Old 09-11-2011, 11:27 PM
Dubai Guy Dubai Guy is offline
Mein Auto: 2005 E60, 530i
2005 E60, 530i Wont Start. Please advise.
The car was running perfectly till last night, woke up today to go to work and it would not start. The key turns all the, systems power up, but no start. Cycled the gear shift from 'parking' to 'drive' and back, brake pedal pressed, but nil starter action. No faults indicated either in the 'control messages'. What I did notice was, when I turn the key to start, at the point where the starter should kick in, I hear a 'click' sound.
I replaced the battery less than 6 months back, no signs of battery weakness and no signs of difficulty in starting either prior to this. Any ideas anyone. HELP!
Old 09-11-2011, 11:53 PM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is offline
U of Dawgs
Mein Auto: 08 535iA Spt/11 X5 35i
It sounds like you're getting power to the starter solenoid since you are hearing the clicking sound. It could be your starter. But first, try to jump or get your battery fully charged. If it still does not start with a full battery it is more than likely that the starter is defective and need to be replaced.
Nube1Kenobi
2011 X5 35i Sport Activity|Plat Gray/Beige/Dk Poplar|Conv Pkg|Cold WX Pkg|Tech Pkg|Prem Sound|Comfort Seats|Hitch|
2008 535i Mon Blue/Dakota Blk/Dk Poplar|Sports Pkg|Prem Pkg|Cold WX Pkg|Nav|RTTI|PDC|L7|HD|I-Pod/USB|PWR Rr shade|Sports Auto - paddles|Active Stg|Comfort Access|F/D R/seats|Rr DMS Airbags|Adaptive Xenons
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
Old 09-12-2011, 03:55 AM
Thanks Nube1Kenobi, will try your advice, just want to clarify, what I hear is a single low volume 'click', not 'clicking'.
Old 09-13-2011, 07:53 AM
Battery voltage is satis, still tried the jump start option, nil fix. checked all related fuses, found normal.
When I rotate the key to ignition, there is a buzzing/humming sound coming from under the car, when i release the brake pedal it goes away. is that the fuel pump?
if its any help, prior to this, my wiper fluid pump had stopped working, but the wipers were still normal. everything else was normal.
Any suggestions? Anyway I can trouble shoot the starter?
Old 09-13-2011, 12:46 PM
mohsaleh2001 mohsaleh2001 is offline
Mein Auto: 530i, 2004
I had the same problem and it was the starter It costs me 2000QR to fix , but try to have a jump start first to check if it is the battery or not
Old 05-12-2012, 07:49 PM
abepa abepa is offline
Mein Auto: e60
same problem here
Hi MrDubai Guy..
I think that i have the same problem as yours. Can you please tell us how did you resolved your problem....
Thanks in advance..
-pa-
Old 05-13-2012, 07:41 AM
w5lx's Avatar
w5lx w5lx is offline
Mein Auto: 2008 528i/2007 328i Coupe
Did you change the battery yourself or let BMW change it? Was it registered when it was changed?
Old 08-09-2012, 06:58 PM
VanBreezy VanBreezy is offline
Mein Auto: 2005 530i
I had the same problem it was the starter for me. A good key is if you still get nothing when you try to jump start which was my case. I removed the battery took it to Autozone they charged it for nothing but it still wouldn't start.
Old 05-25-2013, 05:22 PM
stilldre54 stilldre54 is offline
Mein Auto: 530i
stilldre54
was it your starter I have same exact problem
