Old 05-24-2013, 10:08 PM
MSAMMY MSAMMY is offline
2007 550i & X3, 2002 X5
Mein Auto: BMW 550i, X5, X3
Battery Replacement - this may be a record!
Well, well, after 2,538 days, we finally had to have our original battery replaced in our 550i. That's a total of 6 years, 11 months, 17 days! That's just shy of 7 years on the original battery!!! After all of the horror stories about short-term battery replacements, parasitic draw problems, etc. we decided to finally post a good news story on a battery replacement.
Anyone else have an E60 with a good news battery replacement that exceeds 7 years??? Post on and let's talk batteries - good news or bad!!!
2007 550i, Sport Premium, Silver Gray Metallic, Gray Dakota, Navigation, Cold Weather Package, Comfort Access, Heated Rear Seats, HD Radio, Xenon
2007 X3, 3.0si ///M Sport Premium, Monaco Blue, Gray Dakota, Navigation, Cold Weather Package, Xenon
2002 X5, 3.0i Sport Premium, Titanium Silver, Gray Dakota, Cold Weather Package, Xenon, just a winter vehicle
Old 05-25-2013, 12:24 AM
peachykonan peachykonan is offline
Mein Auto: 2004 525i
I have a 2004 BMW 525i and was forced to replace the battery two months ago. Could not survive even with a jumpstart. Definitely made the most use of it. Original date stamped on the - end was late '03. Should have replaced it sooner; every now and then I was getting errors ranging from abs, dsc, tire pressure low, general system failure, etc.
Old 05-25-2013, 01:32 AM
MADBMWX1 MADBMWX1 is offline
Mein Auto: 2013 BMW X1
I replaced my OEM battery after 8 yrs of faithful service...cant complain
Old 05-25-2013, 07:30 AM
burnie35's Avatar
burnie35 burnie35 is offline
Old Timer (Really)
Mein Auto: 2009 BMW 535i Sport
Nice to see posts with good things to say rather than just complaints!
2017 X5 35 M-Sport, Carbon Black, Black
2009 535i Sport, Jet Black | Cobb Stage 2 Aggressive | Injen DCI | AR Downpipes | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus
2008 528i (Retired)
2006 328ci (Retired)
1975 US Army (Retired)
Old 05-25-2013, 08:06 AM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
Anything special you guys did to make batteries last that long? Using a battery tender, high mileage, few short trips?
2008 535i Monaco Blue
PP, SP, SAT w/paddles, ARS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Trim,
Gray Dakota Leather
Old 05-25-2013, 10:13 AM
mypain525xi mypain525xi is offline
Mein Auto: 525xi
usually you need to drive your vehicle at least 12k mil or more per yr, if not, your battery will drain faster than it being charged. You would need to replace it every 2 yrs like it did with my 2008 x3 and 2007 525xi. I've learned a very expensive lesson..
Old 05-25-2013, 12:04 PM
TLO03's Avatar
TLO03 TLO03 is offline
Mein Auto: 08 535 xit
interested on how many miles that is?
Old 05-25-2013, 12:43 PM
patrick_y patrick_y is offline
Mein Auto: 2004 BMW 545iA
Just replaced the battery on a Mercedes that was on the same battery for 8 years! Battery eventually went bad according to the dealer, never any problems starting the car, but the radio would get locked out.
And my previous car (also a Mercedes) had the same battery that came with the car from the factory for 7+ years.
Do note, none of the Mercedes-Benz vehicles have as much electrical demand as the BMW. For instance, my BMW doesn't go to sleep for over 30 minutes after shutting it off. The Mercedes-Benz cars seem to go to sleep within 10-15 minutes after last touching the car. Furthermore, the Mercedes-Benz vehicles were consistently and fairly regularly driven. Almost driven daily.
And this BMW 545i in the garage is probably on its third or fourth battery. But that's because the car was under-driven (28,000 miles in the first 8 years) and many short trips. Now that the car is over driven and a new battery was installed and programmed at the dealership at the cost of nearly $500 in January of 2013, I'm hoping that I won't have to replace the battery anytime soon and that it will last for at least five years assuming the car is regularly driven. The alternator and voltage regulator was also changed as well.
Old 05-25-2013, 08:48 PM
That's the thing, it seems to be hit or miss with E60 battery life with no definitive pattern at all. My commute over the 7 years was 3.2 miles each way. The car has only 58K miles on her and was only driven from April-November each year. For the 4 months of winter storage, I simply plugged in the trickle-charger to maintain the battery whenever I remembered to do so every couple of weeks or so. One winter, I skipped the charging completely. So short commutes, parked in winter with random trickle charging worked for me, but does not fit the profile of most batteries that fail with short commutes, weird.
