Codes??? - Bimmerfest - BMW Forums
Old 05-15-2013, 03:21 PM
taylorrmj taylorrmj is offline
Mein Auto: 2007 750i
Codes???
I have a 07 750i how do you check your fault codes and where are they located thanks.
Old 05-15-2013, 03:50 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Codes???
to check fault codes you will need a bmw specific scanner to find anything other than service engine soon diagnostic trouble codes. there is an obd2 port on the underside of your driver side dash panel. if i recall correctly it even has small letters on it that reads OBD2. if you need to check a service engine soon light you can use any generic obd2 scan tool to get the code numbers, but the description given by those will be extremely generic. auto zone, pep boys and advanced auto parts will all read check engine/service engine soon lights for free.
if you did not know most of what i said above already, good chance you wont be buying the bmw diagnostic hardware and software yourself and you will need a good bmw independent mechanic or a trip to the dealer to tell you what is wrong if it is another computer module other than the engine that you want to see the codes from.
good luck. you should be a bit more specific as to what exactly you are referring to as an fyi for the future; or atleast do some basic research
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 08-21-2013, 09:42 PM
Monaco&Barbera Monaco&Barbera is offline
Mein Auto: 2008 BMW 750Li
I could be wrong but cant you check fault history by accessing the "secret" service menu? Hold down the trip reset button and when you see the screen pop up with list keep hitting the trip button until you get to unlocking. Then the unlock code is the last 5 digits of vin added together. EX. on of my bmw's was code 19. After that then scroll to the fault history and hold the trip button down and the list should appear in right side screen in tachometer.
Range Rover Supercharged - Current
BMW 750i Monaco Blue w/ oyster interior.
BMW 750LI Sport Package Barbera Red w/Nat. Brown Interior-SOLD
