Old 06-28-2013, 03:43 AM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
Maybe when you press mode it is trying to select the AUX, which is not installed so it does something strange?
Old 06-28-2013, 10:51 AM
chowdarygm chowdarygm is offline
Mein Auto: BMW 318i E46, 735i E65
Re: BMW E65 Facelift ASK
Originally Posted by PAPER View Post
what do you mean hangs ???
does the Aux volume screen pop up ?
Below is the video showing what's happening when I press the Mode button
Old 06-28-2013, 02:32 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Old 06-28-2013, 04:04 PM
PAPER's Avatar
CRISP & CLEAN
your Ask unit is not communicating with the AT Tuner
correctly . That's why your having problems with the
Mode button .
Try to go into manual station select &
try to select a station to set to one of
your Presets & tell me what happens .
& I'm sorry for the late reply , I have been really busy lately ...
Old 06-29-2013, 08:17 AM
Mode button .
below is the video
Today that AUX plug has arrived but the AUX is still not working...is it anything to do with my ASK being manufactured in July 2005 ?
Old 07-01-2013, 04:54 AM
Mein Auto: E65 745i
I think I know why.
That is a CD based ASK unit and either your MMI or ASK (which would be silly) is coded for Mini Disk (MD)
When you press mode it tries to switch to Mini Disk as its the first source other than radio tuner, but it doesn't exist so it hangs.
Old 07-01-2013, 05:20 AM
Originally Posted by Piers1989 View Post
I think I know why.
Oh.... Could be... Do you know if I can recode the MMI back to CD?
Sent from my HTC One using BimmerApp mobile app
Old 07-01-2013, 05:51 AM
Mein Auto: E65 745i
You can very easily if you have the kit. It would take a few seconds for someone that knows what they're doing.
Old 07-01-2013, 05:56 AM
ya, I have all the coding things setup and have once updated by Car Transmission software successfully
Can do it if someone gives me quick steps
Old 07-01-2013, 06:09 AM
Mein Auto: E65 745i
Have you used NCS Expert before?
You just need to go into the coding file for the MMI and change any reference to MD / minidisk to nicht_aktiv and any reference to CD to aktiv
If you have NCS Dummy installed that will tell you the exact name of the options but im pretty sure its just MD and CD.
The only thing to note if your doing this on your facelift MMI you need to change the build date on NCS Expert's Vehicle Order so you can read / write to it which is a bit of a pain.
Old 07-09-2013, 01:24 PM
AngelE66 AngelE66 is offline
Mein Auto: E66 Alpine White
What is the part number the facelift ASK unit with AUX input?
I have a 2004 E66
Old 02-07-2014, 12:58 AM
Diplomat_745 Diplomat_745 is offline
Mein Auto: 745li
Hey guys, I'm having a little problem with Face-lift Ask unit.
I installed the face-lift unit in my 05 745 and neither the radio or the cd are playing?? And while the face-lift ask is connect the car suddenly shuts off...I installed my original pre-face-lift and it everything(radio, cd) works fine and the car doesn't shut off.
And btw I don't have a face-lift mmi and pdc is not working could that be the case?
Coming soo0n to forums near you!
Old 06-08-2016, 01:20 AM
745760 745760 is offline
Mein Auto: 04 745i / 03 760li
Golden info. Ive just purchased a CD ask to slot into my 04 745i as currently its a MD ask. While out im thinking about fitting an aux input. Tell me please, does the aux input hardware once installed also need a coding upgrade or will the ask automatically see the signal input and override the current selected input as ive seen in a couple of youtube videos. Any info would be greatly appreciated
Old 06-10-2016, 08:27 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
Your MMI will need to be coded to show the "AUX" option. Otherwise AUX will not be selectable.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 06-11-2016, 12:34 AM
Ah right got ya. So when i recode the ask to a cd ask i can do the aux addition then. Ok ebay have the aux input wiring for like less than ten bucks, ill get one on the way and go from there. Thanks again mate
Old 06-11-2016, 02:31 AM
Proel Proel is offline
Mein Auto: Bmw 7 e65 2005 fl
Can i put aux to MD ask unit? My car is 2005 06 facelift
Old 06-11-2016, 02:56 AM
Seems like thats a yes however some coding needs to be done to the mmi for it to show as a selectable option in idrive. Others with more experience may like to offer advice too cheers mate
Old 06-12-2016, 02:16 PM
Based on my experience with CD ASK units, the 7 digit part number on the side must start with the number "9" to guarantee support for AUX. So if the number is 6 123 456, it may not have the internal hardware to support AUX. However 9 567 890 would support AUX.
I don't have any experience with MD ASK units.
Old 06-12-2016, 02:34 PM
This is exactly why this forum is worth gold to Those of us breathing life into these fantastic cars.
