Old 06-14-2013, 01:01 PM
wazzabill wazzabill is offline
Mein Auto: bmw X3
Post aux conection
Iv just bought an x3 06 plate the se, its standard inside, and in desperate of an aux for tunes, I heard somewhere that not all the x3 model s have the aux output connection on the standard bmw buisnesd cd player I dobt want to put an aftermarket cd player in it unless i have too. Can someone shed some light on this
Old 06-14-2013, 01:19 PM
gaticaag gaticaag is offline
Mein Auto: 2005 X3 2.5i
Your business cd player is pre-wired for an aux input, you just need to buy and install the cable. Mine didn't have an aux input so I bought one from bavauto. Part # 82 11 0 149 390
Really easy install. I didn't want my input in the glove box so I drilled a hole under the climate control faceplate. I can provide pictures later if you'd like.
Old 06-14-2013, 02:34 PM
Mein Auto: 2004 X3 2.5i
The UK got 3 options of sound system - basic (4 or 6 speakers, no amp., no sub-woofers), Business (8 speakers), DSP (10 speakers).
N. America got just the latter two choices, and not too many DSP were sold.
So for a UK model, you have to first identify which level sound system you have.
If you have the Business head unit, it should support the aux-in kit that gaticaag quotes the part no. for.
(The UK units are programmed differently for the different broadcast frequencies in Europe, but I would think the aux capability is mostly hardware so should be standard.)
If you had the basic level non-Business head unit, you would be out of luck I think.
Old 06-14-2013, 03:37 PM
Mein Auto: bmw X3
aux
Rite on, im gona get the lead tomoz and have a go at wireing it up, I want it in the center console.
Old 06-14-2013, 07:11 PM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Just follow the E46/E39 Aux in threads. You have a New Gen (40 pin) headunit. The pins are the same for OG and NG but the connector shell went from 10 to 12 pins, so if you don't have the shell you need to make sure you get an NG kit.
Old 06-15-2013, 04:10 AM
Mein Auto: bmw X3
iv just had the unit out and i see on the connector which pulls out, 16 pin holes and two of those are free with no wires, is this good news?
Old 06-15-2013, 04:16 AM
Mein Auto: bmw X3
Old 06-15-2013, 03:26 PM
ryan_nguyenvnn ryan_nguyenvnn is offline
Mein Auto: X3 E83
I just have aux input installed not long ago . It was simple and only took me less than 30" to plug in , run the cable , drill the hold in the astray etc . Go on eBay , search for OEM BMW x3 aux - Part Number: 82.11-0 149 390
[IMG]http://imageupload.co.uk/files/ejbg***mt9ys7dc16eip.jpg[/IMG]
Good luck
Old 06-16-2013, 03:16 AM
Mein Auto: bmw X3
Re: aux conection
Nice work putting it in the ashtray there
Sent from my GT-I9300 using BimmerApp mobile app
Old 06-16-2013, 03:47 AM
Mein Auto: bmw X3
and the aux go's in next to the white one ?
Old 06-16-2013, 10:49 AM
Installation depends on what you have already installed. You either put the L, R & audio GND pins into your existing connector or use the one that comes with the kit.
RYAN: love that red interior. Looks a well optioned car, with heated seats and front PDC. I was expecting a different arrangement of connectors for the business nav though! I expected a BM54 in the boot and the blue/white nav connectors at the radio, like the late model E46 business nav.
Old 06-16-2013, 01:22 PM
Mein Auto: X3 E83
@joylove : it was DIY you could easily remove trims/ stering wheel trim then spay them with any plastic primer & spay paint - mine are without lacquer and the paint is MUCH better than original BMW paint work ( chip off )
