E30 325i 1990 2dr. Oil leak - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 06-21-2013, 03:34 PM
BimmerBoy#2 BimmerBoy#2 is offline
Mein Auto: 1990 e30 325i
This is my first post, so bare with me...
I have a 1990 e30 325i with quite a bad oil leak that I can see dripping mostly from the subframe, and the oil pan. I have replaced the oil pan gasket, and the valve cover gasket, and the leak has not slowed. I'm running 5w 30 motor oil, and the car has 212,000 miles on it.
I can also see the leak coming from under the exhaust headers primarily to the front of the engine. Any ideas on where this could be coming from? Any input would be greatly appreciated. ***128522;
Old 06-21-2013, 11:17 PM
kamotors's Avatar
kamotors kamotors is offline
Mein Auto: 325i
oil return tube o-rings replaced? they'll drip right near the steering rack area pretty badly when they go out.
89 325i~~04 s60r~~88 635csi~~91 325ix-SOLD~~02 WRX-SOLD~~04 WRX-SOLD~~01 2.5RS W/h6-SOLD
Old 06-22-2013, 06:34 AM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
Re: E30 325i 1990 2dr. Oil leak
OP,
I recommend you carefully wash the engine to remove the old oil deposits. Next start the vehicle and let it idle for 5 minutes. This should give you clear indication of the location of your leaks. Check to oil filter mount o-rings, oil pressure sender, camshaft seal, crankshaft seal, oil pump intermediate shaft seal, valve cover half moons, and the dreaded head gasket. Good luck.
Big Boyz with Bad Toyz.
Old 06-22-2013, 09:27 PM
Thank you very much for the new info! I didn't mention before, but the oil pressure sending unit was also replaced.
ill give my engine some good cleaning and scrubbing when I can get to a car hoist.
another question... would a thicker oil cause the oil to leak faster? im thinking about running 15w 50.
Old 06-22-2013, 10:16 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
The opposite. A heavier weight oil will leak less.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 06-24-2013, 03:07 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Red face
Are you seriously considering changing the "rate of leak" by going for a thicker oil
In my 20+ years of building engines I have not yet heard such...
I know Alcohol thins blood, now how do I thicken it
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 06-24-2013, 07:27 AM
D'oh, You Kids!
You just did.
And eating plenty of fatty meat will help thicken your blood.
Quotes to live by:
BMW-CCA #441426
Old 06-24-2013, 10:20 AM
It was just a question guys... ha!
but I saw in other forums that people were slowing leaks by going to a thicker oil.
Kamotors, where will this oil return tube be located? I cant find it on a part diagram.
and remember, the majority of my leaking is dripping from the middle of the subframe, also oil is now leaking from what appears to be a steel support of some sort near the back of the tranny.
Old 06-24-2013, 02:24 PM
D'oh, You Kids!
The oil return tube is the tube going from the head to the oil pan on the driver's side of the engine.
Quotes to live by:
BMW-CCA #441426
Old 06-24-2013, 08:07 PM
downhiller's Avatar
livin large
its a bigger molecule. also takes that light knock out of a motor is youre wanting to sale your car
Old 06-25-2013, 03:49 AM
Nick323's Avatar
Nick's Toys
Wink
I now see the light
Drinking large quantities of Alcohol And eating plenty of fatty meat will help
Therefore I will aslo continue running my Diffs & gearboxes on a mixture of banana peels & sawdust...
I know that we used to get worried, when RandLovers stopped leaking oil
Old 06-26-2013, 11:21 AM
Guys I cant see oil leaking from my oil return tube! Are there any other places that I could possible leaking oil from?
you can see ALOT of the oil dripping down from the suspension arm on the passenger side of the engine block. its just gathering oil.
I tried cleaning as much as I could, but I just cant find anything.
Old 06-26-2013, 08:16 PM
downhiller's Avatar
livin large
head gasket, valve cover gasket, oil filter, oil cooler line (if installed), oil pan gasket, cracked pan, cracked block
Old 06-29-2013, 01:25 AM
BMWFatherFigure's Avatar
Old School
Clean clean clean and look. Use a mirror. That much oil should be obvious. If you still cant find it - clean, run, and then pull off manifolds. If that fails take the engine out.
Current:
E38 Parts Car
Previous:
Old 07-04-2013, 11:17 AM
cjmertz cjmertz is offline
Mein Auto: 325i
Has this oil leak issue been resolved? here's a longshot...I once found the oil press swx leaking, engine oil was being pumped thru the engine electrical harness..and across the fire wall...yes,from the bootie on the swx and INTO the harness via the heat shrink tubing used to protect the oil press swx wire in the harness loom.
Crazy I know but true..., The O/P SWX bootie was so tightly esealed to the swx and harness there was no visual sign of oil at the SWX...only when removing the bootie on the swx was the leak found.
Give the O/P a good look. Good luck
Old 07-08-2013, 04:59 AM
Nick323's Avatar
Nick's Toys
cimertz, that sounds like a Randlover story
Where the breather pumps the oil through the hatrness onto & into the ECU under the seat
Old 07-09-2013, 04:44 AM
Mein Auto: 325i
NICK......must be in the genes?
