Do-It-Yourself H.Q.
Old 02-02-2013, 11:40 AM
Stonehenge Stonehenge is offline
Mein Auto: 2004 BMW 325ci
2004 325ci EML problem
Hello, I have a 04 BMW 325ci. My EML light came on and the car wouldnt start. I found the rubber ends dry trotted from thethe vacuum F to the fuel filter. Also found the intake manifold runner valve broken. Replaced /fixed both problems and it ran wonderfully for two days. I got in the car to find it wouldnt start again and the EML light back in. Connector at the F had came off. I reconnected it and still wont start. Any idea what the problem can be?
Old 02-17-2013, 11:08 AM
Thanks for the overwhelming amount of help guys. :P
I figured it out.
Old 06-05-2013, 12:22 PM
DiverDave714 DiverDave714 is offline
Mein Auto: 2004 325i
I just encountered this problem with my 2004 325i. I have plenty of battery power and I had just driven to the store, but now the EML is on and when nothing happens when trying to start. What did you end up finding was your problem? Please...
