E36 (1991 - 1999)
Old 06-17-2013, 11:31 AM
C14 Rider's Avatar
C14 Rider C14 Rider is offline
Mike
Mein Auto: 2010 Audi S4
Originally Posted by TheFinanceGuy View Post
so because Audi?
No, I totally understand that logic. 11 years newer is nice. I tend to drive my wife's 2012 Forester on the weekends. It doesn't rattle, or make strange noises that I have to listen to/worry about...
Its partly the Audi but overall needs changed I guess..
Almost hate to part with it because the car just has soul or character, the Audi is smooth that its almost boring at times...then the supercharger kicks in
2010 Audi S4 Premium Plus/3.0L Supercharged V6/Quattro/6 speed/25k and climbing/
Old 06-17-2013, 12:09 PM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
so because Audi?
Mine doesn't rattle or make noises?
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 06-17-2013, 03:09 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Today on my Bimmer I...
My interior doesn't. But I have rattle/knock/clunk upfront that I can't seem to find. Also exhaust heat shield rattle....
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 06-17-2013, 03:29 PM
hnaz's Avatar
BMW CCA Member
That is either your pivot ball joint, sway bar linkages, or sway bars.
My Previous Work:
Old 06-17-2013, 03:35 PM
still learnin'
Whole front end has been checked a few times by me and my Indy (his name is Dave). It's going back to Dave next Wednesday for a post HG check. I asked him again to look. He has even driven my car for 40 miles and heard it too.
It's just a mystery for now. At some point the worn part will present itself.
99 540i TiAg
Old 06-17-2013, 06:34 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
Look for your missing tool in the engine compartment. (Chuckle!!)
Old 06-17-2013, 06:52 PM
dc_wright's Avatar
bimmerfest Supporting Member
Have you checked your strut bearings? If your struts have been replaced check to ensure the center nut is fully tightened also. Either of these will give you a noticeable clunk.
Old 06-17-2013, 07:07 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
Mein Auto: A redhead E90
this is my issue... i need pillow ball mounts on my coils and not the oem rubber mounts.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 06-17-2013, 07:25 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
pillow mounts??
df
Old 06-17-2013, 07:30 PM
Kdoherty's Avatar
Originally Posted by drivinfaster View Post
pillow mounts??
df
your standard poly centered camber plate. they're called "pillow ball mounts"
  • '06 325xi 6MT
Old 06-17-2013, 07:43 PM
hnaz's Avatar
BMW CCA Member
Ahh yes, good call. I had a clunk that was a result of this when I had my 318i. Soon as I tightened the center nut, clunking went away.
My Previous Work:
Old 06-18-2013, 05:48 AM
hnaz's Avatar
BMW CCA Member
Today on my Bimmer I am thinking about giving EBC a go. I see the prices at ECSTuning is pretty good. But I just don't know... they seem pretty cheap for "track pads"
My Previous Work:
Old 06-18-2013, 06:11 AM
still learnin'
Wait- Can you explain these a bit more? We might be on to something here. Though, the upper strut mounts were replaced 10k miles ago. The clunk was there after replacing...
What is the difference between the bearing and the mount? It seems as though the bearing is incorporated with the mount?
(disclaimer:only had about 4 minutes of google time to "learn" this....)
99 540i TiAg
Old 06-18-2013, 06:58 AM
redE36girl redE36girl is offline
Mein Auto: 1993 E36
Ok is it a random clunk or is it all the time. Because my E36 has had a random clunk seance long before i did my suspension. an what i mean by random is i can go a few weeks nothing then it will clunk when coming to a stop all my brakes are new minus the calipers. So i am also wondering if we are having the same clunk. Squeaks and creaks tend to happen with older cars. I am just going crazy with my random clunk.
1993 BMW 325i
1990 VW passat wagon
1987 jeep(AMC) cherokee
1979 VW westy rabbit 4 door
Old 06-18-2013, 10:50 AM
dc_wright's Avatar
The bearing is part of the upper mount. Since the clunk has been there since the strut replacement I'll be that the center nut isn't tightened completely. There's a shoulder on the strut shaft and if the top nut isn't tightened to where the upper mount is sitting on that shoulder firmly. you'll have a clunk. It can be really difficult to get that center nut tight enough since it's hard to hold the shaft from turning while you're trying to tighten the nut down. I had the same thing on my left front after I did mine. A quick hit with the electric impact wrench fixed it.
If you use a pneumatic impact, turn the pressure way down because you don't want to over do it and break off the top of the strut shaft or strip the threads.
Old 06-18-2013, 11:01 AM
still learnin'
Thanks Don.
I'll try tightening those. I don't have an air/pneumatic gun. Maybe I"ll ask the shop next week....
99 540i TiAg
Old 06-18-2013, 01:34 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Re: Today on my Bimmer I...
Thanks Don.
You could always do it the muscular way.......
-Dino
Old 06-19-2013, 03:17 PM
still learnin'
Awesome Jon!
Is that a wall mounted shop vac in the background?
99 540i TiAg
Old 06-19-2013, 03:21 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
So in love with that color, Jon!
Old 06-19-2013, 03:44 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Nice Jon! I've always wanted to do that on my car, but just don't want to risk it. Also love the shop vac on the wall, and the plywood on the floor...
1998 BMW 328is
1966 Pontiac GTO
Old 06-19-2013, 05:06 PM
Shigeta's Avatar
Old Soul
Originally Posted by SCJon View Post
The plywood is to catch my persistent power steering leak.
Must... Fix... Soon... so... easy.. so... cheap...
Old 06-20-2013, 12:07 AM
TheRealTalk978 TheRealTalk978 is offline
Mein Auto: 1997 328i
Today on my bimmer i bought
Euro clear tail lights
Euro clear passanger lights
Clear side markees
New hood and trunk emblems
Also I want to replace my steeeing wheel. What you think about grip royal for a replacement?
Old 06-21-2013, 12:55 PM
dc_wright's Avatar
Did the annual spark plug, plug boot replacement, and compression check today. Compression good on all six and plugs looked good!
Old 06-21-2013, 02:59 PM
ZeGerman's Avatar
Warm Leatherette
Got a box 'o parts in the mail today. I'll be replacing the upper & lower radiator hoses (which, to my knowledge, are the originals), along with the expansion tank return line (which is the cause of my leak). I'll also be replacing my aluminum t-stat housing with the OEM plastic unit, which many of you will say I'm crazy for doing. The truth is that my aluminum housing always leaked just a tiny bit. Basically not enough to even matter, but still. A lot of the CCA guys around here have stories of the aluminum housings leaking or seeping, so it isn't unheard of. I still think the aluminum housings are a good idea, but sometimes they work, and sometimes they don't. Once I get the leak squared away, I can get to installing the last 2 new spark plugs and see if that cures my engine stumble (not holding breath...).
BMW of Silver Spring was kind enough to throw in an extra lower radiator hose, free of charge. Maybe that was their way of saying thanks for making me wait forever while they special ordered an E36 lower radiator hose.... It's such a common replacement part, so why they don't have an entire room filled with them is beyond me. Also had to special order the expansion tank hose and cable ties which keep it secured to the inner fender well/frame rail. Anyway, if anyone needs a brand new OEM BMW lower radiator hose, let me know.
1998 BMW 328is
1966 Pontiac GTO
Old 06-22-2013, 09:32 AM
dc_wright's Avatar
Interesting! Going back to the plastic is certainly contrarian, but so long as it wasn't molded in a "green" country I don't see why it shouldn't hold up ok.
Moved the connection point on the Turner front sway to the forward position today.
The rear most position allowed a bit of suspension movement before the sway bar started exerting some force. The forward position bring the sway bar in immediately. Noticeable difference in turn in. It will be interesting to see how the sway bar end links hold up since they're under much more load now and at a more extreme angle.
:3
