Rear Pitman Arms - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E34 M5 (1988-1995)
E34 M5 (1988-1995)
Old 05-29-2013, 05:33 PM
garry_lay garry_lay is offline
Mein Auto: 1991 E34 M5
Rear Pitman Arms
Had an indy shop to install new rear pitman arms (otherwise known as dogbones) on my 1991 E34 M5 with 107K miles. I noticed the mechanic tightened the bolts with the wheel up in the air but didn't think anything of it until I got home later and read about the proper installation of the pitman arm bolts is that they should be tightened with the wheel/tires on the ground supporting the full weight of the car.
Will this cause premature wear on the pitman arms and what should I do now ? Should I losen the bolts slightly and re-tighten them with the car sitting on the ground ?
Old 04-07-2014, 11:24 AM
DKJimmy DKJimmy is offline
Mein Auto: 1991 BMW ///M5
This will cause unwanted stress on the pitman arms and they should be tightened with a load on the wheels, however the difference between tightening them preloaded or not at all is so minimal you will not feel any difference in the cars handling or life of the dogbones. If you are a perfectionist and its going to bother you while you sleep at night I would suggest tightening them, otherwise just live with it, your choice.
Hope I helped!!
Old 04-07-2014, 04:24 PM
If those rear pitman arms were tightened with the wheels unloaded up in the air, will I need to tighten them "further" now with the rear wheel loaded on the ground ? Or should I losen the bolts slightly and re-tighten them with the rear wheels sitting on the ground ?
Old 09-26-2014, 01:24 PM
oLDgREY525 oLDgREY525 is offline
Mein Auto: 91 525i
I don't drive a m5 but I do get down and around in a 91 525i my question is what kind of handling deficiency can I expect from worn out dog bones ? I've gone for a wheel alignment and it the right rear out of alignment and not adjustable to spec. I'm trying to identify problems I may have been having before the alignment results.
1991 BMW 525I
Automatic trans
Old 11-16-2014, 06:28 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
Yes, you should slightly loosen the bolts, lower the car so that the entire weight of the car is resting on the wheels and then tighten the bolts. I just did this job on my E24 M635. It was a bear getting the new arms on the car with the car up in the air.
COL(Ret), US Army
Hagerstown MD
2016 528ixdrive/MSport
2016 Corvette Stingray (Fun Car)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Old 11-06-2015, 03:22 PM
jaminjimmy jaminjimmy is offline
Mein Auto: BMW 525i e 34
I have a clunking in the left rear suspension when I'm turning left. So when the left rear is unloaded. Just replaced pitman arm's and noise still there . Any ideas.
Old 11-07-2015, 02:59 PM
gahawkins gahawkins is offline
Mein Auto: 1991 M5
E34 M5 Pitman Arm
I wouldn't worry much about retightening, although the "correct" procedure is weighted. Noise is usually the first thing people notice. 100 Kmiles would be a expected lifetime.
