E30 (1982 - 1993)
Old 06-20-2013, 07:43 PM
M42 Jack M42 Jack is offline
Mein Auto: 1991 bmw 318is
Bmw e30 lug conversion
I have a 1991 bmw 318is and I want to put 16 inch style 5s off an e38(7 series)
But I have 4 lug and they are 5 lug
Are adapters a good option?
Old 06-20-2013, 08:07 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Re: Bmw e30 lug conversion
Not really. Yes, you could use adapter.plates, but they move the wheels out a lot, taking away needed offset. Best option: E36 318ti rear hubs and E30 M3 front hubs. Not a cheap option, but the safest and best.
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 06-20-2013, 08:42 PM
I'm on a tight budget So the hub swap is not really an option
It's either the adapters or keep my stock 14 inch basket weaves
Which I'm am tired of. So are adapters safe for just normal driving?
I don't track my car
Old 06-21-2013, 07:47 AM
kyfdx's Avatar
kyfdx kyfdx is offline
Who, me?
Mein Auto: 2006 330Ci ZHP
Why not look for some 4-lug wheels in 15" or 16"?
2006 330Ci ZHP Imola Red
2011 X3 Bluewater
1995 M3 Montreal Blue
1987 325iS Bronzit (retired)
2011 Z4 Space Gray (retired)
2008 X3 Sapphire Black (retired)
2005 330Cic Silver-Gray (retired)
2003 325i Sport Steel Blue (retired)
1967 2000CS Delphin Gray (retired)
Old 06-21-2013, 12:43 PM
D'oh, You Kids!
What he said^
Adapters are plenty safe if they're made correctly. That's not the problem. Those style 5s off the E38 are et23 (offset). The OEM wheels on an E30 are between et30 (the M3 14" basketweaves, but 5 lug) and et45. You're already going to poke the wheels out toward the fender 20-25mm, PLUS you'll be adding a thick spacer, which will bring the offset to zero or less (even more poked out). It won't work.
Find some style 5s that are et45 and you can then run adapters....or just get some four-lug 16" wheels in a style you like.
Quotes to live by:
BMW-CCA #441426
