Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 8 Series - E31 (1989 - 1999)
Old 06-10-2013, 06:05 AM
SDBDubai SDBDubai is offline
Mein Auto: 850 Ci
Bmw 850 help!!
I have an 850 Ci 1999 that the garage has told me needs a right hand side fuel pump assembly. Any help in locating this part much appreciated. Car and myself in Dubai so expert help or reliable help a bit thin on the ground!!
Old 06-11-2013, 08:44 PM
platinum850ci platinum850ci is offline
Mein Auto: 850CI
Hi!
The fuel pump assembly i doubt would be cheap are you 100% sure that is your problem? what is wrong with your car what is it doing?
Regards
Old 06-11-2013, 10:17 PM
Mein Auto: 850 Ci
Thanks for your reply. The problem occurred when i filled up with fuel and noticed it was leaking. Garage tells me it is leaking from seals at top of assembly and whole thing needs replacing which i am a bit dubious about. OK car is 1999 but has only 70000km on the clock! (When only half full, no problem)
Old 06-11-2013, 10:30 PM
Jay. Jay. is offline
Mein Auto: E34
Can you see where it is leaking from? If so please take pictures of where its leaking from.
'91 525i - Drove it till the wheels fell off
'89 325i - Sold(Drop top on 20" rims)
'93 325i - Totaled
'97 740i - sold
'87 325es with chip - Sold(one of the worst mistakes of my life)
'86 325e - Sold
'90 525i - Current daily driver
I bought a Honda ONCE...
Old 06-12-2013, 12:14 AM
Mein Auto: 850 Ci
Thanks will try this weekend!
Old 06-12-2013, 02:07 PM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
There is an access plate above the pump assembly.It is under the rear seat on the same side as the fuel filler.
If it is leaking there it is most probably the hoses or the seal where the pump assembly attaches to the tank.
Fuel pump failure usually means it won't run at all.
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 06-13-2013, 03:43 PM
Six Addict Six Addict is offline
Mein Auto: 850 CSi
If you only noticed the leaking when you filled the tank, perhaps it is the fuel filler neck (or it's connection to the tank) that is leaking. Does it still leak fuel after you have used some of the fuel ? Maybe not a fuel pump issue at all
Old 01-29-2014, 08:41 PM
centripidal centripidal is offline
Mein Auto: 1991 850i
my 91 was leaking and I took out the passenger side rear seat and opened the access panel , the fuel line was dry rott so I replaced it and also had to tighten the cap that holds the fuel pump assembly on the tank , fixed my leak no more problems.
