Old 05-18-2013, 10:00 AM
Ramjamslam Ramjamslam is offline
Mein Auto: F02
Any coding expert here? I could use some help with E-Sys install
I posted this in the Coding forum as well. Hoping someone here can shed the light on my problem...
I have used the instructions posted by April1, and I am having difficulty launching "ZGW_SEARCH.exe".
I keep getting the error shown in the attached pictures.
I have also checked the network adapter settings and it seems to be set on "Obtain IP address automatically".
Any suggestions/help appreciated.
ID:	377168   Click image for larger version
ID:	377169   Click image for larger version
Old 05-18-2013, 10:58 AM
Wolfman64 Wolfman64 is offline
Mein Auto: 750li, S550, SL550, ML350
I have coded my car and never even used ZGW_SEARCH.exe. What it is for? Can you launch the actual esys app?
If so, what do you see when you press the connect button?
Old 05-18-2013, 12:43 PM
Mein Auto: F02
It's part of the E-Sys install procedure.
Can you PM info on how you connect to your car? Thanks.
Old 05-18-2013, 01:24 PM
Snorlax Snorlax is offline
Mein Auto: _
Is this installed on a 64-bit system? I am pretty sure it needs to be a 32-bit OS. My win 7 64-bit gives the same error. My 32-bit win XP works flawlessly. That program is just a test to see if it connects to the car. I think you can still use e-sys as that is a totally different program.
Old 05-18-2013, 02:08 PM
I am using Windows 7 64bit Ultimate and it works perfect. I am, however, using it via Parallels on a MacBook Air.
Old 05-18-2013, 02:52 PM
Mein Auto: F02
Thanks. I am gonna give it a try and report back.
Wish I kept my old IBM Win XP laptop.
Old 05-18-2013, 03:27 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
Try this:
http://support.microsoft.com/kb/900634
Make sure you install the files under "admin" and not "user" mode in win7.
2011 750i
Old 05-18-2013, 06:34 PM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: F80 M3
Correct, you do not need it at all to code your vehicle and it does not work in 64 bit environments (it may not work on anything besides XP, I haven't tested Win7 32 bit, etc).
Old 05-20-2013, 03:04 PM
Mein Auto: F02
@rajeek, Wolfman64 and Triple_0
I have ignored the ZGW_SEARCH.exe part (as you guys mentioned "it's only functional") and went ahead and hit Connect via E-Sys.
"Connect" button does not seem to "gray-out" to allow selection for next step. I have attached pics. Am I missing something?
Thanks,
Ramesh
Old 05-20-2013, 09:51 PM
For what I can see is that the the PC's connections works as it can read the cars VIN and allows the selection.
I don't see any car models listed in the target section where you normally select the car-specific files F01, F10, etc..
Once you have the car-specific file selected you should be able to continue...
Perhaps the directory to the data is not setup correctly? Check the stickies in the coding forum. I remember having the change directories from default...
Good luck!
Old 05-20-2013, 10:07 PM
OOO
Mein Auto: F80 M3
Yeah, it looks like your psdzdata files are not configured properly (in the correct folder). Have you downloaded the psdzdata files? Do you have your directory set as C:\ESysData
Old 05-20-2013, 10:12 PM
This is how it should look like. I am not hooked up, so the VIN doesn't show like yours. That is also the Target file you should use...
Name:	esys connect pic.png
