Old 05-18-2013, 01:04 PM
tlim66 tlim66 is offline
Mein Auto: BMW X5 35d
Comfort Access Key Placement
When going on a road trip I like to carry my second key with me in case of a mishap with my first key. I read the manual about leaving the second key and he it does not activate if locked with first etc... My question is where is a good place to 'hide' my second key so it s safe and does not interfere with settings and trunk closure etc.... Thanks
Old 05-18-2013, 10:51 PM
philooo philooo is offline
Mein Auto: 2011 X5 5.0
if you want to hide the key, I'd say simply pop the battery and switch ti upside down... should be deactivated and easy to reactivate when needed.
'11 X5 50i M-Sport
19" Black Saphire | Black | Alu | Lux Seat | Adaptive | Cold | Tech | Sound | Prem | Comf Acces | combox retrofit | Invisihitch oem harness
Old 05-18-2013, 11:21 PM
Could leaving the battery out for a length of time cause the key to become inactive?
Old 05-19-2013, 12:12 AM
ard ard is offline
Resident Curmudgeon
I seem to recall reading in the tech doc that if a second key is in the car when the primary key locks the car, the car ignores that second key. if youi look for the pdf on comfort access, here or over on xoutpost, or google, yoiu will see this common occurnace has been designed into the system. Again, my recollection. Okay, Okay... i found it... http://www.bmwmotorsports.org/pdf/e7...t%20Access.pdf
page 17
Now, if you wanted to prevent the key from interfering, place it in a metal tin. Like an empty mint box or something.
Old 05-21-2013, 08:29 PM
Yellowm3 Yellowm3 is offline
Mein Auto: BMW
From my personal experience, if the 2nd key is in the car (say in the middle box in between the front seats...what's that called?) and you lock the car with the 1st key, it ignores the 2nd key. Sometimes this is a real pain in the butt but I think the problem is more that hubby leaves his key in there.
My Alpine White Collection:
ISO '13 E70 35d or F15 xDrive (no 5.0)
'13 X5 35d (totaled by insurance due to unleaded contamination)
'87 325is (track car)
'08 X5 4.8si (sold)
'01 325iT (sold)
'93 325is (sold-only black car I've ever owned)
'87 325is (sold)
Old 05-21-2013, 09:00 PM
JohnMN JohnMN is offline
Mein Auto: X5 35d, S4, V50 T5
Assuming your concern is losing your first key, what good is locking the second key inside the car going to do?
Old 05-21-2013, 09:28 PM
Mein Auto: BMW
Good point.
I'm assuming perhaps a remote unlock via assist?
'08 X5 4.8si (sold)
'01 325iT (sold)
'87 325is (sold)
Old 05-22-2013, 12:38 PM
When traveling, if something happens to the first key like getting lost or broken, it is nice to have a second one. Most tow truck drivers can get you into the car...
Now if the second key gets deactivated when locked with the first, will that second key even work if the first key used to lock the door even work???
Around town I would just leave the key at home.
