Old 05-15-2013, 06:19 PM
Rob13567 Rob13567 is offline
Mein Auto: 2000 528i
Question what's this leak
I found this leak or spill and I tried looking it up, found nothing
Please help?
Old 05-15-2013, 07:31 PM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
Can't really tell, but it's most likely either the water pump or thermostat leaking. While you are in there replace both.
Old 05-16-2013, 07:41 AM
Is it Really? this is on the passenger side of the engine thought the thermostat was in the front of the engine?
Old 05-16-2013, 07:43 AM
tmvE39/E53/Z32's Avatar
I can't tell where the leak is in your pic.
Old 05-16-2013, 08:14 AM
Fudman's Avatar
Fudman Fudman is offline
You need to put an arrow on your picture to better describe the location. You also need to better define the fluid that you have discovered. Color, consistency (oily or watery), smell, etc. Without additional detail, we cannot assist or it would be a WAG.
Old 05-16-2013, 08:17 AM
rdl rdl is offline
Mein Auto: 530i 2003
I too, cannot see a leak.
However, if the red arrows point at the leaks, it's the expansion tank.
If the yellow arrows, the lower rad hose. The electrical sensor in the lower rad hose is the radiator outlet temp sensor used to control the electric auxillary fan in front of the rad and A/C condenser.
Regards
RDL
Old 05-16-2013, 01:16 PM
dtadrian's Avatar
dtadrian dtadrian is offline
BMW's are like women. $$$
Mein Auto: 1994 540i
what's this leak
Get a white paper towel and clean some off. Also touch it and smell it. When engine cold wipe you hand under the vanos unit. Let us know what you find
1999 528iT Sold
1994 540i Toy
2014 Jetta Turbo APR stage 1 daily driver.. FUN!
Old 05-16-2013, 01:58 PM
Truly sorry guys did not realize it was a bad pic
I took two more to show the leak, one far away and one close up with arrows
To make sure
ID:	376840   Click image for larger version
Name:	Leak close up_01-1.jpg
Old 05-16-2013, 02:05 PM
chemist chemist is offline
Mein Auto: e39 530i
valve cover gasket leak
mine made mess in that area
Old 05-16-2013, 02:13 PM
dtadrian's Avatar
what's this leak
Could be VCG leak or vanos leaking. Get a mirror and look. Maybe get brake cleaner and clean area and check it daily to confirm location of leak
1999 528iT Sold
1994 540i Toy
Old 05-16-2013, 03:01 PM
Fudman's Avatar
Rub a clean paper towel under the edge of the VC rim. If it comes up oily, that's your leak: valve cover gasket.
see beisansystems.com for the DIY fix. ~ $40 for the part. You may want to consider replacing your Vanos seals since you are half way there. Do a search for why.
Old 05-16-2013, 03:22 PM
Jim Rolando Jim Rolando is offline
Mein Auto: 1999 528i
That's where my VCG was leaking. Once that far repairing it I decided to also changed the VANOS seals.
leak spill
