Old 06-22-2013, 02:29 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Just hit 60,000 miles. Transmission Service?
I just recently hit the 60k mark on the car and I was wondering if any of you guys have done the transmission oil and pan change for the AT-equipped cars. I would appreciate it if I can get advice for which fluid to use for the AT and the part number for the pan.
Once a 6'er, always a 6'er.
Old 06-22-2013, 07:41 PM
Yorgi's Avatar
Yorgi Yorgi is offline
The oil is not cheap, about $200 I think.
Here is a kit with oil and pan from ECS Tuning.
Here is decent thread on transmission oil but there are many out there if you do a search.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 06-23-2013, 01:55 AM
07 E63650i's Avatar
Freude am Fahren
Thanks for the advice Yorgi! Will definitely need to do this soon.
Old 06-23-2013, 03:58 AM
mfelsoci mfelsoci is offline
Mein Auto: 2004 645ci
I had my pan replaced at the dealership due to a small drip. No further problems. If you are not leaking or low on fluid I would suggest not doing anything. Somethings are better left alone. And yes, the replacement fluid is not cheap.
CURRENT:
BMW 323i
BMW 645ci
Lexus SC 300
Ford F150
Dodge Ram
Old 06-23-2013, 04:56 AM
roseng's Avatar
roseng roseng is offline
When I hit 50k miles I had the brake fluid done by my Indie. I asked him about changing the trans fluid then. He's a former dealer service guy. He said unless there is some problem, don't mess with the trans. I like that he just didn't just take my $$$ and do the fluid change. I think I'll take his advice.
I have a 99 ford expedition with 260k mikes and the trans is just fine.
Old 06-23-2013, 06:11 AM
greco2000's Avatar
greco2000 greco2000 is offline
Mein Auto: 2008 650i LCI
When my 7 series hit that level, I changed mine. I was very happy with the outcome and sold the car at +200,000km with no tranny issues. About a $400 job at an Indy. The dealer calls the fluid "liquid gold" and licks it up with a special lock because its to expensive. Lol
2012 BMW M6 CONVERTIBLE
Old 06-24-2013, 11:50 PM
07 E63650i's Avatar
Freude am Fahren
Thanks to all of you guys for your input. I thought about this and decided that I'm going to have an Indy do the transmission service as good preventative maintenance.
Old 06-26-2013, 08:57 AM
WDKIK WDKIK is offline
Wilma
Mein Auto: Z3 3.0i Road, 650i, 328xd
My Indie advises against doing this oil change...They claim that there is a possibility that the smooth gear changes are lost, and that changing the oil will not help in the majority of cases get past the 150K miles before transmision intervention is required...My 650 is at 63K miles and my 325xi, is at ~160K miles, never had the transmission oil changed, or had an intervention yet...fingers crossed...
Old 06-27-2013, 01:01 AM
etnav382 etnav382 is offline
Mein Auto: 06 550i
Hi, I don't have a 6 but we have the same tranny. I got my fluid change kit from here http://www.thectsc.com/index.php?p=c...parent=50&pg=1. I also replaced my mechatronic sleeve while I had the car up since the dealer had told me it was leaking. I then followed the DIY here (pics don't work) http://forums.5series.net/diy-do-you...-refill-88129/ for the fluid filling.
It really quite easy doing just the fluid. There's a drain hole and a fill hole and here's the tightening pattern for the new pan http://www.thectsc.com/index.php?p=p...e_id=tech_info.
But for $400 at an Indy that's only $150 more than the kit, not a bad deal either, especially if you don't have a lift available.
Old 06-29-2013, 12:07 PM
07 E63650i's Avatar
Freude am Fahren
Thanks for helping out.
