Removing X3 Headliner? - Bimmerfest - BMW Forums
Old 05-28-2010, 10:37 AM
mr.physics mr.physics is offline
Mein Auto: X3
How hard is it? I have the dreaded roof rail corrosion and am considering removing and repainting the rack myself.
How big a deal is taking out the headliner? I can see that the OH console, mirrors, grabs, etc all need to be detached, and the trim on the pillars removed.
Anyone done it? How long should I budget? (competent amateur mechanic, and i want it to go back together correctly.
Thanks for any help. I have searched for DIYs but haven't found any.
Greg
Ottawa, Canada
Old 05-30-2010, 07:52 AM
John320 John320 is offline
Mein Auto: 2017 X1
Hi Greg , I know I have seen a couple of people have done this, and had hoped they could give you a time frame…I haven’t … but I can send you the instructions if you wish ( just too large to post it all here )
So send me a private msg. with your email if you are interested, and I’ll try and get it off to you..
This looks like a fun but time consuming job. It includes removal of; both sun visors & supports, all handles, all trim panels from all pillar’s, trims, & all ceiling lights…
Also, tell me if you don’t have the panorama sunroof
John
Old 05-15-2011, 10:57 AM
lewis291 lewis291 is offline
Mein Auto: 2007 X3
The rear panel on the panoramic sunroof jammed open on my wife's E83. Could use the same info to remove the headliner - sending you a private message to that effect as well if you still have those instructions available.
Josh
Old 05-15-2011, 11:33 PM
whiterasta whiterasta is offline
Mein Auto: 2004 x3 2.5 premium/sport
Greg,
I'm in Ottawa as well and I am looking to remove mine. My mechanic said that it would be a couple hour job. So I'm assuming around $200 to have them removed.
If you happen to get it done prior to me let me know. I have that rust as well. I'm looking at taking them off and leaving them off.
Brian
Old 06-02-2011, 10:30 AM
relsah relsah is offline
Mein Auto: Ordered X3 2.5
do you guys still have the instruction on how to remove the headliner?
thanks
Old 06-02-2011, 10:19 PM
klaus_cluj klaus_cluj is offline
Mein Auto: x3
...and,in addition,with the roof rails installation? thank you
Old 04-25-2012, 08:14 PM
td04X3 td04X3 is offline
Mein Auto: 2004 X3
Hi John,
New to the forum, but wondering if you still had a copy of the directions to remove the headliner. Have had some nasty issues with the pano-roof and would like to get access to the track.
Really appreciate any help,
Tyler
Old 04-26-2012, 06:57 AM
Mein Auto: 2017 X1
Hi Tyler, p/msg received & sent you what I have...good luck, John
Old 04-29-2012, 01:48 PM
jdeday's Avatar
jdeday jdeday is offline
Send a message via AIM to jdeday
Mein Auto: 2005 BMW X3 3.0
http://tis.spaghetticoder.org/s/view.pl?1/09/24/55
Check this web site out for instructions.
Good luck.
Jeff
2005 X3 3.0, Mystic Blue Metallic, Sand Beige Leather Interior, Birch Grain Light Wood Trim, Steptronic Transmission, Premium Package, Heated Seats, Privacy Glass, Satellite Radio Prep, Xenon Adaptive Headlights, Heated Steering Wheel, Premium Sound, Power Folding Mirrors and NAVIGATION RETROFIT
Old 08-21-2012, 02:58 AM
dwarvenlordking dwarvenlordking is offline
Mein Auto: m6
Front Head liner
Says you can't remove the front head restraints/rests, but there must be a way? Anyone done this, if so thoughts?
Old 04-21-2013, 07:05 PM
brunke brunke is offline
Mein Auto: 08 X3, 08 Harley FLSTC
headliner
Please send me the headliner removal instructions also
Old 04-21-2013, 07:13 PM
rmerkushen rmerkushen is offline
Mein Auto: E90 330i, E83 X3si
It's not very difficult.. I removed rear to get access to shark fin, all pilar covers have to come off. There are two screws holding each of oh sit handles, with each screw hidden with a snap in cover. Those things were a bit of a pain, but once you get first one out, it is simple. There is usually a Torx screw behind Srs bracket. Take your time, it can be removed in under 2 hours..
Old 05-17-2013, 11:41 AM
Lartslock Lartslock is offline
Mein Auto: BMW x3
Headliner instructions
Hi,
The instructions would be most helpful.
Jak
Old 10-23-2013, 08:57 AM
markdm721 markdm721 is offline
Mein Auto: 2004 X3 e83
My sunshade is jammed open (panoramic sunroof doesn't work at all, which I knew when I bought the X3). Will removing the headliner allow me to pull the sunshade forward manually?
Old 10-23-2013, 10:24 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
timing
took out an 04 in~90 mins ....lots of plastic clips need a firm yank just like pulling the bench on the rear seat.....most important thing was an assistant .....when it comes free it's a bit of a large boat sail BUT quite rigid .....just need a good pal to help slide it out so it doesn't get soiled or dinged....be ready with a nice clean spot to lay it down
also ....check the pano roof rear drain lines while at it .....both of these were kinked at about elbow height on a six footer at the rear door .......an electricians fish tape works well to snake down the drain lines for and aft
also ....if the kinks won't stay out you can cut the plastic line either side of the kink and work in a pvc sleeve to provide a full diameter path to drain
Old 10-23-2013, 06:34 PM
metalicgreen318 metalicgreen318 is offline
Mein Auto: 1994 318is
Back half of my shade just jammed back there. Wondering if it can be pulled out manually.
2007 BMW X3
Old 10-24-2013, 02:57 PM
KingJ KingJ is offline
Mein Auto: 2004 X3 3.0i
Hey John, you still got those instructions? Roof rack is corroding on me now, I'd appreciate some instruction on how to remove the headliner
2004 X3 3.0i
Old 10-29-2013, 08:17 PM
Kit Fox Kit Fox is offline
Ditto please.
Old 10-30-2013, 06:16 AM
Mein Auto: 2017 X1
Yes, send me a P/M with email and I'll get on it
Old 11-03-2015, 03:35 PM
Elio Elio is offline
Mein Auto: X3
Hi John, You still have the instructions to remove the X3 headliner? I'd appreciate if you can send me those instructions. elioguerinoni@hotmail.com
Old 11-03-2015, 06:53 PM
good FEST headliner/sun shade links
http://www.xoutpost.com/bmw-sav-foru...tml#post891776
http://www.bimmerfest.com/forums/sho...0&goto=newpost
Old 05-22-2016, 01:01 PM
2009x3 2009x3 is offline
Mein Auto: '09 X3, '04 525i
Headliner Removal
Hi, i have an '09 X3 and need to remove my head liner to install a sun roof repair kit.
Are thoese instructions still available?
Old 05-22-2016, 01:04 PM
FESTCHIVE PANO ROOF and sunshades links
best wishes
http://www.bimmerfest.com/forums/sho...61#post9643561
Old 05-22-2016, 02:35 PM
Thanks for the quick reply, much appreciated.
Old 03-22-2017, 08:29 AM
pakodogs pakodogs is offline
Mein Auto: x3
E83 Headliner removal?
The little rubber gaskets on my front roof rails are sliding out. Are the instructions for the headliner removal still available?
