The X5 SAV Forum
Old 06-03-2013, 07:52 AM
Fonkidool Fonkidool is offline
Mein Auto: 2001 X5 4.4i
Central Locking - Please Help
My central locking is only working on the two rear doors with the key/remote for unlocking and locking.
I have to unlock the front doors manually.
Any idea why this could be?
Many thanks for assistance
I have a 2001 X5 4.4i
Old 06-03-2013, 06:28 PM
selfkeymaker selfkeymaker is offline
Mein Auto: e39
Sounds like your general module having problem
Old 06-03-2013, 10:00 PM
Thanks for the response. What does that mean? A replacement or can it be fixed.
Also let me know were the module is situated.
Cheers
Old 06-04-2013, 12:02 AM
Mein Auto: e39
Cheers
Just buy a used or new General Module to replace. I am sure is very cheap from chop shop in your country
Old 06-06-2013, 07:42 AM
Only if you convert $ to ZAR
Were in the car can I find this general module?
Old 06-06-2013, 09:02 AM
Mein Auto: e39
It located behind the glove box. When you press the lock/unlock in the car is it ok ? If internal lock/unlock button facing same problem with your remote then very high chances is general module failed.
Old 06-06-2013, 10:08 AM
Thank you very much. I located it and quickly took it out an opened it. Just some electronics inside that I know nothing about.
The internal lock works fine inside the car but only locks / unlocks the two rear doors (plus the boot and the petrol cap. The drivers door must be locked/unlocked with the key, and the passenger's door does not have a lock. Must open it from the inside.
Old 06-06-2013, 07:18 PM
Mein Auto: e39
How about you press the master lock button ? It is master lock button able to lock/unlock all doors ? If master lock button not able to do this sure general module has problem but dont forget to check the door actuator as well.
Old 06-11-2013, 03:38 AM
I made contact with Scott Johnson and he does not think it is the GM. He also suggested that I look at door actuators.
