Z4 HELP-New Starter Still No Crank - Bimmerfest - BMW Forums
Old 05-19-2013, 02:12 PM
r768 r768 is offline
Mein Auto: Z4
Hi All,
I have a 2008 Z4 that will not crank over and I need a little help. First thought was the battery, but that tested good. Voltage drop to the started is good. Pulled the solenoid wire and tested with meter and had 12+v when the key is turned to start. Must be the starter. Replaced the starter and the engine started once. Turned it off and tryed a again, no start. Checked connections, all ok. Tested solenoind wire, 12v with meter. Tested again with test light, and found the light will not light! Ran a jump wire, 12v to solenoid term and engine cranks fine. Wiring info I got from Mitchell shows the wiring going to an Integrated Supply Module. I'm not sure how to test the module system. Hoping someone will have info on the issue.
Any help will be most appreciated
Thank,
Rick
Old 05-20-2013, 06:16 AM
wifesauto wifesauto is offline
Mein Auto: sloporsche
just the usual help..........check park/neutral switch if auto. check clutch switch if stick and ignition switch. anti theft module ?
Old 05-20-2013, 11:10 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
I do not know if this will help but, I have heard the positive cable that runs from the batt will go bad on some Z4's. Good luck !
Old 05-20-2013, 09:08 PM
Mein Auto: Z4
Thanks for the replies!
I could not find any good info on testing the control module circuits. Sent it to the dealer today.
Old 05-21-2013, 07:25 AM
let us know what it was please
