Old 07-03-2013, 09:10 AM
Punisher745Li's Avatar
Punisher745Li Punisher745Li is offline
BMW Enthusiast
Mein Auto: 2004 745LI
Exclamation DTC OFF = Burning tires!
Decided to give it a try......went to ---->settings---->>>DSC OFF and click DTC ON
Then waiting patiently in the red light for the green, pushed the gas pedal and for my surprise accelerating really fast and burning tires lol...
These are the settings:
1. Default position when you start the car:
The DSC+ system is active. The car has full stability and traction control. This means that the engine power will be cut if the driving wheels start to spin.
2. DTC on - Short press of the DTC button:
When you engage DTC, the DSC system remains active, but the limits at which it will intervene are increased. So the car will wheelspin a bit before engine power is reduced.
3. DSC+ off - Hold DTC button for more than 5 secs
This turns the traction and stability control systems off. The driver has full control and the engine power will not be reduced, no matter how much wheelspin you get or how far the car gets out of shape in a bend.
Officially, BMW state that DTC is for low traction situations, e.g. mud, gravel or ice. However, it's pretty clear that it's also designed to allow for a more sporting drive. Motoring journalists often describe it as emulating an electronic limited slip diff.
ID:	384891   Click image for larger version
ID:	384892   Click image for larger version
ID:	384893   Click image for larger version
Bayerische Motoren Werke
Old 07-03-2013, 10:09 AM
1bad540's Avatar
1bad540 1bad540 is offline
Mein Auto: E65 750i Sport,C5 z51 e46
Pics or it didn't happen.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 07-03-2013, 12:32 PM
wog boy wog boy is offline
Mein Auto: E66 750Li
Save yourself the embarrassment as it only spins one tyre so I was to find out years ago
Old 07-03-2013, 01:52 PM
BMW Enthusiast
Let me tell you that you are wrong.....first of all there's 3 settings
1.- DSC ON - normal driving mode
2.- DTC ON - the DSC still active (there's your one tire spinning version)
3.- DTC OFF - Both tires spin, you are in your own. (careful with this option because all the engine torque is going thru the tires!!!)
Old 07-03-2013, 01:53 PM
BMW Enthusiast
Imma try to take a video, way better than pics..
Old 07-04-2013, 01:16 AM
Chacho2009 Chacho2009 is offline
Mein Auto: 2004 325i
Is the DSC light suppose to always be on or does it turn off every time you turn off the car??
Old 07-04-2013, 02:15 AM
Cool mate, no worries I will try is again next time I am due to replace my tyres, I didn't think our cars had a LSD fitted with all these other safety systems on board?
Old 07-04-2013, 10:04 AM
BMW Enthusiast
Re: DTC OFF = Burning tires!
DSC is always ON....
Sent from my SPH-L720 using BimmerApp mobile app
Old 07-04-2013, 12:35 PM
But is the light that looks like a triangle on when dsc is workin or should the light be off?
Old 07-04-2013, 01:36 PM
BMW Enthusiast
When you have the triangle in the dashboard is totally off
Old 07-04-2013, 01:53 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
If the light is on it means that the system is OFF.
If the system is ON there should not be ANY light ON.
Old 07-04-2013, 02:32 PM
Ok thanks
Old 07-08-2013, 03:47 PM
GPDenver GPDenver is offline
Mein Auto: 2003 745i
OFF=Singular burning tire. The car has an open diff, and will only spin 1 tire no matter how hard you try. I turn it off everytime I get in the car.
Old 07-08-2013, 07:54 PM
Yeah that is what I thought. I couldn't get both wheels to rotate at the same time on dry bitumen hence why I said save yourself the embarrassment in front of your friends
Old 07-14-2013, 12:40 AM
Why does it feel that I have better control when the light is on then??
Old 12-20-2013, 10:31 AM
ssdriver27 ssdriver27 is offline
Mein Auto: 2003 745LI Alpine White
I think you either missed some options or you meant to say DSC off in #3. My car you can have DSC on or off and DTC on or off and any combination you choose.
Im still curious of actual function of dtc vs dsc. All I know is dsc on no spinning. dsc off spins tires. I haven't seen or felt any difference that I can tell with the dtc on or off. Maybe an actual explanation of functionality would clear things up.
2001 Camaro Z28 custom built and custom turbocharged 600+WHP @ 14PSI. (SOLD)
1996 Maxima GXE (commuter/camping/Dogs are coming with, car)
Old 12-20-2013, 10:57 AM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
DTC is for conditions like snow; it allows the tires to slip a little bit before cutting power. It's a relaxed version if traction control between "on" and "off."
Old 12-20-2013, 11:17 AM
that would make sense then, as my car seemed to handle very poorly with DSC on (normal mode) but today I had the dtc on and it handled much better in the snow as the car wasn't constantly trying to stop the tires from spinning at all.
Old 12-20-2013, 03:39 PM
rushmach rushmach is offline
Account Under Review
Mein Auto: 735i
Mine did leave an 11 so both wheels do Spin .. Do we have LSD ?
Old 12-20-2013, 04:35 PM
from what I have read we do not have a limited slip differential
Old 12-20-2013, 04:38 PM
Mein Auto: 735i
Hmmmm i see thanks ss
