Old 05-12-2013, 01:15 PM
jajja jajja is offline
Mein Auto: 750li F02
F02 M Sport Package - is it wired for fogs?
does anyone know if the F02 M sport package (front bumper) is wired for fog lights?
Old 05-15-2013, 04:48 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
Nope... No wires and the control module for the fogs lacks the correct pins. Also has to be recoded once that's corrected so car recognizes output. The euro switch with front and rear fog controls is however just plug & play.
I had mine custom installed...
Note functional dash indicators for front/rear fogs
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 05-15-2013, 07:05 PM
Attachment 376674
Attachment 376675
sent you a PM, can you outline what it took for you to do it? also is there mounts for the fogs because the front bumper doesnt seem to fit them.. or does it?
2011 BMW 750Li - Coded, Rear Entertainment, M Sport, LED Lighting, ACS Trunk & Roof Spoiler, Tint, //M Pedals, iForge 22's, Conti CS2 Tires, EBC Dimpled Rotors and Red Stuff Pads. M Sticker on Steering (lol) & a ton of paint work to accent the Alpinweiss body & Jet Black trim pieces. The Ultimate Storm Trooper Driving Machine.
Old 05-16-2013, 07:00 AM
RocknDoc
The module that feeds power to the driving lights and controls them is missing the appropriate pins which had to be added. Then the module had to be recoded to enable the fog light output. This can be done by a knowledgeable BMW mechanic as they have the coding ability since we have two different models of 7 in the US... M-Sport without and regular with fog lights. Then add the Euro headlight switch which also enables the rear fogs. From there you just wire in the lights. I used the following;
http://www.autoanything.com/lights/77A1332A476002.aspx
The mounts are perfect for the far edges of the bumper support. You will remove the bracket on the lights and flip it upside down to mount inverted.
Then you have to customize the grille covers for the lights. It's a bit of work but necessary if you want a clean instal and factory functionality...
One other thing... the HID bulbs that come with this kit are a bit blue ~ 8500K so I replaced them with 6000K HID's to match the other lights.
