Old 07-07-2013, 09:58 PM
whytry's Avatar
whytry whytry is offline
Mein Auto: '07 750Li, 68 Camaro
Logic 7 and extra subs install
So I followed this DIY install
http://www.bimmerfest.com/forums/sho...d.php?t=670470
N it was very easy to do. I was able to do this at the same time as I did a replacement on my fried logic 7 amp, just added some extra wires. My question is now that this has been done my battery died I used an older Arc Audio that needed a remote signal, not self sensing power on. So I added a LOC with remote power wire. The problem is this kept my amp on for an extended period of time and killed my battery over the long holiday break.... My question is for anybody else who has done this before how are you able to not kill your battery when it's ran this way? Im open to ideas....
Thx
06 750i - Blk/Blk, Sport pkg, premium pkg, comfort access, ent pkg, convience pkg, 21's, sold
07 750LI - Blk/Blk, Sport, Premium, comfort access, rear DVD, convenience, 21's
68 Camaro - Procharged and injected LS2 in progress
Old 07-08-2013, 01:28 AM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
Thx
Connect the remote on to something that only powers up when the car is on?
Most of the MOST devices are "off" until the car is active. If you tap into it here the power module should be able to shut everything down if worst comes to worst without draining your battery too (assuming your LOC does no amplification and just cleans up the signal and reduces it to low level you should be ok with the power draw).
Old 07-08-2013, 09:30 AM
mrbmwx5 mrbmwx5 is offline
Banned
Mein Auto: 06 750Li
Remote wire should tap into the ignition switch. Or you have to find the factory remote wire on the L7 AMP.
Old 07-08-2013, 12:43 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Thx
Instead of using a LOC with a remote, hook up the remote wire to a relay and tap the other end of the relay into a SWITCHED power source such as the sunroof fuse. I believe that's the only fuse that turns off with the car.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 07-11-2013, 10:46 PM
whytry's Avatar
Can you elaborate more on this? This sounds like the ideal situation using a relay. Where do I tap into it at on the fuse? I've read people doing this using the sunroof signal but it was low voltage like 3.2v if I recall, can't remember where I read it but something like that.... Does adding the relay jump the voltage up when powered on? Please any more info would be greatly appreciated!!!!
I have done this before but used the cigarette lighter in the center console in a Lexus for remote, can't do that on this car.
Old 07-15-2013, 11:30 AM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
The L7 has a power that is switch-able, a relay will be needed if you don't want the amp to add an additional load on the system you are tapping into.
Old 07-15-2013, 01:08 PM
csmeance's Avatar
Mein Auto: 760Li
Originally Posted by Nygel View Post
The L7 has a power that is switch-able, a relay will be need if you don't want the amp to add an additional load on the system you are tapping into.
I wasn't aware of the switched power on the L7 amplifier!
Basically a is a trigger switch. When it gets power it'll click on connecting 2 terminals on the relay. When the power turns off it'll click off breaking the connection on the terminals. That way when you tap into something for a switched power source, you are NOT drawing directly from it but using it only as a trigger. The actual 12V power supply for your amplifier's on switch is hooked up from the battery to 1 terminal on the relay. The other terminal has the wire going from the amplifier's trigger on switch to the relay.
That way when the trigger source turns on, it'll connect the 12V on switch to your Amp thus allowing it to turn on!
lOE Fog Lightsl
Old 07-17-2013, 09:47 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
If the L7 amp in the E65 is like the one in the E9x, there is no remote wire on the amp. The REM wire is pin 13 at the back of the HU.
OP if you use a relay, make sure you fuse both the trigger and supply lines properly. A 1 A fuse on each will take care of it. Place the fuse as close to the power source as possible.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 07-17-2013, 11:19 AM
Nygel's Avatar
here is a diagram
Old 07-17-2013, 03:21 PM
whytry's Avatar
So I can run constant +12 to a relay then run that to the remote wire input on amp?
Old 07-17-2013, 03:57 PM
dsaautocustomz's Avatar
dsaautocustomz dsaautocustomz is offline
Donny A
Mein Auto: 14 Sierra, 13 Denali XL
Their is actually a wire in the trunk driver side right behind the driver tail light, its purple and white i used that as a accessory to power my computer and video interface, i also connected a relay to it.
Old 07-17-2013, 07:39 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Most of these "switched" powers that have been mentioned are part of the MOST? network. The power source will stay on until the system goes asleep. And will turn back on when car is unlocked started etc...whatever makes the system wake up. The only true ignition controlled wire that I am aware of runs into the OBD plug. That is where mine is wired to
Old 07-18-2013, 09:55 AM
whytry's Avatar
What wire is that?
Old 07-18-2013, 09:56 AM
whytry's Avatar
Can you elaborate a little more on this please in terms of what wires goes where on the relay wiring? N have you ever had your battery drain?
Old 07-18-2013, 10:25 AM
Donny A
Re: Logic 7 and extra subs install
Purple white wire in the trunk just splice into that wire and connect it to a 12v relay, after that you have a igtion wire Ive had no drainage problems and kingsilverback is running the same thing
Sent from my SCH-I605 using BimmerApp mobile app
Old 07-18-2013, 11:30 AM
What wire is that?
I believe it Is a green wire
Old 07-18-2013, 11:35 AM
Donny A
Its a purple and white
Old 07-23-2013, 01:01 PM
whytry's Avatar
Ok so I'm gonna try this tonight then!! Thx
whytry's Avatar
here is a diagram
So the 86 connects to the purple/white wire mentioned in the post above correct?
Old 07-23-2013, 02:02 PM
Donny A
Yes it does
Old 07-24-2013, 11:45 AM
whytry's Avatar
Thx ds!!! I just did this last night n hopefully it takes care of the slight battery drain issues I was having!!
Old 07-24-2013, 05:34 PM
Donny A
Ya if your still having a problem run the purple white wire to 87. Then a wire from 30 to your amp or what ever. 85 to ground and 86 to the battery with a 30a fuse
