Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 05-17-2013, 11:06 AM
selole selole is offline
Mein Auto: BMW 328IS
[question] Will these rims fit ?
So i was looking at getting some rims for my 328is coupe e36. Im looking at a pair of 17" m3 rims,(The 67 style ones) and was wondering if one of you wheel experts, could let me know if they would fit on my car. (without having to do a lip roll or camber thanks) . (Stock suspension)
Details
225/45R17 and a 47mm offset (Tire size used from previous owner)
1996 328is coupe
Old 05-18-2013, 10:04 AM
LMC's Avatar
LMC LMC is offline
Mein Auto: M3 & X3
OE BMW style 67 rims are 18-inchers fitted to the E46 M3. 225/45R-18 tires in front etc.
E36 M3s used 17-inchers with a 41mm offset and 225/45R-17 in front.
Plus there were all sort of replica wheels made for both those M3 generations, so it is a little hard to know exactly what you've got there...
If it really is a set of genuine OE M3 wheels -- 7.5 inch wide in front, 8.5 inch wide in rear with 41 offset F & R,I don't think those wider rears will fit. But four front wheels will.
Larry
BMW CCA #115780
'14 X3 35i M sport
'17 M3
Old 05-18-2013, 10:14 AM
Thanks for the info, im gunna go try them on today and see what happens. Will post back with the answer.
1996 328is coupe
Old 05-18-2013, 03:51 PM
Fit like a charm. Biggest wheels fit the back no problem, 8.5" is the max though still could have fit another inch in diameter but ill just lower the car a bit.
1996 328is coupe
Old 05-19-2013, 10:46 PM
1996 328is coupe
