Old 06-25-2013, 06:36 PM
djcwardog djcwardog is offline
V-8 Driver
Mein Auto: 2007 650i 6MT
Dension is working!
I followed the steps and added the two items to cas and lma, then did the default coding. Success!
My in-car bluetooth is still acting up same as it was when i bought the car. It won't fully sync w my Bberry 9900, and a contacts transfer fails right away, but the phone flashes the blue light, while the car fails to show me any bars for signal strength at the bottom of screen. Suspect the TCU as dealer said when I described these symptoms. However, boldened by the coding success of adding a better iPod solution than BMW ever offered for these CCC cars, I have a feeling that I can use my BMTechnic software suite to diagnose a few things and perhaps upload an update to the phone pairing list?
Any thoughts for me, is a new TCU the answer and if so, tips on getting it?
What a great group and thanks again!
djcwardog: 2007 650i 0440/LCGE, 6MT, Sport, Nav, HUD, NiVi (w pin swap in CIC), HD Radio (from CIC), CDC, SiriusXM. Coding: no lawyer screen (CIC), fan speed LED seen on "auto" (with an LCI-IHKA), turn signals in HUD. Complete: CIC.C1A retrofit>E90.SSD >E90-E60 merged CIC.trc >CMEDIAR.C05 coded Combox, w/ ConnectedDrive, Plug-In, etc., Verde 19" wheels, DINAN CAI, BAVSOUND Stage One Speakers and Ghost Underseat Subs, DIRAC 752 Individual Audio retrofit amp (up from L7).
Old 06-26-2013, 08:20 AM
V-8 Driver
BT Solved - Sync then do a battery pull on the phone!
Got that tip right here on the forum while doing a search for how to update the appropriate modules in the car for "program Bluetooth update" that the dealers were doing for a while - owners had to pay the first 99 Euros... So, if the phone is now syncing and the address book shows up and calls sound good - no worries!
One more concern - after having the battery disconnected for 20 minutes, now I notice that my climate system is directing the air flow from top and bottom vents - but not much out of the vents in the left center and right of the dash. I looked at the auto program stuff in iDrive for ventilation but no luck. What have I missed and is this usual after a battery disconnect? Otherwise, car drives fine and sound system is great with the Dension onboard!
Old 06-27-2013, 09:43 PM
V-8 Driver
Updates - vents still not working properly
Made sure I had coded both the +IPOD and +KMP3 in CAS and LMA, then used the "process car" followed by "code car" commands to get all the modules default coded based off of the CAs and LMA FA Writes done first. I still have the climate control issue - air blowing out of defroster vents. I did notice that now my vent controls showed that they were set for no air through center vents. However, when I used iDrive to roll those out to the right to demand air, the flow did not change - still coming out by windshield. Have I buggered up the actual LHCA climate control module - which is part of the box with knobs? Anybody seen this before?
Old 10-10-2013, 12:19 AM
Liquidsilver Liquidsilver is offline
New to BMWs
Mein Auto: 07 328i (My baby Blu)
Where can I purchase the software and cable from? I went to the website http://www.bmtechnic.co.uk, but it seems that their site is down. I'm tired of paying $90 a pop for clearing codes, programming batteries, and after regular maintenance.
Old 10-10-2013, 07:11 AM
roseng's Avatar
roseng roseng is offline
Read this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=678446
Old 10-10-2013, 08:27 AM
New to BMWs
Oh man. It seems I'm 8 months to late! Would you guys be able to recommend an other easy to use software that will pull all the error codes and allow me to program my car??
Old 10-12-2013, 06:20 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Answered your Post here:
http://www.bimmerfest.com/forums/sho...&postcount=268
Old 11-18-2013, 09:34 AM
col3356 col3356 is offline
Mein Auto: 745i 2005 individual LPG
hi, im having a problem using my cable for the first time ?, its saying error code 200.159, not 299.159, can anyone tell me what my code means please.
thanks for any help
Colin UK
Old 11-18-2013, 12:05 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
thanks for any help
Colin UK
I take it you are using DIS? If so this error is usually related to blocked comms between the real & virtual machine. Here's a few things to check:
- Is your firewall turned off (needs to be).
- Is anti-virus off (can cause problems).
- What version of Ediabas are you running? (Later versions don't work for DIS set up).
Old 11-18-2013, 01:01 PM
HerbP HerbP is offline
thanks for any help
Colin UK
What system are you using? The cable has to be plugged into the same port, every time.
Old 11-20-2013, 01:12 PM
reply
Hi, thanks for replies, im not that good on computers after I suffered 2 strokes and have some brain damage/memory loss etc, anyway I bought a BMTechnic cable with auto install, then I fell ill for a few weeks after loading it and then I forgot which connection I used out of 3 options ? but still managed to delete all errors/lights, but then trying to try recoding some options eg keyless entry etc that I lost when my battery went flat, its now saying the error connecting code is 200.159 my laptop runs on windows 7, I have stopped my anti-virus and firewall, and same code comes up, I don't know what ediabas is ? sorry.
thanks for reading
Colin
Old 11-20-2013, 06:16 PM
How far are you getting to before the system crashes? Is the BMTechnic software panel loading up? It sounds like something updated your computer, & deleted unwanted files?
Old 11-22-2013, 07:51 AM
2BAGolfer's Avatar
2BAGolfer 2BAGolfer is offline
Send a message via ICQ to 2BAGolfer
Mein Auto: 2005 645 Ci
I must have missed the special rate period. I just ordered the BM Technic and it wasnt $63. I paid $179, still well worth it if I can code the vehicle with it as well as monitor my vehicles codes.
Old 04-21-2014, 10:26 PM
steve650iguy steve650iguy is offline
Mein Auto: 06' 650i SMG
@Rebel.ranter good stuff thank you.
The document NCS expert mode coding.pdf is prompting for a password to open. can you share that?
Old 04-22-2014, 12:02 AM
Password is bmwcoding.com
I keep meaning to remove that password!
Old 04-22-2014, 09:32 AM
great! thanks
Old 11-16-2015, 05:07 PM
DeNERO DeNERO is offline
Mein Auto: 2006 X3 E83
Where to buy the package
Originally Posted by All-Or-Nothing View Post
Since I plan on keeping my 6er for a very long time (probably forever) I decided to get me some diagnostic cables and software just to help when I do have issues in the future.
Another forum member (rebel.ranter) suggested I try the BM Technic Diagnostic Cable and the software that comes with it. Seeing all the problems people have installing those programs and realizing my.....ummm....lack of appropriate computer knowledge I decided it was my best option.
Here is what you get along with the cable.....
All of this for...what cost me $58 and it truly is a click and install process. No fiddling with registries or command line prompts just click and wait.
With the minimal requirements for operating this hardware/software I found an old Atom powered netbook my daughter had long since abandoned and hooked up an external DVD drive and i was off to the races.
Here are some shots of the install process...
Literally 8 minutes later or roughly the time it took me to tell my 2 year old daughter that throwing her crayons at the TV was not nice....and the cable was recognized and installed.
I won't post all of the loading screens but 2 hours later and everything was installed on the laptop and I'mm ready to screw up my ECU.....Woo Hoo
I don't know if there is a better package online somewhere but this just seems like the steal of the century. Especially for anyone doing DIYs or wanting to do the random programing or whatever. They have a forum for help and the guys are extremely nice and helpful. I can't wait to hook it up and see what I can do.
P.S. I'm doing this right now
Hi, please care to share the link to where you purchased the package? (Cable and software)
Old 11-16-2015, 05:22 PM
BM Technic is no longer in business. There are two other vendors that sell similar one click installations:
- www.bcables.com
- www.cable-shack.co.uk
Current cars
1996 e36 320iC (convertible)
2006 e63 630i Sport w/SMG
2007 e63 M6
Previous Cars: 2002 e39 525iA Sport, 1994 e36 318i, 1990 e34 520i, 1989 e30 325i, 1986 e30 316
Old 11-16-2015, 05:39 PM
Thank you.
