E36 (1991 - 1999)
Old 06-19-2013, 01:09 AM
cristiane36 cristiane36 is offline
Mein Auto: bmw 325is
Exclamation Stock jack
How good are the jacks that come with the e36.. the ones that go into the side skirts?? they seem very unstable? anyone ever have any problems. I thinking about using it just to change my brake pads out, not going under the car.
Old 06-19-2013, 02:53 AM
kpjo4 kpjo4 is offline
Mein Auto: e92
they are alright, but a hydraulic would be soooo much faster
Old 06-19-2013, 06:08 AM
E36 Phantom's Avatar
I Am The Machine
Re: Stock jack
They're very effective for quickly raising the car for an emergency tire change, and that's it. Way too unstable for anything else.
C:\>Sent from my 386 using MS-DOS__
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 06-19-2013, 10:02 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
+1. They are really for emergency use only. I had one rock back and buckle/collapse, but luckily I had already gotten all wheels bolted on when it happened. Definitely get a proper hydraulic floor jack and jack stands when doing any work on your car.
1998 BMW 328is
1966 Pontiac GTO
Old 06-19-2013, 10:03 AM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
+1. Mine recently rocked back and collapsed. Luckily, I was already out from under it during a roadside inspection/repair.
Old 06-19-2013, 10:04 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
This weekend I used the stock jack to raise the car up onto jack stands. I think it works great! But would I keep it on the car during a brake pad change out? Nooooooooooooo...
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 06-19-2013, 10:26 AM
3B2M8WI 3B2M8WI is offline
Mein Auto: 1998 BMW 328i - Avus blue
Yeah defiantly for emergencies only. I had my car lifted up with it in the back and the tire was off. I leaned into the trunk a little too far and rocked the car and the jack collapsed. My tire was off and the car fell on the rotor, not fun!
Old 06-19-2013, 10:28 AM
I Am The Machine
That's fine, Harry, I've done that in a pinch as well and it does have the benefit of leaving the jack pad clear for a jack stand. You absolutely have to chock the wheels when raising/lowering though, so I still prefer the stability of a proper hydraulic jack.
// Chad //
You're a derbanana
hnaz's Avatar
BMW CCA Member
See, if that were to happen to me, I'd probably just sit there for 5 minutes, staring at the damage then light a cigarette.
My Previous Work:
Old 06-19-2013, 10:37 AM
Shigeta's Avatar
Old Soul
Or a nice cigar. Knowing my area, it would take 2 hours for the tow truck to arrive and they would proceed to bitch how my car was "too low" for an hour.
Old 06-19-2013, 11:00 AM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
I bought rubber tire 'chocks' for $5.99 at harbor freight. Only way I use the factory jack is with them properly placed. Previous experience with this style jack says "DON"T trust them if you have options.
Old 06-19-2013, 11:37 AM
ZeGerman's Avatar
Warm Leatherette
Yeah, when hydraulic jacks, jack stands, and wheel chocks are so cheap at Harbor Freight, it's pretty foolhardy to continue using the trunk jack for anything other than emergencies.
1998 BMW 328is
1966 Pontiac GTO
Old 06-19-2013, 12:11 PM
Shigeta's Avatar
Old Soul
I've even seen some people carry small racing jacks in their trunks over the dangerous BMW jack.
Ideally, you buy a E36 jack pad adapter that will let you use the hydraulic jack with the factory mounting points.
Old 06-19-2013, 12:23 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, I have a jack pad adapter, which honestly, BMW should've included in the trunk of every car from the factory, but didn't... Nevertheless, I'd still have to use the standard trunk jack if I ever got a flat, since there's no way I'm going to carry even an aluminum racing jack in my trunk all the time. Gotta keep my curb weight down!
1998 BMW 328is
1966 Pontiac GTO
Old 06-19-2013, 12:36 PM
hnaz's Avatar
BMW CCA Member
I need to order that adapter from Pelicanparts.com, along with a few other tools. I'll be starting my BMW specific tool collection in August until I have enough to do anything from a water pump replacement to stapling hogties to upholstery replacements.
My Previous Work:
Old 06-19-2013, 12:54 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
I have already purchased 2 of the side skirt jacks for my car since owning it. Both of them have collapsed. One collapsed when raising the car at home and the other collapsed when I was lowering it at work. No damage to car on both occasions. I love the jack though because my car is wayy too low for a normal size jack to fit under there. I usually raise it up enough to where I can fit my jack stands and use wheel chocks when getting ready to lift it.
They are a couple of bucks at the junk yard. Junk yard shopping is my idea of fun! Lol
Old 06-19-2013, 12:59 PM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
+1
I have the adapter and I absolutely love it. With the adapter I can easily get all four wheel off the ground because I can place the jack stands up the factory jack points.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 06-19-2013, 01:29 PM
FYI: Harbor Frieght has a small hydraulic bottle jack with a screw-up top that works great and fits nicely in the trunk of my vert
Old 06-19-2013, 02:40 PM
Oh it was in my garage thank god.
Old 07-28-2013, 10:17 PM
pimpin.dre pimpin.dre is offline
Sucker for the 3 Series
Mein Auto: 1995 328i, 1980 323i
Did exactly this a few weeks ago. Glad it's not just me. Felt like such a knob
Member of the Non-M Bumper by Choice Club Member of the Official Secret Bimmerfest Text Club
Old 07-29-2013, 11:53 AM
dtownmikebrown's Avatar
dtownmikebrown dtownmikebrown is offline
Smooth Operator
Mein Auto: '98 BMW 323is
Stock jack
I've had the tip over while changing a flat with the stock jack. On my car there's damage on one side on the sheet metal just above the jacking point that I suspect is from same thing happening to the last owner. I found a small 1.5 ton hydraulic jack to stick in there instead because I'm afraid of that thing.
-Mike
'98 BMW 323is
'87 Mitsubishi Starion ESI-R
