that light irritates me. Any help is always appreciated, this forum never lets me down.
Old 03-12-2012, 04:45 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i
Sounds like your air pump is bad. I'll wait for other to comment. But it can be a DIY job!
Old 03-12-2012, 04:52 PM
Mein Auto: 745i
Thanks Kins29, I hope
Old 03-12-2012, 05:19 PM
Also, the air pump only turns on when you first start you car to help the engine heat up. So you are "safe" to drive it. But I wouldn't leave it broken forever.
Old 03-12-2012, 07:12 PM
Mein Auto: 745i
Exactly, I want to fix this ASAP
Old 03-13-2012, 09:28 AM
Mein Auto: 745i
i just pulled up the codes list and P1434 is not listed?? any opinions fellas?
P1432 Secondary Air Injection System Incorrect Flow Detected
P1438 Purge Control Valve Control Open Circuit
P1439 Purge Control Valve Control Circuit Signal Low
P1440 Purge Control Valve Control Circuit Signal High
P1441 Leakage Diagnostic Pump Control Open Circuit
P1442 Leakage Diagnostic Pump Control Circuit Signal Low
P1443 Leakage Diagnostic Pump Control Circuit Signal High
P1444 Diagnostic Module Tank Leakage (DM-TL) Pump Control Open Circuit
P1445 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low
P1446 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal High
P1447 Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching
P1448 Diagnostic Module Tank Leakage (DM-TL) Pump Too Low During Switching
P1449 Diagnostic Module Tank Leakage (DM-TL) Pump Too High
P1450 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Open Circuit
P1451 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low
P1452 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High
P1453 Secondary Air Injection Pump Relay Control Circuit Electrical
P1454 Secondary Air Injection Pump With Series Resistor Control Circuit Electrical
Old 03-13-2012, 09:41 AM
ShoNuff745i ShoNuff745i is offline
ShoNuff745i
Mein Auto: 2004 745i
l
I'm sorry cant help at all with the code, but will say this: Sometimes the code readers that AutoZone and Advance Auto uses CAN give codes that arent part of the manufacturer's codes.(dont know why)I've experienced this firsthand with other cars, not my Bimmer, yet. (fangas crossed).
Old 03-13-2012, 09:44 AM
Mein Auto: 745i
thanks Nuff.....i'm still searching
Old 03-13-2012, 10:00 AM
ShoNuff745i
Yo bkdave2atl, I've Googled this, see if it helps especially check out the response from or_550i about 3/4 down on page 2! Hope this helps!
http://forums.5series.net/topic/6926...or-code-p1434/
Old 03-13-2012, 10:14 AM
Mein Auto: 745i
thanks bro, i appreciate your help, i'll check it out
Old 05-14-2012, 05:34 PM
Pdux72's Avatar
Pdux72 Pdux72 is offline
Mein Auto: 05' BMW 745i,
Hey bkdave,
Did you find the culprit to this code.. i just had this pop up...
Old 05-15-2012, 06:25 AM
Mein Auto: 745i
Old 05-15-2012, 09:09 AM
Mein Auto: 745i
Originally Posted by Pdux72 View Post
Hey bkdave,
Pdux it turned out I just needed to buy a new gas cap, the first place I had the code read was at autozone which read my car as being a Volkswagen (crazy) and gave me the secondary air pump fuse malfunction, then I went to car quest and had it read again, that machine said I had a massive leak in the gas tank. The dude said change ur gas cap, I did and haven't had a problem since.
Old 05-15-2012, 09:16 AM
Pdux72's Avatar
Thanks bkdave,
I really hope thats the deal cuase looking up some other potential issues it could be didnt look fun.. something about the DMTL... Just have never seen anyone on here have this code before... Im sure the cap would be the cheapest start..
Sent from my EVO using Bimmer App
Old 05-15-2012, 09:22 AM
Mein Auto: 745i
Thanks bkdave,
good luck i had the same feeling and didnt like what i was coming across either. thank God it was just the cap.
Old 05-15-2012, 09:34 AM
Pdux72's Avatar
Thanks!
Real quick. Did the alarm go away on its own or did you have to clear it after you put the new cap on....?
Old 05-15-2012, 10:33 AM
Mein Auto: 745i
Thanks!
the mechanic said it would go away (clear itself) after 10 starts, but i had it cleared because i had the valve cover gaskets and water pump change before i got to 10 starts.
Old 05-15-2013, 11:37 AM
minhvotx minhvotx is offline
Mein Auto: 2006 bmw 750li
Thanks for the post.
I took my 2006 750li to AutoZone and got same P1434 code/msgs. Will change the gas cap and wait a few days to see if the check engine light goes away.
Thanks.
Old 05-15-2013, 01:29 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Thanks.
Takes a day or two for the light to go away after replacing gas cap.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 05-28-2013, 09:08 AM
Replaced the gas cap, my check engine light disappeared after about a week. May be cause I did not drive much for that week.
