E36 (1991 - 1999)
Old 06-05-2011, 08:38 PM
markwainwright3 markwainwright3 is offline
Mein Auto: 2002 BMW 330 1996 BMW 328
Radiator blew
Im 18 and new to this all, a week ago I bought a 1996 328i with 165,000 miles and yesterday while sitting in traffic the radiator blew, the plastic that the hose in the left top corner attaches to broke and the hose popped off, I heard this is a common problem and was wondering how much including labor it would cost to fix???
Old 06-05-2011, 08:55 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Zero. Buy an aluminum radiator off ebay, buy a cooling system overhaul kit from ECS tuning, and overhaul your cooling system. Its so easy, a caveman can do it. Seriously. Aluminum ebay radiators arent half bad, I'm using one now and I race with it and everything, and theres no plastic on it to break off Look up cooling system overhaul E36 and you'll see how easy it is
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 06-18-2013, 08:26 PM
I realize this response is two years too late but I took your advice drive by72 and purchased a aluminum radiator from ebay, I also replaced the radiator fan clutch, thermostat, thermostat housing (with an aluminum one), water pump (with a metal impeller instead of plastic) and I have had absolutely no problems since then, the car now has 184,XXX miles and until a couple of weeks ago when I bought a 2002 330I it was my daily driver.
Old 06-18-2013, 08:56 PM
dc_wright's Avatar
bimmerfest Supporting Member
Thanks for coming back to the 'Fest! It's always welcome when someone comes back with the problem solved.......even if it's two years later.
