Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 06-24-2013, 03:04 PM
bruzda bruzda is offline
Mein Auto: 2008 535 xi
Help with Halogen to LED fog light install on an E60
I have an 2008 535xi. I upgraded my halogen angel eyes to LED bc one went out, and decided to do the same with my halogen fog lights. I installed the the passenger side fog light with some difficulty by removing the headlight and also going through the wheel well. Going through the top alone ,where the headlight was, was next to impossible with the tight space. I found going through both spaces helped. The problem I am running into is on the driver side. There is a windshield wiper fluid reservoir behind the fog light, which makes it it impossible to access from the wheel well. I have search everywhere on various forums and the web with no success. I can't see how I can install the LED fog light through the top alone. There is just too much to install and secure and little room to work. Also, i don't think I am skilled enough to remove the bumper. Any help would be greatly appreciated.
Old 07-08-2013, 09:47 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Bumper removal is not that hard. It will help to have another set of hands available to take the bumper off and put back on so you don't scratch your headlights or fenders.
Not sure if there are videos for the E60s but try youtubing the process. It's not that bad and you'll have MUCH more space to work with.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
