Old 06-20-2013, 02:09 PM
kvasg kvasg is offline
Mein Auto: 325i
Fuel Pump Sensor
Hello BMWfanatics.
Has this issue happened to anyone of you? I have a 2001 325i (160k) miles. Today while heading back to work from lunch, my car wouldn't start. It would start for few seconds and immediately shut off. Lights, and everything work in the car. So I ended up getting it towed to my house and after it was back on the ground, I started and it worked. The AAA towing person stated it was probably a Fuel Pump sensor. Any advice? I'm afraid to drive this and it turns out to be another issue like this again. My check engine light didn't come either.
Old 06-20-2013, 05:43 PM
LOS842 LOS842 is offline
Send a message via Yahoo to LOS842
Mein Auto: 325 xi
Re: Fuel Pump Sensor
This issue jus happened to my 2003 325xi I called the dealer to see if it was under warranty and its not and it would cost me 1200 they are crazy
Old 06-20-2013, 10:30 PM
Mein Auto: '04 330Ci 6-speed
Probably needs a new fuel pump. Not sensor. What is a fuel pump sensor??
Look up DIY on youtube
Part is around 130 and takes 40 minutes if you can DIY well.
Old 06-21-2013, 12:18 PM
moemeadors moemeadors is offline
Mein Auto: 2002 325ci convertible
Just finished with this problem. Fuel pump. exact same problem. Checked it by the Youtube video with volt meter at harnass. Listen for the pump with the back seat up...if it is running, it isi obvious. get the right fuel line hose clamps. Rock auto has a great price, about 90 cheaper than advance.
Old 06-21-2013, 12:26 PM
Mein Auto: 325i
Thanks everyone. I guess i'm confused on why it would work at random times? Today when i started it, its running as well. I spoke with my mobile mechanic and since I didn't get the check engine light, what is the best way for him to see if it is the fuel pump or sensor? How would i know its not the sensor?
Old 06-21-2013, 01:42 PM
mawana's Avatar
mawana mawana is offline
Mein Auto: e46 ZHP
Warranty!!!
"Common sense is the collection of prejudices acquired by age 18." ~ Albert Einstein
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 06-21-2013, 02:36 PM
Mein Auto: 325i
Looks like, the warranty has passed it. The fuel pump warranty is only for 10 years or 120k miles. I have 12 years and 160k miles on my car.
Any way to really be sure its the fuel pump?
Old 06-21-2013, 05:39 PM
Fast Bob's Avatar
Keeping it surreal
Is this a SULEV car ?
The road goes ever onward....
(R.I.P. Jever)
Old 06-21-2013, 10:34 PM
Look up the word erratic.
Old 06-21-2013, 10:50 PM
Fast Bob's Avatar
Keeping it surreal
What is a fuel pump sensor ? What purpose would it serve ?
Do you mean relay, and not "sensor" ?
(R.I.P. Jever)
Old 06-22-2013, 10:10 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Might be saying "sender" so basically the pump but could be the relay or other typical items
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 06-22-2013, 12:01 PM
+1
Let's get some feedback here.
Old 06-24-2013, 07:02 AM
STS42 STS42 is offline
Mein Auto: 2005 330 cic
I had this happen at 51k on a trip. A bmw dealer replaced the fuel pump and it failed again, it turned out to be the fuel pump relay that my home dealer diagnosed.
Old 06-24-2013, 07:51 AM
Don't forget in a pinch, can always swap wiith the horn relay to get running again.
Old 06-27-2013, 12:46 PM
my fuel pump problem was...erratic. annoyingly so. you can test at the harness and/or schrader valve on the fuel rail.
