Old 06-24-2013, 09:05 PM
ericwest ericwest is offline
Mein Auto: bmw 1999 323i
transmission light came on for 10 minutes then off. would there be an error code ??
the transmission light came on for 10 minutes..car would hardly move...no power...turned it off and 10 minutes later I started the car and it drove great...and no light...would an error code be stored??...if so where?...I did the obd2 scan and it shows no error codes..is there a different way to check for trans error codes??..or is it just the obd system...if its the obd system how come I can not find an error code when I scan??..
ANY HELP WOULD BE GREAT!!
Old 06-25-2013, 05:09 PM
BMW318i_E36 BMW318i_E36 is offline
Mein Auto: 2011 BMW 328i, 11 X5 35d
Scary ! Go show your mechanic and let us know, what it is ?
Probably TCM ?
Old 06-26-2013, 06:25 AM
Kamikaze1 Kamikaze1 is offline
Mein Auto: 318i E46
I have a very similar issue. Please read my thread posted today.
Old 06-26-2013, 06:26 AM
Mein Auto: 318i E46
Did you turned the key to Position 2 and then plugged the scanner?
Old 06-26-2013, 07:29 AM
I plugged the scanner in first...then turned on the key...should I have turned on the key first? ...I will look for your post
Old 07-02-2013, 05:36 AM
Mein Auto: 318i E46
My bad. You are right
You will have to plug the scanner first. Then turn the key to Position 2.
Cheers
Old 07-02-2013, 02:23 PM
k0l0k0l0 k0l0k0l0 is offline
Mein Auto: 1999 323i
I have a similar issue with my automatic 323i. Usually when the car has to downshift when going uphill, per say, is when the light comes on from time to time. I definitely feel a drop in power and the car tends to rev high. The car had almost 200k miles when I replaced the transmission and now nearing 300k, the problem returned. Although, my light turns off after about 1 min not 10min and it doesn't do it often. I surely do not know if we both have the same issue, but after all the miles and money, I just deal with the nuisance when it happens.
In short: I don't know what the issue is, but I am interested to find out as well!
Best of luck to you!
