Grinding noise when turning... - Bimmerfest - BMW Forums
Old 12-14-2010, 09:46 PM
moiz21's Avatar
moiz21 moiz21 is offline
Mein Auto: '99 323i 5-Spd
So quick question for ya guys. I get a grinding noise when making right hand turns only lately. And it's only when the car is cold. Once it warms up the noise goes away. Doesnt make a difference if I break or not during the turn. Any suggestions?
P.S. I've tried doing a search but get so many different possibilities. Was wondering if there is a way to narrow down the issue. Can give more info as needed. Thanks in advance to everyone.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S/ 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
Old 12-15-2010, 04:56 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
First thing I would try, if you have not done it already, is to replace the power steering fluid. Use Dextron III compatible ATF. There is a link in the wiki at the top of the page on how to do this. Very simple, cheap, and worth a try. Could also be a wheel bearing going bad. Try jacking up the left front of the car and see if the left front wheel is rough, or if there is any play when turning by hand to rule that out
Old 12-15-2010, 08:04 PM
AzNMpower32's Avatar
Tar Heel Faithful
+1. Replace the PS reservoir fluid (which is Dex III ATF) if you haven't done so recently.
Old 12-15-2010, 08:18 PM
moiz21's Avatar
I'll definitely give the PS fluid a change. Easy enough DIY.
Is it still likely to be that even though the grinding is only coming from one side?
MODS
Old 12-16-2010, 04:22 AM
gesoffen gesoffen is offline
Mein Auto: Rainbow Unicorn!
More details please moiz!
Does the grinding noise happen while stationary (i.e. with the wheels not moving)? Does it happen only in fast turns? Is it coming from up high? Or down low?
If the grinding happens while stationatry, I'd suspect strut top bearing if the noise sounds like its coming from behind the dash/base of the windshield or bushings/ball joints if coming from the footwell area. If it only happens while moving, my first move would be to pull the front wheels off and inspect the brake pads/rotors (inner and outer pads) to see if they are near the end of life. If you have any uneven pad wear, you could be down to the rotor backing on one or more pads before the wear sensor goes turns on. This is especially true if the rotors are worn too (likely).
----Brian
Old 12-16-2010, 05:13 AM
moiz21's Avatar
It is not making any noise at all while stationary. And it makes noise when taking turns of varying speeds. Not necessarily fast turns only. But if I take turns very slow it will make less noise than if I take it at average speed. And the noise seems to be coming from down low in the footwell area. And I'm fairly certain it isn't the pads cause I had them changes a few months ago.
MODS
Old 12-16-2010, 05:58 PM
sergdman sergdman is offline
Mein Auto: 03 BMW 540i6
Let me know how you make out as my car is having a similar problem. Does yours make noise if your not moving, but turn the steering wheel all the way to the left or right when you first start it?
Old 12-16-2010, 08:25 PM
EWeis EWeis is offline
Mein Auto: 1999 328i
I vote for a bad front left wheel bearing.....first thing I think of when I hear "grinding" and "turning" in the same sentence.
Sent from my HERO200 using BimmerApp
Old 12-28-2010, 02:55 PM
joebry joebry is offline
Mein Auto: 525 & 325
I posted something on this same topic a few weeks ago. My scraping or grinding only happens when I turn to the right and it happens almost regardless of the speed. I can go very slow and easy and it does not scrape but anything other than a crawl and the noise is there.
It does not happen turning left.
If it is power steering fluid, why not scrape when turning right or left?
Old 12-29-2010, 06:29 AM
MicahO's Avatar
MicahO MicahO is offline
In my own cars again
Mein Auto: 330i ZHP
Ditto on the bearing, though it could be front or rear. The noise probably abates when turning to one side. You can figure out which side it is by moving back and forth in slow slalom-like motions. If the noise is greater when turning left, it's a right-side bearing. If the noise is greater when turning right, it's a left-side bearing.
If it's only a gentle grating right now, let it be. As the bearing gets worse, it will turn into an intrusive helicopter-like sound which is easier to locate front vs. rear.
Also, as it's winter and we are getting some sand/salt/gravel on the roads, it could be as simple as some grit or a pebble in the brake caliper or the parking brake drum. Here's to hoping!
--Micah O'C
CCA 193374
'88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion
'92 M5 Touring - BL01001 - first M5 Touring ever built
2017 M2 V887285 - Mineral Grey, 6MT
'04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10
UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
Old 12-29-2010, 06:37 AM
If it is the bearing, what is a ball park estimate for fixing it on a 2003 525i ?
Old 12-29-2010, 06:41 AM
MicahO's Avatar
Mein Auto: 330i ZHP
Couldn't say as I haven't had to do it on an e39. I do think that the e39 rear bearing is easier to do than the PITA press-fit-in-the-trailing-arm e46? You'd have to look for a DIY to see how it goes.....
--Micah O'C
CCA 193374
Old 12-29-2010, 06:45 AM
Thanks.
Old 12-29-2010, 06:32 PM
jinda's Avatar
jinda jinda is offline
Mein Auto: 2013 X1 xDrive35i MSport
I think you can get better answer for that question from the series 5 forum
2013 X1 x35i M Sport
Past:
2011 Mazda CX7 AWD Sport
2004 BMW 330i ZSP/ZPP
2008 Hummer H3
2005 Honda Civic VTi
1997 Honda Civic ESi
1996 Nissan Sentra SS EXi
Old 12-30-2010, 04:10 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
I have the same vehicle...2000, 323i and had the same grinding noise last week when turning the steering wheel in either direction...seemed to go away when it was warmed up or warm outside?
I jacked the car, wheel bearings, Control Arms and CABS all in good order..and no noise when car is jacked up and steering wheel was moved back and forth etc. all was smooth.
I replaced the struts this past summer and also remembered the new bump stops were very tight when slipped over the strut rod, so I gambled / guessed that it might be the rubber bump stop grinding on the bottom of the strut mount. I very lightly greased the top of the strut bump stop- between the bump stop and the mount and the noise went away.
However, it also warmed back up down here in FL so I am not sure, just yet, that I fixed anything. I really suspected the seals in the rack and pinion steering rack or the power steering pump itself as going south. Wife said she has not heard the noise today..but it is 65 degrees out today.
Still working it and will keep you posted when I know for sure...please do the same.
Old 06-24-2013, 01:49 PM
jakej90 jakej90 is offline
Mein Auto: 328i
Anyone find a solution to this problem? My car is doing the exact same thing as described by the OP.
Old 06-24-2013, 04:29 PM
Well, in a manner of speaking I found the solution. I had it towed in and the BMW fixed it and it was a couple of thousand dollars.
I have since gotten a new car so I do not have the bill to tell you exactly what work was done.
Old 06-25-2013, 07:38 AM
Mein Auto: 328i
Why'd you have to tow it? I can't imagine the issue caused the car to be nonoperational
Old 06-25-2013, 08:17 AM
I am about ten miles from the dealership and losing my front end was not what I wanted to do on the interstate. Since I did not know what it was, it seemed like the smart thing to do.
