Old 05-20-2013, 09:57 AM
acidball acidball is offline
Mein Auto: F10
E-Sys 3.22.5
Hi Shawn!
Is it possible to change vin nr by e-sys in my f10, because i bought a used emf and i have a problem. I would be grateful if u send me a solution and "how to" make a working 3.22.5 and 49.1
Old 05-20-2013, 10:15 AM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by acidball View Post
Hi Shawn!
You would need to flash the firmware on used ECU to write VIN to it. Problem is, to flash, you need to know the I-Level Shipment of the Donor Car, other wise E-Sys won't properly know which ECU Part Number it is dealing with.
Old 05-20-2013, 11:56 AM
Mein Auto: F10
esys 3.22.5
Hi shawn!
There`s a possibility that the ecu was "cleard" inside the eeprom does it change the matter? but i think it was done by changing vin to "000000000000000" and that`s all. I think i will see in e-sys what`s up with this ecu. Can you give me some advices, i can go to bmw dealr as well but i don`t know the history of last vin number and there`s a problem because dealer contacts nypd immediatly if there`S a problem. Can u send me links to working esys and psdz and est. by the way everything works fine with the brake but the yellow icon blinks about the parking brake fault.
Old 05-20-2013, 01:54 PM
Hi shawn!
If the ECU EEPROM VIN has been blanked, which is usually not the case, then it should just require injecting CAFD and VO Coding ECU. During the VO Coding, VIN will be written.
Old 05-20-2013, 10:12 PM
Mein Auto: F10
esys 3.22.5
Hi shawn
That looks possible. Can you pleasese pm me a working version for my 2011 f10 would be grateful.
Regards,
Greg
Old 05-20-2013, 10:15 PM
Hi shawn
That looks possible. Can ypmleasese pm me pm a working version for my 2011 f10 would be grateful.
Regards,
Greg
PM sent.
Old 05-21-2013, 05:38 PM
Tnhl1989 Tnhl1989 is offline
Account Under Review
Mein Auto: BMW 330XI
Could you pm me the info ?
Old 05-21-2013, 06:00 PM
What info?
Without knowing what chassis you have, its hard to even guess.
Old 05-21-2013, 06:14 PM
Do you have a full 49.3 pack for 3.22.5 ? I'm looking to code a 2013 335is and a 2014 x535d.
Old 05-21-2013, 07:07 PM
PM sent.
Old 05-23-2013, 02:36 PM
sofge sofge is offline
Mein Auto: 320
Hi Shawn!
Do you have a full 49.3 pack for 3.22.5 ? THANKS
Old 05-23-2013, 02:37 PM
Mein Auto: 320
Hi Shawn!
Old 05-23-2013, 05:25 PM
Originally Posted by sofge View Post
Hi Shawn!
PM sent.
Old 05-25-2013, 04:39 AM
resaran resaran is offline
Mein Auto: bmw f30
49.3 Cafd Files
Hi Shawn,
I have 3.22.5 and 49.2 and i need 49.3 cafd files to upgrade 49.2 to 49.3 because i got cafd_00000794-004_228_010 file not found error. Can you send the link for 49.3 additional files to upgrade 49.2. Thanks.
Old 05-25-2013, 04:48 AM
Originally Posted by resaran View Post
Hi Shawn,
No, you can not add 49.3 CAFD's to older PSdZData library. They need the full 49.3 PSdZData.
PM sent.
Old 05-28-2013, 04:55 AM
F10J F10J is offline
Mein Auto: 528i
Hi Shawn,
Can you please send me the link to latest Esys and PSdZData files (and password), and maybe tell me how to buy the est token.
Thanks in advance.
Mein Auto: 528i
Hi Shawn,
Thanks in advance.
Old 05-28-2013, 07:53 AM
Originally Posted by F10J View Post
Hi Shawn,
Thanks in advance.
PM sent.
Old 05-28-2013, 11:49 AM
tackerkratzke tackerkratzke is offline
Mein Auto: M5F10
Hi
Can you please send the password for the 49.4 psdzdata.rar files
Thanks Tackerkratzke
Old 05-28-2013, 11:52 AM
Originally Posted by tackerkratzke View Post
Hi
PS. Is it possible that the Engine (M5F10) dismatch after programming Auto Start stop off.
Too much fuel in Kat. He burned out!
550i / M5 does not come with ASS (Auto Start / Stop), as it is not available on V8 Motor.
PM sent.
Old 05-28-2013, 12:00 PM
Mein Auto: M5F10
PM sent.
thanks
it does and its worke fine
BMW does not know how and why the engine, the kats the injectors are damaged
Old 05-28-2013, 12:01 PM
simonchs simonchs is offline
Mein Auto: BMW 118i F20
hi Shawn, may I have the psdzdata 49.4 too? thanks
thanks
It does what? You have an M5 with Ass?
Old 05-28-2013, 12:02 PM
PM sent.
Old 05-28-2013, 12:12 PM
Mein Auto: M5F10
Auto Start Stop yes
german M5F10 08/2012
