5 Series DIY
Old 08-31-2012, 11:28 AM
latitude39 latitude39 is offline
Mein Auto: E46-325xi; F34-328GT
DIY - E60/N52 Cooling system overhaul
Here is my experience on a 2007 530xi, 3.0 liter, 6-cylinder N52, 94k miles. The work was done in May 2012.
Disclaimer
Use this for your reference only. I cannot guarantee the accuracy of what you see here. This project is fairly difficult due to working in tight spaces. This procedure
was assembled from my recollection and from photographs taken during the work. You will certainly find gaps and inconsistencies in my explanations. Use your own best judgment and work safely.
Overview
• Replaced 8 of the 9 HOSES. Only the metal-rubber hybrid was not replaced due to the difficulty of access. Read more below.
• Replaced the COOLANT PUMP.
• Replaced the THERMOSTAT.
• Used new clamps-the quality, exact replacements from BMW.
Parts List
Item____________________P/N____________Qty__Price
Water hose______________11537521049____1____$23.06
Water hose______________11537522999____1____$40.86
Hose clamp L12-14.5_____32411712735____1____$1.02
HoseClamp L42-48________07129952119____3____$2.10
HoseClamp L18-24________07129952109____2____$2.22
this item was not replaced due to access difficulty
Inlet pipe______________11537516414____1____$95.32 Half-steel, half rubber pipe; o-ring & seal included
ASA-Bolt ZNS3___________07129902813____2____$0.99
Water hose______________11537544638____1____$20.76
HoseClamp L23-35________11537547945____1____$2.51
Expansion tank__________17137542986____1____$79.99
Exp. tank cap __________17137516004____1____$6.86 URO brand because it was $8 cheaper
Vent pipe_______________17127521775____1____$29.44
Hose clamp(vent)12-14.5_32411712735____2____$2.04 I think only 1 is needed but I got 2
Return hose ____________17127521778____1____$36.05
Temperature sensor______13621433077____1____$20.97
Supply hose (1)_________17127546064____1____$63.18
Return hose (7)_________17127560160____1____$81.30
Hose clamp _____________17127533721____5____$6.35 These may not all be necessary, depending on condition
Water Pump______________11517586925____1____$382.65 (ebay kit comes with 3-bolt kit!)
Thermostat (Wahler)_____11537549476____1____$95 ($8 more than BMW OEM but photos show a more robust unit)
Hex bolts_______________07119903851____2____$3.06 Attaches thermostat to water pump (aluminum, single-use)
2 Alu bolts for t-stat__11537521049____1____$3.06 (aluminum bolts must *NOT* be re-used)
BMW Coolant_____________82142209769____2____$19.65
My total, including tax & shipping for all component
Approximately $950
All new components – Expansion tank, 9 hoses, pump, thermostat, clamps, hose routing clips, coolant
Electric water pump
Pump, thermostat, "U"-pipe, expansion tank
Motivation to overhaul
I wanted peace of mind.
After 94k miles I was feeling unsure of my E60's cooling system. After all, a coolant system blowout will leave you stranded and may possibly destroy your engine. I won't repeat what is often said about the BMW cooling system reliability. I think it's a pretty good system but needs attention at regular intervals. As I approach 100k miles, I feel like this cooling system was living on borrowed time. Therefore, I decided to shell out nearly $1,000 and my time to make the system reliable.
Electric water pump – an innovation
The high-tech, aluminum-magnesium composite, VALVETRONIC N52 engine is 22 lbs less than its predecessor (Bentley E60, p. 010-11), the venerable and cost-effective M54 that I am used to working on. Also the N52 gains about 3 hp by using an electric water pump, a BMW innovation, as I understand. The water pump for the old M54 can be had for less than $100. If you shop around, you can get the N52 pump for just under $400. The N52 has 9 rubber hoses for just its cooling system, ignoring the heater hoses. The M54 has 3.
The good news is that the water pump is self-diagnosable (Bentley E60, p. 170-2) and can throw codes for:
• Impeller speed deviation
• Stiff operation or blocked by foreign objects
• Incorrect mixture ration coolant / water
• Air in cooling system
A Check Engine Light can prompt you read the codes for impending water pump failure, as I understand it. That sounds good and maybe it's really not necessary to replace the pump until then. From my perspective I like having the peace of mind of a factory-new component for such a critical function. I've gotten a good service life (94k miles) from the original unit, though.
Hose replacement is straightforward
The hoses are all generally well-accessible and were easy to replace. The expansion tank is a cinch. To prevent confusion, take photos. But if you don't it's really not a serious puzzle. Only 1 hose didn't get replaced--more on that, below. Plastic hose-routing clips will be brittle. Buy replacements. I don't have the part numbers. Look on realoem.com.
Pre-assembly of Pump-Thermostat-Assembly (PTA)
The pump and thermostat are physically connected in two ways:
1) A pair of bolts holds them fast to each other, and
2) the U-shaped rubber pipe that feeds coolant from the thermostat to the pump provides a flexible connection when the bolts are removed. Removing the bolts give the PTA freedom of motion for easier installation.
PTA – PumpThermostatAssembly (reconstructed from removed parts) – Viewed as if from the front, right of the engine block; the "radiator" is the white, cardboard box at left.
In order to avoid kinking or stressing the "U" hose that clamps onto the pump and thermostat, I felt it was necessary to orient the pump and thermostat in-place, loosely, in order to allow the "U" hose to be correctly oriented prior to clamping. This is how I did it.
The new pump and thermostat should be attached with the u-shaped hose (see photo) after bolting together the pump and thermostat. The 2 bolts holding them together should then be removed after the PTA has been correctly oriented and the hose clamps tightened. You will need the freedom of motion to get that assembly into the tight space. Once the PTA is put in place, prior to applying final torque to the mounting bolts, connect the pump outlet to the metal-rubber hybrid "INLET PIPE" that attaches to the engine block. Clamp the "INLET PIPE" to the pump outlet. Then the PTA can be bolted together with the two steel bolts.
Here's the step-by-step procedure (recalling from memory). I've ignored telling you to drain the coolant from the system and have left out other details.
1. Remove the old PTA (pump & thermostat) and discard or keep it for a reference as I did.
2. Bolt the new pump and thermostat together, with just enough torque to orient them in their final position. There are 2 steel bolts with 10mm hex heads.
3. Attach the U-shaped hose to connect the pump and thermostat. Think about accessibility of the screws in case you need to access them when the PTA is in place. Tighten the clamps fully.
PN 11537521049 PN 07129952119 (2 pieces)
4. Remove the 2 bolts holding the PTA together. Now, only the U-shaped hose holds the PTA together.
5. Remove the silver, metallic hanger that suspends the right end of the PS high-pressure line, a flexible line. It is held in place by a single 10mm hex-head bolt located inconveniently under the PTA. This allows the PS line to dangle a few inches to give you room to work.
6. Place the PTA in its space and push the pump outlet onto the "INLET PIPE," which should have a new 42-48mm clamp-same as the other 2 clamps on the PTA.
7. Using 2 of the old aluminum pump-mounting bolts attach the pump in place (this is temporary so do not tighten it beyond firm contact).
8. Now the PTA is held in correct orientation to the "INLET PIPE." Torque down the clamp on the rubber section of the "INLET PIPE."
9. Remove the aluminum pump-mounting bolts.
10. Re-hang the PS bracket using the 10mm hex-head bolt. This is the "interesting dexterity challenge" that may give you some consternation. It can be done. It's a PITA for sure. I used a short 12-point combination wrench and with many 1/12th wrench turns the bolt was seated.
11. Bolt together the pump and thermostat using the 2 steel bolts. Tighten to 10Nm, as per Bentley E60, p. 170-15. 10Nm is 7.4 (Seven point four) ft-lbs.
12. Bolt the pump to the engine block using the 3 *new* aluminum bolts. Torque till it feels good or…..........follow Bentley's recommendation of 10Nm + 90-degrees (Bentley E60, p. 170-17). Torque this down ONCE AND ONLY ONCE! The aluminum bolts are to be tightened only once. If you need to back them out then off to the dealership you'll go. My subjective experience with this final 90-degree twist is that I could feel the bolt deforming under the tension as if it were a threaded Tootsie-Roll. It's unnerving for us old-school, steel-bolt guys.
13. The hard part is over.
14. Connect the rest of the hoses using new plastic clips to route them. I don't recall any special challenges.
15. Double-check your connections; close the radiator drain plug.
16. Mix BMW coolant 50/50 with distilled water. I used an old 1-gallon water jug, filling 1 liter of coolant and then 1 liter of distilled water to make 2 liters, which I then poured into the expansion tank. Peek under the car to check for leaks. The system is 10 liters. I was able to put in 8.5+ liters. I'm not too concerned about getting a complete flush. 85% replacement makes me happy.
17. Once the red level indicator pokes up out of the expansion tank to the second bubble, run the "bleed process" according to Bentley. To my recollection it goes: 1) Plug key into ignition, 2) press the "Start" button but do NOT place your foot on the brake-to prevent engine from starting. Again, do NOT start the engine. 3) Turn heat controls to 91 degrees, the top of the scale, and turn the fan on the lowest setting, 4) Press the accelerator pedal to the floor and hold for at least 10 seconds. The ECM will begin the bleeding process. You'll hear water rushing through the pipes and the low hum of the electric motor. This takes 12 minutes. Be patient. When it's done check the level again, topping-off as necessary. I ran the bleed process a second time but Bentley did not recommend this. I don't think it hurts. I was able to top-off after that.
18. Look for leaks. When you are satisfied that everything is sealed, continue.
19. Finish reassembling.
20. Start the engine with the hood open. Look for obvious leaks.
21. Road test around the neighborhood, radio off. Listen and watch the dashboard for lights.
22. Upon success of the previous step, take it for a short road trip to tax the system a bit.
23. Let the car cool, overnight hopefully. Check the coolant level and use a flashlight to inspect for drips.
24. Done.
Random thoughts
The Power Steering high-pressure line is in the way of pump installation. A single bolt holds a hanger for the right end of line. That bolt is attached to the chassis UNDER the PTA by a single bolt with a 10mm hex head. This provides an interesting dexterity challenge to re-mount the PS hanger. This is a key reason for not bolting together the PTA until the end.
The PTA installation will consume a large amount of time. I spent 9 hours with this project but this was my first time and I had only the Bentley manual to give lightweight and non-subjective directions.
The aluminum bolts require a 2-stage torque sequence. Good luck on getting a torque wrench in there-no way. I did it by feel, approximating the 10Nm and following with an "additional 90 degrees." The aluminum bolts are one-use only. Be sure to have 3 new replacements on-hand-I bought a "kit" on eBay that included the pump and the 3 aluminum mounting bolts.
In hindsight, the original hoses were all in fine condition, showing no signs of deterioration. I had gotten no codes from the water pump. Could the cooling system have been ignored until codes were thrown or leaks noticed? Maybe, but I'm glad to have a new cooling system.
The problem hose (called "INLET PIPE" on realoem.com)
PN 11 53 7 516 414
This "hose" is really a hybrid pipe-hose, being made primarily of heavy gauge steel(aluminum??) and having a rubber hose fused to one end. It won't come off without removing the entire exhaust system. I chose to not replace it.
These photos tell the story better than words.
Location of pipe/hose attachment to block
Engine block with pipe in place, without the exhaust manifolds
The other eight replacement hoses went back together without issue. Only the metal-rubber hybrid "INLET PIPE" was not installed. It's metal for a reason. It is connected to the block on cylinder 2, under runners 1 and 2 of the exhaust manifold. Its composition changes from metal (iron/steel) to rubber when it is clear of the heat hazard and must be attached to the pump's output port. I did get a socket on one of the two bolts (the bolt at the 2 o'clock position) holding the unit to the block-I did *not* loosen the bolt. The socket connection was a confidence-inspiring near-straight-on fit. I did this using a mirror and flashlight. It was impossible to connect to the second bolt (at the 7 o'clock position). Even if both bolts could be extracted, I don't think the pipe could be removed from the block because the pipe extends several millimeters from the mounting flange into the engine block. The exhaust manifold for cylinders 1-3 almost contacts the pipe and would prevent the wiggle-room needed to remove the pipe.
Here's a view from the expansion tank (removed), looking downward toward the motor mount. It shows where the "INLET PIPE" would be mounted to the block.
The next photo is a mirror view into the "INLET PIPE" mounting area
You can forget about replacing this pipe unless you're willing to remove the exhaust system. I'm going to wait until when and if this pipe ever starts leaking. I'm betting it will be OK.
The pipe is plugged into the engine deeply. There is not enough room to back it out in these tight confines.
Alternate access
I turned to Bentley to find out how to remove the front manifold (cylinders 1-3) -- the exhaust manifold consists of 2 parts.
• Step 1: "Remove rear manifold." In order to do that, perform step 2, next.
• Step 2: "Remove exhaust system."
Therefore, you have to remove the entire exhaust system from stem-to-stern. I've removed the "exhaust system" before. It consists of a 90-lb 8-foot-long section, connected at the front to the exhaust manifold outlet. Not too hard. But the removal of both exhaust manifolds was making this a very involved project.
I left the pipe in place.
I justified my decision since the coolant in this pipe is the coolest coolant in the entire system since it has already been passed through the radiator and is being sent back into the engine block. The rubber on this pipe has had less exposure to hot coolant than any other pipe in the system.
Expansion tank plug ("blind plug") PN: 11 53 1 436 850
The existing expansion tank has 4 connections, one of which is plugged. You must reuse that plug so pull it off carefully. It's held in-place with the normal clip-type wire bail that is common to the other hoses.
Hose PN 11537522999
The coolest coolant in the system comes from the water pump, goes into the INLET PIPE and into the engine block. There is a take-off pipe on the INLET PIPE that connects to the top connection of the hose shown.
This pipe connects to hose in the previous photo. There is a notch in the hose end that keys onto this tube. The pin on the tube orients the hose properly so you don't have to think about it.
Old 09-19-2012, 05:05 PM
looney53 looney53 is offline
Mein Auto: 07 BMW 530i
Very nice.. Thank You.. I'm also in the process of Replacing the electric water pump, thermostat (Wahler Brand), Serpentine Belt and 2 Gal BMW Coolant.
Old 09-19-2012, 07:45 PM
Have fun. Be sure to take the motor apart and keep the magnet. It's a really strong magnet.
Those hoses were all in good condition when I replaced them. Pretty tough material.
Name:	IMG_8766 resized.jpg
Old 07-05-2013, 06:42 AM
croat croat is offline
Mein Auto: 02 M3
Amazing writeup. Does the cap on expansion tank need to be on or off when doing the bleeding?
Old 07-17-2013, 09:28 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
Outstanding writeup.
A couple of comments, after doing this job yesterday (bad pump, PM the thermostat since I was in there) on my 07, 65K mi E60.
First, the pump control electronics are what fails. Other sites note that intermittent codes are sometimes thrown prior to failure, but realistically you'd need to regularly check the codes in memory every so often, since no one has seen the check engine light go on solid in advance of a "achtung! Stop zee effing car right now!" dash warning.
That said, you can confirm pump failure by trying to start the bleeding routine. It won't start. If you want to confirm it, put a meter on the pump control line while the bleed routine is running and you'll see +6VDC on it, but the pump still won't run. If these are your symptoms, you can be confident that it's a failed pump.
Electrical diagram below. Navigate to engine cooling for your year E60/61 and you'll find wiring color coding, fuse location and control line location. Do yourself a favor and check the fuses before you climb under the car.
http://www.bmw-planet.com/diagrams/r...0e61/index.htm
Second, the above writeup is really well done, so if you use it this is a straightforward but fiddly job for a confident shadetree mechanic. But, I don't recommend it as the first repair you decide to do on a car. You really don't want this job to fail again because of a loose clamp or improperly seated hoseclip...
Third, pump and thermostat are probably a $900-1000 dealer job. DIY with parts from Pelican and Bav Auto are $450-500 or so net of shipping.
Couple of cooling system diagrams attached, as well.
Again, absolutely a great writeup, and it will guide you through the process if you decide to attempt it. Good luck.
ID:	387143   Click image for larger version
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 09-10-2013, 09:20 PM
No, the radiator cap should remain in place during the procedure, IIRC. Sorry for the delay.
Old 09-10-2013, 09:54 PM
Thanks. I hope this is useful to others. My post-mortem thoughts 27k miles later are: 1) don't replace all hoses--only the couple up front that handle the hottest fluid. Inspect other hoses and replace weak rubber as needed, 2) don't replace the expansion tank unless it shows leakage. I have an E46, which has a fairly lightweight expansion tank that is prone to leakage before 100k miles. But the E60 X.tank is solid and beefy. It's also easily accessible. Save your money and wait for leakage if/when that ever happens.
According to Bentley, the pump is supposed to store codes as a result of ongoing self-diagnostics. But this is my wife's car and she won't necessarily pay attention to the "stop zee effing car..." warning. 500 bucks spent every 100k miles is ok by me to prevent a meltdown.
...straightforward but fiddly job for a confident shadetree mechanic.
well said
Comments made inline
Old 09-10-2013, 10:07 PM
Post-Mortem on aftermarket stuff:
Don't do it.
In my list of components, I said I saved $8 on an aftermarket cap for the expansion tank. Well, after 10k miles that part snapped in two. Note to self: stick with OEM
Old 11-25-2013, 09:46 PM
x5homework x5homework is offline
Mein Auto: 02 x5
any idea what this is?
thanks!
ID:	409438   Click image for larger version
Old 12-29-2013, 03:54 PM
06530IDAN 06530IDAN is offline
Mein Auto: 2006 530I, Sports Package
2006 530I (N52 Engine) with active steering
Hey guys,
Thanks for all the useful info on this thread!
I think I am ready to take the challenge. :-)
From the information I gathered, it seems like my car is set up differently (more hoses that are in the way) because it has active steering and Active-Roll Stabilization System.
Please see the picture and the indicated red arrows. If I loosen them (red arrows), will I have enough space to disconnect the water pump and thermostat assemblies? More importantly, am I going to risk any damage to the active steer/active-roll stabilization system?
Thanks!
Daniel
Old 01-01-2014, 07:36 AM
Hey guys,
Happy New Year!
Can someone please tell me if I need to remove the three hoses (see red arrows in the pic) to get access to the water/thermostat assembly?
Or will dropping the sway bar be enough to get those three hoses out of the way?
Thanks!
Daniel
Old 01-01-2014, 07:41 AM
I wonder why my last two posts don't get bumped to the top for people to see?
Old 01-01-2014, 07:44 AM
Hi guys,
My last two posts didn't get bumped to the top for people to see. I am replying to this post simply to see if it would fix the issue.
Thanks.
Old 02-10-2014, 08:26 AM
My Update:
After almost two months (since my purchase of the parts), I finally gained the energy/desire and installed my new water pump and thermostat. It took me a little less than 4.5 hours; and I am so glad I got this project out of the way!
At 83,240, the hoses still look like they can probably last another 80,000 miles. The old pump and thermostat can probably go for another 20,000+ miles. In any case, I know this preventative maintenance will save me money and time in the long run.
More importantly, I want to say the three hoses that I previously asked about do not have to be removed. Lowering the active stabilizer bar was all that was needed for the necessary space to finish the job! I hope this confirmation will put someone at ease when attempting the task some day.
Thank you, OP, PCY, BimmerFan52, my mom (for giving birth to a multi-talented kid, j/k) and everyone (you know who you are) for your help! ;-)
Originally Posted by 06530IDAN View Post
Hey guys,
Happy New Year!
Or will dropping the swap bar be enough to get those three hoses out of the way?
Thanks!
Daniel
Old 02-10-2014, 09:07 AM
Marine0369 Marine0369 is offline
Mein Auto: 2001 Ram 2500 4x4 Cummins
Thanks for the update!
Mike
2009 535i X Drive Premium Monaco Blue
Old 02-10-2014, 10:27 AM
You're welcome, I am glad the update was useful!
I was hesitant to replace the water pump and thermostat because I didn't want to mess up the expensive to replace/fix hydraulic system for my ARS and steering. lol
Old 05-28-2014, 01:47 PM
850csi 850csi is offline
Mein Auto: E90/E61; N52B30^2
Interestingly enough, on my E90, I got several intermittent failures from the water pump (and yellow dash lights) before it completely failed leaving me stranded.
I'm trying to figure out now whether I want to replace the water pump prophylactically in my wife's E61, which I believe has the original pump (but not the original thermostat) at 98k miles.
Anyone know how much tougher this is to DIY on the wagon, which is an x-drive model? I've never done anything bigger than oil/spark plugs so this would be a big step.
Old 05-31-2014, 12:29 PM
blindjoe blindjoe is offline
Mein Auto: e61 530xi
Im having a heck of a time getting your first "remove the PTA" Step done.
Ive got a 530xi, so i can't drop the swaybar to get access to the back supply pipe.
How do I get the pump out? To me, it seems there is a subframe in the way, but obviously you were able to get it out.
I had an oil filter housing gasket leak, so everything under the car is extra unpleasant. It doesn't make it any different, just harder to spend time under there wiggling things.
Old 06-02-2014, 07:11 PM
For anyone with the same problem:
I have a 2006 530xi wagon.
I was trying to follow the bav auto video, but they show removing the block to water pump hose first, to pull out the pump.
With the x drive, there is a subframe in the way and you can't get to the hose.
The solution is to go in from the top. Pull the individual hoses first, then remove the thermostat to pump hose. That will allow you to remove the thermostat housing, and access the back block to pump hose.
Will be putting back together tonight (some of the hoses were in bad shape, and the cylinder head to thermostat hose fell apart as I removed it. Parts didn't come in til today) and will update if there are any more tricks needed.
edit:
Nothing too fancy. Was able to do most of it from the top, in the order as was done above.
The difficult part was getting the thermostat to waterpump hose on the waterpump. Since there is no access to the back of the water pump, the u-shaped hose must be tighened down when installing the pump. Then, you get to wiggle the thermostat on to a floppy u shaped hose. I was able to do it with the help of a breaker bar wiggled to the back of the hose, as something to push against.
Then I re-connected all the small hoses, with the Y-shaped hose to the oil cooler going last. I had that one on first, but it had to come off as you can't get the thermostat on with it in the way.
Temps didn't go above 185 driving to work today, where it was 210 and climbing after my wife got the overheat shutdown message, limped it home, and plugged in the ultragauge I had lying around.
I vote it fixed.
Old 07-15-2014, 05:27 PM
I vote it fixed.
Good work blindjoe and 06530IDAN,
Sorry I wasn't there to help in a timely manner. Even though I'm subscribed to this thread I've managed to ignore the emails, not intentionally. What kind of OP have I been?
I'm glad people have been inspired to do this job...and not get into trouble.
My 530xi is now gone, as of June 30. We've traded for a 328GT (F34 chassis), which is sized like a spacious 5-series and outweighs the E60 by a couple of hundred pounds. The wife loves it. And I love it because it's under warranty and I don't have to work on it. I'm busy enough keeping my '02 325xi running like top. And someone is getting well loved-on E60.
Sport rack: Does anybody need a BMW sport rack for this car? $100 Good condition and has all the correct hardware (plastic liners, rubber booties, manual, torque tool) PM me.
Old 07-15-2014, 05:39 PM
850,
Sorry, I don't know anything about differences on the wagon, though I can't imagine it's any different from my xi. All my photographs were taken on my 530xi. I'll bet it's exactly the same unless you've got the active steering, which my E60 did not have.
Remember, this job is a dexterity challenge as much as anything. It's a bit tight down there so removing components just to get access is the key.
Don't get in over your head though. Good luck and keep us posted.
Feel free to PM me. The one tool that would be useful for getting that 10mm hex-head bolt from underneath the WP and stat would be a 10mm GearWrench ratcheting box-end.
Old 12-25-2014, 07:46 PM
07lilredwagon 07lilredwagon is offline
Mein Auto: 07 e91
This is a phenomenal write up with awesome pics. Im in the middle of overhauling my cooling system which seems to have waited until around 140,000 to start hemorrhaging from every O-ring on almost every coolant line on the car!....I have heard of alternator problems arising because of this problem too....its right near 2 of the upper coolant hoses.
thanks very much for doing this back in July!
JP
Old 12-26-2014, 11:29 AM
I hope you find this useful when you dive in. Yes, keep your alternator dry.
Good luck. Report back if you like. I'm interested in hearing.
JP
Old 01-12-2015, 10:21 PM
RedWagon
Your comment about so many O-rings blowing out has piqued my interest. I have a theory that when our engines overheat, the O-rings get toasted since the temperature gets well above 250F, which is the limit for Buna-N O-rings, according to the O-ring materials charts I've seen.
Did your engine overheat prior to your O-rings failing?
... overhauling my cooling system which seems to have waited until around 140,000 to start hemorrhaging from every O-ring on almost every coolant line on the car!...
JP
Old 01-14-2015, 06:46 AM
Mein Auto: 07 e91
RedWagon
You, know, funny thing you should mention that......
A year and a half ago my water pump went. I was on my way to NH at the time and had just read about the water pump issues as was planning on changing it out....it beat me to it.
The light came on as I was pulling out of a rest stop and I stopped immediately and shut the engine off. maybe 15 seconds after the light came on. So to answer your question...YES it had overheated.
I had to get the job done on the fly in a town I didnt know, but got very lucky and found an awesome place and am very happy...(turns out they left me a bonus too...a 1/4" wobble extension that was nestled down between my steering rack and the frame!)
correlation to the support your theory?...could be!
interesting fact about the type of o-rings BMW uses and their temp limits...This could explain other sites of failure as well.
thanks for the thoughts!
JP
