Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 05-06-2013, 11:30 PM
TipsyWolf TipsyWolf is offline
Mein Auto: bmw 118i F20
Need your advice, guys. Bmw 118i F20
Hey guys.
Got a bit of discussion in my mind with a friend of mine. There is BMW 118i F20
pic link http://http://www.google.ru/imgres?n...5&tx=139&ty=66
The bottom line is info about cooling of supercharger. I've hear though the grapevine that now it not nessecary for waiting couple minutes before shutting down engine. Because new (f20) bmw has some sort of liquid in there and it hepls to keeping temperature of supercharger down, but i don't know about it at all. is it right ? or I still should give for my bmw some period of time to cool it. ?
with best regards from russia._a_
Old 05-14-2013, 06:25 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Most turbo charge cars have a intercooler to cool the engine and the fan will run for 30 sec or so after shutting down.... you will be fine here
My last car I installed a timer that let the fan run a bit longer than usual after switching off the engine...
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 05-15-2013, 02:10 AM
thx for answer, but I was writing about turbocharger, not engine. and it's my first time I hear that intercooler cools engine. it cools hot air after turbocharger to put in cylinders. the coolest air you have the more air 02 (oxygen) you can put in cylinder. intercooler has a bit of other functionality. am i mislead ?
Old 06-26-2013, 08:08 AM
DslDwg DslDwg is offline
Mein Auto: 2014 Z4 35is
You're exactly correct. When any device (turbocharger, supercharger, blower) compresses air it raises the temperature of the air. The intercooler cools the air coming from the turbocharger giving additional efficiency to the combustion process.
People have many different theories about cooling turbochargers. Many that have highly modified cars will even add turbo timers which will keep the car running for a specified period of time and then shut the car down so you don't have to sit in the car and wait.
My theory is this if you drive your turbocharged car normally around town and then drive slowly through your neighborhood and then park your car and shut it off you're going to be fine.
If you just did a drag race down your street and as you're pulling into your driveway before your even stopped you shut off the engine and coast into the garage you may have some problems.
My concern with things like turbo timers has always been this. For most cars they cool most efficiently when fresh air is passing over the radiator as the car moves forward. When you park the engine is cooling down because it is no longer loaded but if there is the wall of a garage directly in front of the car it may not be getting the best source of cool air to help with the cooling process.
My opinion says - drive fast and hard if you want but about two minutes out from you place take it easy keep the engine lightly loaded and at lower rpm's - park and shut off your car immediately and you should be fine.
Old 06-26-2013, 08:50 AM
DslDwg, thx a lot !!!
Old 10-07-2014, 08:30 AM
arabyh arabyh is offline
Mein Auto:
T
Old 10-07-2014, 01:02 PM
Angelbones Angelbones is offline
Mein Auto: 2014 V.O. 228i
Good explanation DslDwg. To relay my past experience with intercooling, in 1986 I bought a brand new Buick Grand National and that was the first of two years that had the intercooler. I took it to the drag strip a couple times. I was always very careful about keeping engine temperature down and would keep engine off while waiting. The car was a rocket before it had warmed up and I wish I could have trailered it to the strip to get the best times. I miss that car a lot but with my Bimmer, I suppose the more things change the more they stay the same. Just think nearly 30 years ago, intercoolers were practically unheard of in production and now BMW and other manufacturers are seeing the benefits. Buick did something with a V-6 that is now commonplace in 4 cylinders. Gotta love this 2nd golden age of fast cars.
