Old 06-22-2013, 08:49 PM
drzoom drzoom is offline
Mein Auto: 2001 330i, 2009 650i
Transmission reset and standard/sport mode
Hi All,
One of the first things that I did when I recently bought my e63 was the transmission reset. I wasn't happy with an often jerky 5th gear shift. That problem disappeared after the reset and I've been happy except when in sport. That problem is still there, so I'm wondering whether redoing the reset with sport mode selected would reset the transmission for sport. Ay ideas or prior experience?
Thanks in advance.
Drzoom
Old 06-23-2013, 07:48 PM
HerbP HerbP is online now
I would have your fluid level checked, or changed. If the fluid is low, you can possibly get a hard shift. Changing the fluid & filter will usually resolve most harsh shifting problems. There have been some firmware updates to resolve some issues with harsh shifts also.
Good Luck!
Old 06-24-2013, 12:40 PM
645/333's Avatar
645/333 645/333 is offline
Michael
To my knowledge transmission reset does not affect or is affected by sports mode. So as HerbP mentioned you may need to see if you have a fluid leak?????
Old 06-27-2013, 06:02 PM
Thanks guys. Since the shifts in normal mode are like butta, I'm not suspecting a physical issue with the transmission. But, a software issue might be the problem, since I'm guessing that's basically what sport mode is. At any rate, I've gone ahead and redone the reset, only this time, I put it in sport mode before pressing the gas pedal. It seems better, but I'll update the thread after I've had a chance to drive it some more.
Cheers!
2009 650i Sport
