Old 05-23-2013, 08:00 PM
mypain525xi mypain525xi is offline
Mein Auto: 525xi
service engine soon (SES) and overheating
hi guys, my 2007 525xi only has 36k miles is giving me headache.
I scanned for the error codes/faults using Bavarian tool, it gave me the following codes...
2C9C
2C9C Lambda probe heating in front of catalytic converter, input signal
Error will cause a warning light
Error is currently present
Test conditions have not been completed
Signal or value below threshold
Freeze Frame Information
Event 1Odometer 58512kms 36357miles
Ceramic temperature Lambda sensor VK 1 0.00 C
time since end of start 179.20 s
Battery Voltage 13.82 V
Lambda sensors heating front cat 1 73.05 %
2C9D
2C9D Lambda probe heating in front of catalytic converter 2, input signal
Ceramic temperature Lambda sensor VK 2 0.00 C
Lambda sensors heating front cat 2 73.05 %
2C9E
2C9E Lambda probe heating behind catalytic converter, input signal
exhaust temperature behind of Cat Bank 1 352.00 C
Resistance Lambda sensor NK 1 65,280.00 ohm
Voltage Lambda sensor rear cat 1 0.43 V
Lambda sensors heating rear cat 1 71.88 %
2C9F
2C9F Lambda probe heating behind catalytic converter 2, input signal
The above mean all 4 of my oxy sensors are bad. Is it possible all 4 gone bad at the same time? So what I did was, I replaced 1 out of 4 sensor just to test( before spending $500 for all 4 sensors). As soon as I reset the error codes, the same codes came right back on...since I have replaced 1 sensor already, why all 4 sensors still shown being bad after I re-scanned it? thanks for all the help in advance..
Old 05-23-2013, 08:16 PM
Mein Auto: 525xi
overheating problem
my other headache is overheating problem. I scanned with my Bavarian tool and got the following error code
2E85
2E85 elctrical cooling pump, communication
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
Event 1Odometer 57552kms 35761miles
Engine speed 864.00 rpm
cooling fluid temperature OBD 13.00 C
Voltage terminal 87 14.52 V
Event 2Odometer 58080kms 36089miles
Engine speed 1,184.00 rpm
cooling fluid temperature OBD 12.00 C
Voltage terminal 87 14.62 V
Event 3Odometer 58248kms 36193miles
cooling fluid temperature OBD 4.00 C
Voltage terminal 87 14.83 V
2E83
2E83 elctrical cooling pump, low-power mode
Event 1Odometer 58080kms 36089miles
water pump voltage 0.00 V
water pump temperature electronics -50.00 C
water pump power reduced 50.00 %
Event 2Odometer 58088kms 36094miles
cooling fluid temperature OBD 60.00 C
water pump temperature electronics -25.00 C
2E84
2E84 elctrical cooling pump, communication
Timeout
Event 1Odometer 58120kms 36114miles
Engine speed 960.00 rpm
cooling fluid temperature OBD -6.00 C
Voltage terminal 87 14.73 V
Event 2Odometer 58120kms 36114miles
Engine speed 832.00 rpm
cooling fluid temperature OBD 45.00 C
Engine speed 992.00 rpm
cooling fluid temperature OBD 10.00 C
2E82
2E82 elctrical cooling pump: switch off
Timeout
According to the above info, it indicates the water pump needs to be replaced. My question is why when I disconnected both battery terminals for 15 min. or more, the water pump would work again for 2 or more days (no overheat problem) then it stops working again after that. why did the water pump work again after the battery has been disconnected for 15 min or more?
Old 05-24-2013, 07:22 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
wild guess on my part....
why your batt voltage fluctuate quite a bit, 13.82 (on problem one) then 14.73(on problem two), clearly with engine running.
Is it possible your batt is very weak, then when you disconnecting it for >15min it rebuilds charge enough to run OK for a day or two?
I'd load-test the batt at local auto-part store to see if the batt is still up to snuff.
Old 05-24-2013, 08:12 AM
Mein Auto: 525xi
thanks, i don't think it's the battery. It was replaced 1 and 1/2 yrs ago and it's draining b/c i have not driven the vehicle for almost 7 months now.
Old 05-24-2013, 07:37 PM
bschmidt25 bschmidt25 is offline
Mein Auto: '07 530xi, '01 525iT
Re: service engine soon (SES) and overheating
I would clear the O2 (lambda) codes and see if they return. If the car has been sitting a while it may be because of that. Get some fresh gas, put some miles on it and check again. They're almost certainly not bad, especially at that mileage. Might want to check your plugs while your at it.
Have you checked the electrical connection to the water pump? You're not overheating according to the temps posted. Overheating would be anything over about 215 C.
Edit: Some of those temps look really low. I'd check the temperature sensors. Those should be cheap to replace if you need to.
Old 05-24-2013, 08:26 PM
Mein Auto: 525xi
yes, I did cleared the faults and they came right back on.
yes, I did checked the electrical connection to the water pump. I got the correct reading. wire 1-===12v, wire2--==12v and wire 3 ====8volts.
where is the temperature sensors? how do I check it? thanks
Old 05-25-2013, 08:35 AM
I don't know that you can really check them, but it's located in the lower coolant hose near the radiator. The sensor itself is less than $20. Might be worth a shot before you replace the water pump.
Old 05-25-2013, 09:13 AM
Mein Auto: 525xi
thanks, i'll check on it later.
is there a fuse or relay for oxygen sensors. i just can't believe all 4 of them went bad at once and the car only has 36k miles. plus i replaced 1 oxygen sensor just to test but the service engine soon light came right back on for all 4 of them as soon as i cleared the codes...
Old 05-25-2013, 09:29 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Sounds like something going on with water temp sensor or it's wiring to me. You aren't overheating--it's saying it's getting such a cold reading from the sensor that it can't be right.
Old 05-25-2013, 10:03 AM
Mein Auto: 525xi
thanks, let me clarify guys....as i was driving...yellow light (warning) light came on then red light (overheating) came which i have to pull over and unplugged both battery terminals for at least 15mins before it was drivable (normal temp) for a day or two then the whole cycle starts over again. If the pump is bad, why did it run normal again after i disconnected the battery terminals for 15 minutes or more? then it operates normally for a day or 2 then stop.
Old 06-08-2013, 05:55 AM
Mein Auto: 525xi
replaced the water pump...so far so good.
check engine soon still giving me the headache....finally took my car to the dealer for the diagnosis..according to them, all four oxygen sensors are showing faulty because of the low voltage they getting from the battery and battery is not being charged correctly therefore IBS Cable needs to be changed. To change the IBS cable, re register the battery and clear out all the codes, they wanted to charge me $695. they must be crazy to think I would them them that much. IBS Cable only cost $220 on ebay and 10 minutes max of labor.
Anyway, my question is.... has something like this happened to anyone? is the diagnosis correct? all 4 oxygen sensors are faulty because of low voltage? I just wanted to sure before i'm going to spend $220 for the IBS cable. thanks everyone
Old 06-08-2013, 05:59 AM
DIY'er
These cars do some really strange things when voltage is too low. I've never seen this particular result but I don't think it's outside the realm of possibility by any means.
Old 07-06-2013, 11:08 AM
Mein Auto: 525xi
just wanted to update the problems.....overheated was solved by replaced the waterpump and tsat and service engine soon light was due to a fuse blown in the EBOX.
