Old 06-12-2013, 01:33 PM
mikecw123 mikecw123 is offline
Mein Auto: 2003 Z4
DSC & Brake light
My 03 Z4 has 103,000 milies. I was driving and the DSC light and the BRAKE light came on and stayed on. The manual says take it to the dealer. Is this a big problem?
Old 06-15-2013, 08:04 AM
Jstic Jstic is offline
Mein Auto: 2006 Z4 3.0i
Could be any number of things tripping those lights. You need to pull the fault codes to narrow it down. First thing to do is check to see if your battery is holding enough charge.
Old 06-15-2013, 08:19 AM
Mein Auto: 2003 Z4
DSC light and Brake light
Thanks for the response. The alternator and the battery are new so I can probably rule that out. I'll have to take it to a repair shop to have the codes checked. Here in Clearwater that's $100.
Old 06-15-2013, 10:49 AM
vintage42's Avatar
BMW CCA 1405
You could buy an Ultragauge for $60.
http://www.ultra-gauge.com/ultragauge/
http://i49.photobucket.com/albums/f2...psc9470460.jpg
Even if you did not want to mount and use it for its other functions, it would read the trouble codes.
Old 06-15-2013, 12:36 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
I do not think the DSC is part of the ODB-II system, so I do not think Ultragauge or any other ODB-II reader/scanner will see those codes. I could be wrong....
You can find out by taking your car to AutoZone or AdvancedAuto. They will hook up an ODB-II reader/scanner and read the codes for free.... Seven days a week...
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 06-15-2013, 02:14 PM
Clearancediver's Avatar
Clearancediver Clearancediver is online now
Mein Auto: 2004 Z4, 2009 Nomad mc
DSC & Brake light
One thing that you might like to consider doing yourself is cleaning the wheel sensors. You have to remove your tire but once you have done that the wheel sensor is easily accessible. Allen bolt holds it in ... Remove bolt and wiggle and it comes out fairly easy. Clean with brake cleaner and replace. Do all four sensors. If it was dirty wheel sensors causing the fault it should clear the visual fault lights. The fault will still be in memory and can read/cleared. Dirty wheel sensor connections could also be a possibility but dirty wheel sensors more likely.
